Author Topic: Sniffing the Rigol's internal I2C bus  (Read 1885574 times)
0 Members and 12 Guests are viewing this topic.
Offline Co6aka
Re: Sniffing the Rigol's internal I2C bus
« Reply #975 on: August 22, 2013, 11:34:53 pm »
surprise surprise ;-)
Cybernet, PM me with your preferred communications method; have some info that might be useful. ;-)
Co6aka says, "BARK! and you have no idea how humans will respond."
Offline Rigol-Friend
« Reply #976 on: August 23, 2013, 06:46:29 pm »
Hi Ladys and Gentlemen  ;),
at first, please forgive my wrong english. I have never learn this language  :(   here in Germany.
Ok, i have a question, please can onebody help me?
Some days ago I bought a DSA815-TG from Rigol (for me as radio amateur a phantastic instrument) and after that I read the interesst messages here, but I do not understand all (language).
Naturally is it for me nice to open the hidden options, too and so I download the file RiGen-2b1.zip and executed RiGen.exe (a very, very big thanks to Cybernet  ::), who develop it)
But I see I must input a "private key" in this keygenerator. And that is my problem, from where I can get this key? Here I found no information about.
That was my question.
Many thanks for read my crazy english....., sorry i can not better.
My english is VERY poor, sorry. I learned in school, about more than 55 years ago.
But I'am a happy owner of Rigol DSA815-TG with all options + DS2302 (was DS2072) + DG4202 (was DG4062)
Mega thanks to the developers of the key-generator ! Especially to CYBERNET with his brilliant brain !
Offline hammy
« Reply #977 on: August 23, 2013, 06:51:43 pm »
Der gesuchte Schlüssel ist: "80444DFECE903E"
The private key you are searching is: "80444DFECE903E"
Du kannst diesen auch in der Antwort #903 von "jamesb" finden.
You can find this private key in reply #903  from "jamesb".
Schicke mir eine eMail wenn Du noch Fragen hast.
Send me an eMail if you have more questions
73 de Hammy
PS: Thanks a lot to cybernet and dl5tor and all the others! Great work!
« Last Edit: August 23, 2013, 07:02:12 pm by hammy »
« Reply #978 on: August 23, 2013, 06:59:44 pm »
Hallo Hammy,
super, so schnell eine Antwort... Herzlichen Dank, ich werde den Key gleich mal versuchen.
Klasse,  ;D
Hi Hammy,
very fast answer... best thanks for it. I will try this key in the next minutes, phantastic,  ;D
« Reply #979 on: August 23, 2013, 07:10:06 pm »
Phantastic.....
All options of DSA815 are switcht "forever".
What a great work from Cybernet !!
@Hammy:
Thanks again for this private key. Where you found it?
Offline hammy
« Reply #980 on: August 23, 2013, 07:12:07 pm »
Hier im thread war er erwähnt und auch im sourcecode von cybernet:
You can find the private key with the search option and also inside the sourcecode from cybernet:
http://pastebin.com/ghYHnCfT
« Last Edit: August 23, 2013, 08:46:03 pm by hammy »
« Reply #981 on: August 23, 2013, 07:19:47 pm »
Ja, hattest Du ja auch vorher schon geschrieben (jamesb). Aber ich war eben so aufgeregt, dass ich diesen Hinweis gar nicht beachtet hatte  :-[
Und -ich muss es gestehen- in den C-Quelltext hatte ich gar nicht reingeschaut, da das Programmieren nicht so meine Stärke ist.
Tschüss und nochmals vielen Dank für Deine freundliche und schnelle Hilfe.
Rigol-Friend
Offline Carrington
My English can be pretty bad, so suggestions are welcome. ;)
Space Weather.
Lightning & Thunderstorms in Real Time.
Offline MaxwellsSilverHammer
« Reply #983 on: August 23, 2013, 07:35:18 pm »
I recently updated my options on my DS2202 and noticed the following strange issue under installed options with respect to the BW. Seems I have a 100MHz/200MHz scope now????? Any input would be greatly appreciated.  :-//
Offline synapsis
    • Blackcow
« Reply #984 on: August 23, 2013, 07:48:11 pm »
The private key is found by following the link in the RiGen app.
Having 100M/200M on the DS2000 scope is from enabling both options at the same time. (I forgot which code that was.) My scope has both options visible and still works fine.
While testing RiGen-1 I installed many keys on my scope.
Offline hammy
« Reply #985 on: August 23, 2013, 08:49:58 pm »
LOL http://translate.google.es/?hl=es&tab=TT#de/en/Rigol-Friend
Rigol = Atten  :-DD
Sorry folks, for highjacking the language. This was the fastest way to help a fellow ham.  :-//
Offline Wim13
« Reply #986 on: August 24, 2013, 10:46:37 am »
Is only à problem with firmware 01.00.05, then bandwidth options are not working
Offline Orange
« Reply #987 on: August 24, 2013, 03:07:54 pm »
Yes, you used the DSA9 option code, if you used the DSAZ code it would have had only the 200MHz BW option.
Both codes work OK (on the new firmware 01.01.00.02)
FIRMWARE LINK :
https://www.eevblog.com/forum/testgear/first-impressions-and-review-of-the-rigol-ds2072-ds2000-series-dso/msg158684/#msg158684
Offline tlu
« Reply #988 on: August 25, 2013, 07:05:32 am »
FIRMWARE LINK :
So which code is better?
Offline mickpah
    • Yeti Hacks
« Reply #989 on: August 25, 2013, 07:31:10 am »
I received last week my DP832. Without options. Does anyone know the JTAG pinout?
Is anyone willing to post his serial number and a valid code? I would be interest in a keygen ...
I was just about to be realy lazy and order one of these http://www.grandideastudio.com/portfolio/jtagulator/
out of stock though
Offline iceisfun
« Reply #990 on: August 26, 2013, 09:38:37 pm »
Is there a problem using this with Software version 00.01.01
« Reply #991 on: August 26, 2013, 09:44:38 pm »
only use the latest firmware 01.01.00.02 if you would like to update your options. The latest firmware can be found on another thread. Cheers
Offline Carrington
« Reply #992 on: August 26, 2013, 10:45:42 pm »
Those who now have by serial number DS2A0000000001 probably rewrited some other important data, besides the S/N.
But look at the images attached (DSX_QuickPrint1.png and SNumber.JPG). Is as if the loss of such data force to use the data contained in the firmware.
The question is: What S/N have you used to install the options? DS2A0000000001?
It seems that the S/N is write in more places:
https://www.eevblog.com/forum/testgear/sniffing-the-rigol's-internal-i2c-bus/msg265211/#msg265211
I attached other curious images. Is impressive all what cybernet has achieved...
Space Weather.
Offline iceisfun
« Reply #993 on: August 27, 2013, 12:16:58 am »
Got it working, had a data entry error - Thanks to everyone who worked on this.
I wish Rigol had sent the trial key as a card with the scope so you could enable them when you wanted, I'm pretty new to scopes and by the time I got familiar with things I burned up most of my trial, I need to mess with some I2C stuff and I have been turning the scope on and off using it as little as possible but now I can just use it normally and not worry about using up my trial time.
I'll be getting other Rigol products crackable or not, the quality (minus spelling errors) seems awesome. All the cheap stuff I've gotten needs replaced like the cheap ebay PSU and sig gen.
Offline true
  • INTERNET
« Reply #994 on: August 27, 2013, 01:28:11 am »
What other important bits are there?
If, after self-cal, using standards it measures correctly, what does it matter? It doesn't seem to have changed anything else by outward appearance, and if the unit functions normally, I really don't care what else could have changed, I can't see it anyway.
The only reason I care about SN is if I decide to sell it shortly to upgrade.
Offline Carrington
« Reply #995 on: August 27, 2013, 01:45:01 am »
* Then modify/edit the firmware, change "DS2A000 .. 1" string for yours S/N. And re-install it.
You don't lose anything if try it.  ;)
You can use a hex editor, 0xF045B0 see SNumber.JPG attached in my previous message.
Edit:
* It seems that does not work.  :(
« Last Edit: August 27, 2013, 10:52:36 pm by Carrington »
Space Weather.
Offline Orange
« Reply #996 on: August 27, 2013, 12:12:46 pm »
It looks like from the screenshot you have found an other hidden menu, where you can enter the scope model, serial number, and fan speed !
Question now is how to get there  ;)
Offline Carrington
« Reply #997 on: August 27, 2013, 12:25:30 pm »
No, I have not found how access to the hidden menu, if it exists. I wish.
Is only that I think there is the possibility to modify the S/N modifying the firmware. And it may only work in some cases, I have not tried.
The capture Hidden_Menu.JPG only shows the ASCII strings of a possible menu.
« Last Edit: August 27, 2013, 12:28:07 pm by Carrington »
Space Weather.
« Reply #998 on: August 27, 2013, 03:21:27 pm »
I thought I read somewhere in this thread where you can access the hidden menu via certain keystrokes. I may be wrong or maybe dreamed it, lol. I will look again and if I find it I will quote/repost here
Offline Carrington
« Reply #999 on: August 27, 2013, 03:28:19 pm »
Please someone who has had the problem with the S/N:
 What S/N have you used to install the options, after the "failure", DS2A0...01 or original S/N?
Space Weather.
