Hi! Guys,
I've been a bit lazy
( might be all the Turkey I been eating ) anyway I was doing some work with my updated 72 to 302 and found that I couldn't record the waveforms I was working on.
I should add that I had the DSO Band Width set on 20MHz.
Also I don't use AUTO on my scopes, prefer to set the DSO to what I want, anyway I tried to use AUTO and all I got was a blank screen and then after a few tries a menu outline with no instructions.
Has anyone had any problems like that on a modified DS2072 ??.
I have a stack of work to do and will get back to it next weekend I am not really worried about the AUTO part but not being able to record and save the output is a big worry. It isn't a DSO if I can't store on it. It might have been turned into a DO Scope. I can still capture screenshots on USB Sticks but I need the storage so I can study and send the test results to others on the team. Nearly all our work is shared by Video conferencing. Someone said they had problems with adjusting voltage height, I haven't had that problem.
Also has there been other problems after changing from lower Band Width to 300MHz.
Thanks Guys
Rachael
Keeping a positive outlook
