from the list with temp keys .. the temporary editions are SAAB (tm?), SAAC, SAAD, SAAE, SAAF ... .e.g. S=temp, A=perm
temp keys
80001 - SAAB
80002 - SAAC
80003 - SAAD
80004 - SAAE
80005 - SAAF
perm keys
00001 - AAAB
00002 - AAAC
00003 - AAAD
00004 - AAAE
00005 - AAAF
somebody with lxi could test other "bit positions" - to find other stuff ...
here is the not elegant way to come from option code to hexcode used ...
* DS2000 license options reverse bruteforcer
* (c) CyberNet, 2013.
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
#include <ctype.h>
unsigned char codemap_ee00d0[]={ 0x0, 0x0, 0x18, 0x19, 0x1a, 0x1b, 0x1c, 0x1d, 0x1e, 0x1f,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x1, 0x2,
0x3, 0x4, 0x5, 0x6, 0x7, 0x0, 0x8, 0x9, 0xa, 0xb,
0xc, 0x0, 0xd, 0xe, 0xf, 0x10, 0x11, 0x12, 0x13, 0x14,
0x15,0x16, 0x17 };
unsigned char codemap_20688e[]={ 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, /* 0-9 = 0x30 */
0x37, 0x37, 0x37, 0x37, 0x37, 0x37 }; /* A-F = 0x37 */
unsigned char vb[]={'A', 'B', 'C', 'D', 'E', 'F', 'G', 'H', 'J', 'K', 'L', 'M', 'N', 'P', 'Q', 'R', 'S', 'T', 'U', 'V', 'W', 'X', 'Y', 'Z', '2', '3', '4', '5', '6', '7', '8', '9'};
** convert string to uppercase chars
unsigned char *strtoupper(unsigned char *str)
unsigned char *newstr, *p;
p = newstr = (unsigned char*) strdup((char*)str);
while((*p++=toupper(*p)));
return newstr;
unsigned char code_map_206846(unsigned char i)
if ((i >= 'A') && (i <= 'F')) return(i-0x37);
if ((i >= '0') && (i <= '9')) return(i-0x30);
return(0x0);
** Encryption Routine 1
unsigned char *lic_code_map(unsigned char *lic_skipped)
unsigned char lv1,lv2;
unsigned char b1_mapped, b1_shifted, b1_remapped;
unsigned char b2_mapped, b2_shifted, b2_remapped;
unsigned char b3_mapped, b3_shifted, b3_remapped;
unsigned char b4_mapped, b4_shifted, b4_remapped;
unsigned char b5_shifted, b5_remapped;
unsigned char *lic_mapbytes;
lic_mapbytes=calloc(28, 1);
if (!lic_mapbytes) return(0);
lv1=lv2=0;
while(lv1 < strlen((unsigned char*)lic_skipped))
b1_mapped = codemap_ee00d0[ *(lic_skipped+lv1) - 0x30 ];
b1_shifted = (b1_mapped / 2) & 0xf;
b1_remapped = b1_shifted + codemap_20688e[b1_shifted];
lic_mapbytes[lv2++]=b1_remapped;
b1_mapped = b1_mapped & 0x1;
b2_mapped = codemap_ee00d0[ *(lic_skipped+lv1+1) - 0x30 ];
b2_shifted = ((b1_mapped << 0x3) | (b2_mapped / 4)) & 0xF;
b2_remapped = b2_shifted + codemap_20688e[b2_shifted];
lic_mapbytes[lv2++]=b2_remapped;
b3_mapped = codemap_ee00d0[ *(lic_skipped+lv1+2) - 0x30 ];
b3_shifted = ((b3_mapped / 8) | ( (b2_mapped & 0x3) << 2 )) & 0xF;
b3_remapped = b3_shifted + codemap_20688e[b3_shifted];
lic_mapbytes[lv2++]=b3_remapped;
b4_mapped = codemap_ee00d0[ *(lic_skipped+lv1+3) - 0x30 ];
b4_shifted = ((b4_mapped / 16 ) |((b3_mapped & 0x7) << 0x1)) & 0xf;
b4_remapped = b4_shifted + codemap_20688e[b4_shifted];
lic_mapbytes[lv2++]=b4_remapped;
b5_shifted = b4_mapped & 0xF;
b5_remapped = b5_shifted + codemap_20688e[b5_shifted];
lic_mapbytes[lv2++]=b5_remapped;
lv1 = lv1 + 4;
return(lic_mapbytes);
unsigned char * find_match5(unsigned char *code5)
unsigned char c1,c2,c3,c4;
unsigned char *input;
input=calloc(40,1);
/* lets bruteforce it ;-) */
for (c1=0;c1<sizeof(vb);c1++) {
for (c2=0;c2<sizeof(vb);c2++) {
for (c3=0;c3<sizeof(vb);c3++) {
for (c4=0;c4<sizeof(vb);c4++) {
input[0]=vb[c1];
input[1]=vb[c2];
input[2]=vb[c3];
input[3]=vb[c4];
input[4]='\0';
lic_mapbytes=lic_code_map(input);
if (!strcmp(lic_mapbytes, code5))
printf(" Match found with map bytes: %s\n\n", input);
return(input);
return(0); // no match
int main(int argc, char *argv[0])
unsigned char *lic_code;
unsigned char lic_code_len;
if (argc < 2)
exit(-1);
if (argc==2)
lic_code=strtoupper((unsigned char*)argv[1]);
printf("target-code: %s\n", lic_code);
lic_code_len=strlen((char*)lic_code);
if (lic_code_len < 5) { fprintf(stderr, "code is to short !\n"); exit(-1); }
if (lic_code_len > 5) { fprintf(stderr, "code is to long !\n"); exit(-1); }
input=calloc(40,1);
input[0]=vb[c1];
input[1]=vb[c2];
input[2]=vb[c3];
input[3]=vb[c4];
input[4]='\0';
// printf("input: %s\tlic_mapbytes: %s\n", input, lic_mapbytes);
if (!strcmp(lic_mapbytes, lic_code))
return(0);
printf(" No match found\n\n");
return(-1);
