I was however wondering... Is it possible, like with flash/hard drives, that they units are tested prior to being labeled, and perhaps there is variation in the quality of the analog front ends of these scopes. Some work up to 300mhz within some set parameters, others don't perform to the same quality threshold, and they are catagorised as such?
This would make sense when looking at the cost of these scopes. As with most things, making it with tolerance is cheaper, especially if you can rebrand lower quality items as a lower end in the same product range.
This is from a point of view or ignorance on the internals of these scopes, so I have no idea if there are components that have this kind of band of quality, or if its a case of it they work at 300mhz as designed, or not at all?
I don't think that's the answer - since, as far as we've discovered so far, the entire series has always been a single model - although it's possible Rigol has changed something.
As mentioned in my previous post, possible problems with 300MHz could theoretically arise from aliasing caused by a sample rate that's too low. When both channels are on, the max. rate is 1GSa/s - meaning the Nyquist frequency is just 500MHz - and from published BW tests, 500MHz is not attenuated enough by the DS2000 front end. Perhaps this is something that Rigol has tackled in newer DS2302s, although I'm skeptical about it.
EDIT: It just crossed my mind that perhaps there's a new revision of the DS2000A series motherboard because of the recent introduction of the MSO2000A. So maybe some new buyers of the DS series are getting the new revision - which could, in some way, impact the ability to install the 300MHz option.
I can screenshot mine to get the various software/hardware versions and partial serial number if that helps, although it's running modified 2.x (and thinks it's a DS2302 scope).
Just tried to get the new firmware, and says files are gone....guess Rigol didn't like ppl just downloading it. Anybody out there willing to share the files?
Like Codemonkey said: "The following instructions apply, don't hold me responsible if you brick your scope etc etc..."
Links to download the two update files (Bootloader and Firmware update) -> 00.04.00
Be aware that after finishing the update no downgrading is possible.
Start with the Bootloader File and follow the instructions. After successfully finishing the bootloader update
do NOT reboot as instructed. Instead, continue with the Firmware update file.
Bootloader Update (new link):
https://www.dropbox.com/s/nteyndjz17dmcmi/DS1000Z%28Boot%29update.rar
Firmware Update (new link):
https://www.dropbox.com/s/w9x66ghdhagtsaj/DS1000Z%28ARM%29update.rar
Hello.
Update file(bootloader)here is same as RIGOL International(China) Update file(MD5 checksum is same).
I don't why some model has to be done like that.
So my concerns,if we update only official update file(same as 1st file here) as usual,whether the options are remained or not.
The firmware here(2nd one) is a bit small file size.But I think,totally the result might be same.
Anybody only updated first file here?and no problem?
Be very careful with these files!!!! Bricking is very easy!!!!
You need to do is in 2 steps without reboot! if you reboot after the first file your are dead!
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
PS: there are some differences between serial numbers too! its better to ask for the right one for your serial number... its free... why download this one?
Just to follow up,
My new 2072A arrived, and using the Upgrade Utility from madcrow, it took me about 5 minutes to get all the options. Including the 300mhz!
Photos of the HW/SW versions are included.
https://www.eevblog.com/forum/testgear/ds2000a-upgrade-utility/msg467427/#msg467427
Thanks to all who made this possible!
One question. Is it now ok to upgade this to the latest firmware version?
So I noticed that your scope came with 3.0.SP1 firmware, whereas mine came with 2.0.1. When I get home I'll take a screenshot of the detailed system information and post it. If you could do the same we can compare and see if there is a difference.
Here is my screenshot with the newest firmware:
Here's mine, using non-A-keys firmware 2.x.
So this is firmware for the A version? If so can you post a link to the file?
I used the firmware from the review thread. I think the firmware is the same for both A and non-A.
Although it doesn't say this is for the 2000A series scopes? Does anyone have the latest firmware for these. I've requested it from rigol, but I have to wait for them to email it over..
So far, the firmware has been identical for all models in the DS2000 series: DS2000, DS2000A, DS2000A-S, MSO2000A, MSO2000A-S
my DP832 arrived yesterday, firmware 01.09 and only Analyzer and Monitor options are as trial available
![Sad :(](https://www.eevblog.com/forum/Smileys/default/sad.gif)
also the riglol key generator doesn't work, after entering the generated key it just says "wrong serial number" (I double checked if I entered the correct one)
it seems that it's since v01.09 and so far no working hack?
Good day!
We received a Rigol DS4014 yesterday. I scanned and read through this huge thread and also found this directory:
http://www.gotroot.ca/rigol/As I understand, to upgrade to 500MHz I need to use the DS2000A upgrade utility and the DS4000update_00.02.01.00.03.GEL
Can anyone confirm this?
Also want to upgrade my DG4062. How to do this?
Cheers
Sam
Will update you guys off course.
Thanks to all the geniuses that worked on this.
Sam
Which option do we choose for 1000z on the riglol? I remember 500uV is not good. how do you input all but that one?
DSER gets all but the 500uV option.
Cheers to all that worked on this!
I upgraded a DS2072A first to all options and 200mhz bandwidth but then couldn't get 300mhz with the 300mhz upgrade key provided by the key website or the non-patched PC generator.
I removed the keys and then used the patched key generator linked in this thread and generated a new all options+300mhz key and it worked fine.
I have since upgraded to the latest 03 firmware and all options are intact.
Ok, I got 300MHz upgrade and all options working on my DS2072A which was not able to upgrade to 300MHz. Here is what I did:
1-Install all options, no bandwidth upgrade (NSEH) using rigup or the upgrade utility.
2-Use rigup to get license for NS8N (All options - 56M + 300MHz) and install on scope in any of the methods described in this thread.
The result will be a scope with all options AND 300MHz!!! Success!
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
By the way, you can't use the upgrade utility to install NS8N since that program always uninstalls all options before installing new ones.
Good day!
Cheers
Sam
So I was wrong. I'm not finding the right info in this thread. Anyone please help?
Link to how to upgrade?
Hopless, but happy
Sam
Many thanks for this - It worked a treat
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
Now have 300MHz in addition to all other options!
Is upgrading DS4000 only possible via JTAG?
Noob wants to know
The result will be a scope with all options AND 300MHz!!! Success! ![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
PERFECT!
I did it the other way round on mine (NS8N first, then NSEH) and that worked as well. Now got all the goodies on 00.03.00.01.03 firmware. Thank you!
Noob wants to know
On the 2000 series the code can be entered using RIGOL Ultra Sigma, take a look at the PDF in
http://gotroot.ca/rigol/Alternatively the 2000 allows keys to be entered directly into the scope. Utility Menu -> page down -> Options -> Setup -> Editor
There's some 4000 stuff
here, I don't know if it's been superseded but it refers to "trigger option install" which suggests to me that it too is done via Ultra Sigma.
Lots more DS4000 info at
http://rigol.avotronics.co.uk/msods4000-series/
