So you're saying it's the key for the PC application and not the scopes option code you're talking about?
If that's the case then I'm not sure you can even use Riglol to generate a key, I would suspect not but who am I...
I guess what I'm trying to say is that I don't know I currently don't have a need for the power analyzer so I'm not going to mess around with it.
Yes.
The scope options I've enabled long ago but I switched back to the default 100MHz of the DS4012.
Yesterday I've tried the first time to go back to 500MHz after I've installed the latest firmware by using Ultra Sigma as described in the PDF you've attached. That works fine! Thank you for that.
Then I've thought to download Ultra Power Analyzer. Done so.
Ultra Power Analyzer can be set "online", which connects to the scope and identifies its serial number. Either the 15 days trial is working or a 4x7 key has to be entered. Thought you've meant that also. And when entering the key there likewise it replies with the message that it does not match.
Well, it's not so important but would be an interesting tool. I can't see any Power option on the scope as the other options like RS232, SPI,.... so I was thinking that the key would only make sense to be used with the PC application itself.
Kind rgds
Gunb
