here we go - custom DS2000 firmware, based on FW 00.01.01.00.02 (imho latest)
tricked into believing its a 350Mhz model, thus enabling 200M BW limit & 1ns timebase.
i also tried 500Mhz, while this allows 500ps TB, it does not make a difference on screen (probably hitting some hardware limit)
the only thing i dont like is that the model type should be changed too as it still says DS2202.
i also tried options de-install/install - worked fine.
to the best of my knowledge the change does not affect the bootloader, its only a modification of the application payload, so i consider
it safe to play with - there is always the possibility to flash back a standard version. i killed it several times during testing, no problem whatsoever (just flash back another version)
nevertheless - no guarantees whatsoever if u want to try this ! - no whining if something breaks !CHG3_RILOL.GEL - >
http://www.sendspace.com/file/ybkx21download, rename to "DS2000Update.GEL" -> put on USB stick -> install via bootldr method (power on + HELP)
./geltool -c -f CUSTOM/ASM/CHG4/CHG4_RILOL.GEL
model: DS2202
version: 00.01.01.00.02
bitmask: 0x7
num_of_sections: 0x12
section: #00: CRC:568EAD3C ADDR:20040000 LEN:0037D7DC [VALID CRC]
section: #01: CRC:5A3AC3C3 ADDR:20000000 LEN:0017CCA8 [VALID CRC]
section: #02: CRC:52C1A46B ADDR:20000000 LEN:00010F60 [VALID CRC]
section: #03: CRC:3F65CE51 ADDR:20020000 LEN:000322F6 [VALID CRC]
section: #04: CRC:CD2A7325 ADDR:200D6000 LEN:0000245A [VALID CRC]
section: #05: CRC:4CAC7870 ADDR:200C8000 LEN:00007FB4 [VALID CRC]
section: #06: CRC:454D5A80 ADDR:200F0000 LEN:000663F4 [VALID CRC]
section: #07: CRC:BCB8589E ADDR:20120000 LEN:00001D54 [VALID CRC]
section: #08: CRC:885A8C98 ADDR:20000000 LEN:0006DC62 [VALID CRC]
section: #09: CRC:B7481D18 ADDR:20040000 LEN:000032D8 [VALID CRC]
section: #10: CRC:D2B695F5 ADDR:20000000 LEN:00000B64 [VALID CRC]
section: #11: CRC:3F1C1BCC ADDR:20000C00 LEN:0003C598 [VALID CRC]
section: #12: CRC:1AF2DF9D ADDR:201E4C00 LEN:00000118 [VALID CRC]
section: #13: CRC:550735A2 ADDR:2003D400 LEN:00009010 [VALID CRC]
section: #14: CRC:5161CEE1 ADDR:201FD800 LEN:00001661 [VALID CRC]
section: #15: CRC:4B530B40 ADDR:20045000 LEN:000BB808 [VALID CRC]
section: #16: CRC:52C4EDFB ADDR:20100000 LEN:00046EF0 [VALID CRC]
section: #17: CRC:00000000 ADDR:20122800 LEN:00000000 [VALID CRC]
