Hi all,
I have, I hope a not too distracting question from a newbie. I've purchased a DS2102 some time ago and upgraded using the Keygen on the forum.
Unfortunately, I selected the DS2102 option by mistake. I then re-entered the code using the DS2202 and I have the following installed screen which is somewhat ambiguous as to what the scope bandwidth actually is.
At home I only have a POS AWG that can put out a maximum 25Mhz sine wave. Using a 2v p-p signal, my p-p voltage at 25mhz was 1.92v down from 2.24v. That works out to 1.3 dB loss (I think), which doesn't make sense if the scope were at 200Mhz.
Does anyone have a quick and easy method to ballpark the actual bandwidth with spit and chewing gum?
![Embarrassed :-[](https://www.eevblog.com/forum/Smileys/default/embarrassed.gif)
Should I reset the options by putting the code for the trial options for the DS2102 back in and redo it?
Kudo's to all the very large brains on the forum that made this all possible.
![Clapping :clap:](https://www.eevblog.com/forum/Smileys/default/clap.gif)
Thanks, S.
