Hi to all,
Thank you for reply stormbr.
1. Generates both Windows-Apps correct licenses?
You can use the synapsis version and hit 300mhz too, as the user Niffler explain. But i have sure that the two versions works fine.
I was not interested in more BW and 50ohm option than more in CAN trigger/decode for the future.
But it is nice to see the challenge how to get maybe all option free. That is like a TV Thriller…
The first question I posed was only because I got my DS2072 only a week ago. So I cannot decide to unlock the licenses immediately or later. I want check the device at first. Or send it back and wait for the DS2072A...
2. Are there more possible to activate?
Others users says for me that private key with 14 digits (8EEBD4D04C3771) not work 100% with ds2072a and i not tried uninstall the update yet (not have sure if i going to do this).
My case - with the same software/hardware/mcu version.
Unlock method: studio25 (last post) by windows prompt.
model: 2202 (after update)
serial number: not change
time base: 2ns
bw filter/limit - options: off - 20m - 100m - (not have 200m)
50ohm option: not unlock
Note:
The keygen of studio25 works well (thanks for your work) with all other options unlocked, but i not hit 300mhz.
The second point I wanted to see how the TV Thriller continues, and perhaps to give some ideas to rekindle the “research fire” to continue.
And it’s true, there was something like 13 and 14 digit of serial numbers with the DS2072 (without the “a”. Or do you get already a new one DS2072A?). I think, that problem was solved in
reply#567 ff on page 38. But it was not really clear to me, is it a general problem that been solved or the 13/14 chars long serial/lic1/lic2 or whatever problem…? Very confusing.
3. Does anyone know what the difference is to the MCU 02.12?
I think that it's not important because just the software version (not fpga) is updated.
The third point was not only to know, what is the change in MCU 02.12. I'm interested in, but also in how the MCU (or even FPGA) can get new Software? With a new Firmware? If the Firmware update 00.01.01.00.02 include the new MCU Version, why nobody get them? My Rigol was shipped with the new Firmware but with MCU 02.12. Where is the difference between the shipped version and the update version of the “same” Firmware (or does the Firmware never change the MCU Version?)? Maybe there are different versions of the same Firmware 00.01.01.00.02? Could I clearly express what I want to say?
This is all very exciting!
Bugware
