To all you MSO1000Z Owners: It's done, we found what Rigol changed for the MSO1k and we patched rigup to generate working keys.
Usage: Well, get the file, compile the source, call rigup like this:
./rigup license mso1074z.txt 0x1C0FF
Note: The License option *must* be supplied as hex, these are valid values:
0x1C001 - TRIGGER
0x1C002 - DECODER
0x1C004 - MEM-DEPTH
0x1C008 - RECORDER
0x1C00F - All of the above
There are also these options, but they will modify your scope into a MSO1000Z. They are mostly untested and might harm your children.
0x1C010 -
0x1C020 -
0x1C040 -
0x1C080 -
0x1C0FF - all Options
Generate the mso1074z.txt like this:
./rigup scan YourDump.bin > mso1074z.txt
Note: You will need to open the scope to get a dump. I'm not going to change that, but if anyone of you would like to reverse the firmware signing process, there is a hidden DBGCMD that might provide useful as an entry point for custom SCPI logic.
I want to thank rmd79 for his continuing efforts as well as all original authors of the rigup tool! You guys are the one who deserve any credit!
Also, thanks to sptm14 for you keeping all the info from the public. This motivated me to actually walk through their code!
Best regards,
Fabian
