Hello everybody,
Below you can find the instructions to migrate from standard DS2102 non A (100MHz) to an oscilloscope of 300MHz (DS2302) without any cable connection or teardown:
1) The original FW of my DS2102 System Information screen was:
Manufacturer: RIGOL TECHNOLOGIES
Model: DS2102
Serial: DS2A#########
Software version: 00.00.01
Hardware version: 1.0
2) At the begining I only use the software "Rigol Keygen v2.0b1" to generate the licence key marking/filling the following options in the software:
- Memory (56M)
- Serial Decode
- Advanced Triggers
- DS2202
- Official
- Option code = DSAZ
- Private Key = 8EEBD4D04C3771
The program generate the following licence key (don't use it in your DS2xxx because maybe don't work properly):
JDMNBSJ-W8SX28S-VLNA5W3-TAVGZYS
Introduce the licence key using Utility->Options->Setup->Editor (ON).
Link to download the software:
http://www.gotroot.ca/rigol/RiGen-2b1.zipAfter enter de licence key and accept it you can restart the oscilloscope and observe in the menu "Installed Options" that new characteristics now are enable.
3) After the installation of new characteristics you can migrate the FW to v00.01.01.00.02. One good thing is that the "Installed Options" where there after migration.
Model: DS2202
Software version: 00.01.01
In the "System Info" screen you can see perfectly the new model of the oscilloscope "DS2202" and in the "Installed Options" the following characteristics available:
- 56MB of memory available.
- Advanced Trigger options available (including Windows, NthEdge, HDTV, Delay, Timeout, Dur, USB).
- Decode (RS232, SPI and I2C, until now without CAN protocol).
- Bandwidth 100M and 200M.
4) We will migrate again the FW to the new version 00.02.01.00.03 (last version until February 13th 2014).
In this case the idea is to migrate the oscilloscope to the last version and then generate a new licence key, now using "Riglol 1.03c" web page and not any software.
The link is:
http://riglol.3owl.comTo do it you will need to complete again the following options:
Options: DSCA (here only use the code of 300MHz version because we need only enable this option)
Privatekey: 8EEBD4D04C3771
Press "Generate" and you will obtain the new licence key:
FD74GJQ-KLSEP6S-RVSCZNN-878KAWA
Introduce the new licence key using Utility->Options->Setup->Editor (ON).
Restart and "bualá" you will obtain a 300MHz oscilloscope.
Please if you need something write to me!
Best regards,
Seba from Argentina.
