0 Members and 13 Guests are viewing this topic.
DSHH includes a bit no one knows what it does. DSGH is all bits that are known for 300mhz,can,trig,mem,decodeGH = 00110 00111HH = 00111 00111
Lol the magic bit =) and What about 200mhz for the DSGH combination?
Quote from: m-joy on December 23, 2013, 06:02:26 pmLol the magic bit =) and What about 200mhz for the DSGH combination?Neither the 200m or 100m are set in the final "H". I'm not so sure it is a good idea to set any of the bandwidth ones together, then again I'm not so sure it matters either. But 300M on its own works so that is the simplest.
Thx. So What is the hex code for all Options and 300mhz but no 200mhz?
Quote from: m-joy on December 23, 2013, 06:10:32 pm[Thx. So What is the hex code for all Options and 300mhz but no 200mhz?SYSTEM:OPTION:UNINSTALLfirst
Thank you so much, the parts in which I am interested are these:https://www.eevblog.com/forum/testgear/rigol-ds2000-hardware-version-2-0/msg270218/#msg270218https://www.eevblog.com/forum/testgear/rigol-ds2000-hardware-version-2-0/msg272842/#msg272842
Sorry about the quality.
did you jtag dump the device?
In the input stage they also change a bipolar trt!!! What is the SMD marking code? R2W..? -> BFR93A?
No bus blaster yet. Will check the mail today. Xmas has stuffed postage in this part of the world.
This might be a better pic. JPEG compression instead of scaling.
The one you ordered ~4 weeks ago which was supposed to arrive 'in a week or so'? Somebody is screwing with you... Then again, perhaps New Zealand is the last stop for Worldwide mail...
Quote from: apelly on December 23, 2013, 06:54:28 pmNo bus blaster yet. Will check the mail today. Xmas has stuffed postage in this part of the world.The one you ordered ~4 weeks ago which was supposed to arrive 'in a week or so'? Somebody is screwing with you... Then again, perhaps New Zealand is the last stop for Worldwide mail...
Have you read this?https://www.eevblog.com/forum/testgear/sniffing-the-rigol%27s-internal-i2c-bus/msg350129/#msg350129Maybe my method (TopJTAG Flash Programmer) to download the flash is not valid for hacking. Cybernet should know better.
Have you read this?https://www.eevblog.com/forum/testgear/sniffing-the-rigol%27s-internal-i2c-bus/msg350129/#msg350129Yes.Figured I'd cross that bridge when I came to it.Frankly, I'm surprised nobody else has beaten me to it.
Quote from: apelly on December 23, 2013, 07:50:31 pmFigured I'd cross that bridge when I came to it.Frankly, I'm surprised nobody else has beaten me to it.LOL...They are waiting for someone to do it for them.
