Hello Guys,
First of all: Happy New Year ... a little in advance but as many, family will keep me away from the forum for a while so ...
I've been trying the memory dump of my MSO1074Z, I'm using an OLIMEX JTAG header (the same model as referenced here by different members), I use MAC OS X and Windows 7 (Enterprise, 32 bits) without success (so far).
Some of you have helped me to do some progress (thank you for that!), however still stuck; I should be doing some stupid thing I think
I wanted to confirm with you, I was wondering if I should turn the oscilloscope ON when trying the dump (?)
My problem seems to come from the USB driver for the OLIMEX header (in both MAC OS X and Windows)
I used the zadig (ver 2.1.1) tool (in the Windows environment, which is a real one not a virtual machine) to install the drivers (tried the three proposed by the tool) and I had the same error message: no device found.
In the MAC is not any better, I installed and locally compiled several tools without any success.
Any suggestion ? I really don't care which OS can make it, I'm using these two basically because is what I have at home, I could even use Linux virtual machines (I have Debian and Fedora already installed and running) but considered that if with the real hardware I'm not getting good results adding and extra layer of complexity wouldn't help at all.
Any advice will be appreciated!
Gus
