Just a quick question (I have already read through almost the whole thread)
Has anyone run into problems using the 300MHz unlock?
And is it better to generate all the keys individually instead of just using the "ALL" option? (ie, generate 300MHz, serial, mem, etc and then enter them one by one?)
EDIT: Dear God this thread is confusing. Someone REALLY needs to write a summary. I'm a pretty experienced software guy and I kept getting lost.
It seems there are two different ways to unlock features, depending on whether or not you have the A version. Though I can't find it stated explicitly, I've inferred that if you try to use the keygens with the new A models they won't work unless you first install the patched firmware.
Am I correct in that? When I receive my DS2072A in the next month or so, I should use a USB stick to install the patched firmware, and THEN generate the keys using the keygen, and install? It seems that the patched firmware is an older version -- obviously upgrading to a newer firmware will disable the upgrades, correct? Never mind, apparently it's the latest firmware, but patched.
