Has anyone successfully dumped the flash content of DSA815 ?
Just got a tiny progress, hope to see if anyone can share their finding?
I tried to dump BF526's async banks (0x20000000 ~ 0x203FFFFF) with bfin toolchain and ARM-USB-OCD-H cable,
however I found that the dump files are inconsistent, results are not the same.
(Tried on both DSA815 with bootloader 1.03 and 1.04)
Since TopJTAG was mentioned previously, I decided to give it a try.
The flash chip on DSA815 is Spansion S29GL064N90TFI04 (TSOP48 package, 8MB Parallel NOR flash, CFI compiant).
I used Segger J-LINK v9 as the JTAG cable.
I managed to figure out the setting for TopJTAG Flash Programmer:
1. BSDL for BF526 is attached.
2. Data bus is 16-bit wide with 16-bit maximum capable data
3. Signal pins:
CE = AMS0, active = low
OE = AOE , active = low
WE = AWE , active = low
A0 ~ A18 = ADDR1 ~ ADDR19
(A21 ~ A19 seem to be hardcoded as 110 or controlled by other device, FPGA?)
D0 ~ D15 = DATA0 ~ DATA15
4. Static pins
No static pins defined.
With the above setting, I was able to dump 1MB flash content.
My intention was to dump the flash content of a DSA815 with bootloader 1.03 and restore it on my DSA815 with bootloader 1.04.
I was able to dump 1MB binary files from each.
However when I tried to restore the dump from 1.03 to my 1.04 DSA815, the program and verification process was completed successfully.
But when I rebooted my DSA815, the bootloader remains 1.04 and everything is unchanged. (WP# was hardcoded at VIH, maybe there is some dynamic write protections?)
I was confused by the design.
BF526 supports up to 4 async banks with each has 1MB address. That will only be able to provide 4 MB address in total.
However, they uses a 8 MB flash. Is the reset of the space used by FPGA?
Also, as I mentioned, if A21 ~ A19 are hard coded with 110, BF526 will only be able to access 1MB flash space in this case.
And the size of DSA800_UpdateFile.sys (firmware) is nearly 2.x MB. I believe that A21 ~ A19 must be connect to BF526 in some ways.
Or it won't be able to program the whole content of the firmware update into the flash chip.
According to past experience, usually flash will maintain multiple copies of firmware (I've seen the case with 4 copies), and the content will be checked during boot. Maybe I was just updated one of them?
Appreciate if anyone with similar experience can share your finding.
UPDATE
The setup profile for TopJTAG Flash Programmer is attached. Remove the suffix .txt before use.
BDSL file needs to be placed in the same folder with the setup profile.
