Author Topic: Sniffing the Rigol's internal I2C bus  (Read 1869883 times)
0 Members and 38 Guests are viewing this topic.
Offline cosmos
Re: Sniffing the Rigol's internal I2C bus
« Reply #925 on: August 14, 2013, 09:13:06 pm »
What of the higher BW settings of the DS4000? ideas for a way forward?
First tries (in this tread somewhere) with bits next to decoding options seemed not to work.
From the teardown it seems it uses an ASICs in the frontend, would be strange if it is not ready for the full BW.
Is it the same amplifier (as in DS2000) with selectable BW following the ASIC? That amplifier had settings to go to about 1GHz so it could fit.
One post (not in this tread) claimed to have seen 500MHz pulse response with a DS4000 that got confused about its internal state.
Offline synapsis
    • Blackcow
« Reply #926 on: August 14, 2013, 09:44:27 pm »
enjoy
http://pastebin.com/ghYHnCfT
would not have happend without jtag firmware dump from DL5TOR, ecc help from some guy and testing by marc - thanks guys.
PS: the windows tool makers, might want to integrate that into their tool - only the length of the serial & private key differ, rest is the same ! (RILOL !)
The ecssign functions generated different keys between the DS2000 code and your DSA800 release. So there's something else different somewhere. ;)
Offline synapsis
    • Blackcow
« Reply #927 on: August 14, 2013, 09:54:16 pm »
I was in another city trying to find a job (no luck) and my PMs blow up about cybernet's latest offering.
I don't have a DSA815, so the only way I could test this code is to compare the output to cybernet's Linux code using Dave's demo unit serial number from his video. So, this code is considered beta.
Edit: Oh yeah, this is the Windows version of the keygen with DS2000 and DSA800 generators.
« Last Edit: August 14, 2013, 09:56:02 pm by synapsis »
Offline cybernet
  • pm deactivated, use the search function ...
« Reply #928 on: August 14, 2013, 10:28:35 pm »
sorry dude didnt mean to blow up your pm's ;-) - verification is rather easy, if u have a copy of riglol (verification part not keygen) and just update the "point2" (which is the public key) to the DSA and a minor update to the serial length check:
if (strlen(serial) < 0xd) { fprintf(stderr, "serial has invalid length !\n"); exit(-1); }
you can then verify them as easily as the DS keys.
to the script kiddies: those are not the private keys ...
#ifdef RIGOL_KEYS
unsigned char prime1[]="AEBF94CEE3E707";
unsigned char prime2[]="AEBF94D5C6AA71";
unsigned char curve_a[]="2982";
unsigned char curve_b[]="3408";
unsigned char point1[]="7A3E808599A525";
unsigned char point2[]="8445B2BE29E5C7";
#endif
#ifdef RIGOL_DSA_KEYS
unsigned char point2[]="691213692D18FA";
#endif
otherwise maybe somebody shares a real code with you DL5TOR has one, but im not doing it without his permission.
IMHO if u just swap in the new private key, and allow the serial to be >= 0xe it should work just fine for the DSA as well.
detection which key to use could be done via the serial format ...
___________________
"all rights reversed :-)"
R0=-0x18;
UNLINK;
RTS;
Offline synapsis
    • Blackcow
« Reply #929 on: August 14, 2013, 10:32:16 pm »
I ended up just replacing the ecssign function with yours. I only had to cast a couple unsigned chars and change a parameter name.  :-+
Offline cybernet
« Reply #930 on: August 14, 2013, 10:33:38 pm »
good stuff  :-+
___________________
R0=-0x18;
UNLINK;
RTS;
Offline jsykes
« Reply #931 on: August 14, 2013, 10:44:55 pm »
synapsis
YOU THE MAN!
The other day,  jamesb was kind enough to generate keys for me using cybernet's code with his Linux box. I asked him to generate more that one set but he said with the 815 keygen, the other sets generated were exactly the same. For comparison, I used your windows software to generate the keys for my serial number and they all match the keys generated by cybernet's code running on the Linux box. Your Windows software is verified good on the first try. GREAT JOB to you, cybernet, DL5TOR, and all that made this happen.
« Last Edit: August 15, 2013, 03:45:30 am by jsykes »
Offline Rufus
« Reply #932 on: August 15, 2013, 07:13:36 am »
talking of firmware i would love to get a 2nd DSA firmware (.sys file) if somebody has 2 versions, and is willing to share let me know.
I have 1.05 and 1.07.
Offline fqahmad66
« Reply #933 on: August 15, 2013, 09:37:35 am »
synapsis
YOU THE MAN!
Hi jsykes,
Did you also send the bf dump or just the s.no and licence info? I do not want to open the analyser.
Regards
F
« Last Edit: August 15, 2013, 11:16:34 am by fqahmad66 »
Offline fqahmad66
« Reply #934 on: August 15, 2013, 11:20:59 am »
Is it just a myth or real that after three wrong attempts of License Keys entry..the unit is locked and must be sent to China to unlock..
Offline dr.diesel
« Reply #935 on: August 15, 2013, 11:22:58 am »
Myth, at least on the DSA.
Offline fqahmad66
« Reply #936 on: August 15, 2013, 11:29:16 am »
I have aquestion. My analyser has serial no. starting with DSA8.... but cybernet's keygen wants to put s.no DS2A....
printf("  <sn>       serial number of device (DS2A.........)\n");
Is that OK?
Offline PA0PBZ
« Reply #937 on: August 15, 2013, 11:32:07 am »
DS2A is for the DS2000 series of scopes, where the keygen was born.
I think someone just forgot to change that bit.
Offline fqahmad66
« Reply #938 on: August 15, 2013, 05:06:19 pm »
Re.  'Rory'   « Reply #933 on: Today at 06:40:51 AM »
      Thanks Cybernet and dr.diesel, I'm up and running on all.
      The license info still shows the trial options by their keys and their "left time". I assume the trials will disappear once they expire?
_____________________________________________________________
No, it won't go away, and it is too bad because it says that the options were hacked in. This may be a dead give away when a future firmware version is installed. We should look for a way to clean them out, and of course leave the new option license info in place.
The trial key for the VSWR option stayed in after I entered the offical (sic) key I got from RIGOL.  So it's not specific to the hacked keys.
Hi Rory,
What is official (sic) key? Mine shows as trial.
REgards
F
« Last Edit: August 15, 2013, 05:07:54 pm by fqahmad66 »
Offline Carrington
« Reply #939 on: August 15, 2013, 05:08:20 pm »
DS2000
MODEL_DSModelType_modify_?_sub_1D6BE2                ROM    001D6BE2 0000005E R . . . . . .
MODEL_MakeDSModelType_sub_9850A                      ROM    0009850A 00000042 R . . . . . .
MODEL_MakeDSXString_sub_F204E                        ROM    000F204E 00000056 R . . . . . .
MODEL_Make_sub_F273C                                 ROM    000F273C 000002CC R . . . . . .
MODEL_and_SERIAL_sub_9731C                           ROM    0009731C 0000005A R . . . . . .
MODEL_createModelTypeString_?_sub_F21BC              ROM    000F21BC 00000116 R . . . . . .
MODEL_getDSModelType_sub_F1DE2                       ROM    000F1DE2 00000014 R . . . . . .
MODEL_getStr_sub_18F0F4E                             ROM    018F0F4E 0000000E R . . . . . .
MODEL_getTypeID_sub_18F0EDE                          ROM    018F0EDE 00000014 R . . . . . .
MODEL_getTypeID_sub_18F0F84                          ROM    018F0F84 00000014 R . . . . . .
MODEL_getVendor_sub_18F0F72                          ROM    018F0F72 0000000E R . . . . . .
MODEL_makeDSModelType_sub_A9760                      ROM    000A9760 0000008C R . . . . . .
MODEL_retDS2XXX_sub_F1E4E                            ROM    000F1E4E 00000012 R . . . . . .
MODEL_setDSModelType_sub_F26DE                       ROM    000F26DE 0000005E R . . . . . .
MODEL_set_DSModel_Type_sub_F1E84                     ROM    000F1E84 00000018 R . . . . . .
MODEL_sub_19D5CDE                                    ROM    019D5CDE 0000005E R . . . . . .
Some of these functions are not accessible. Hidden menu? Any ideas?
My English can be pretty bad, so suggestions are welcome. ;)
Space Weather.
Lightning & Thunderstorms in Real Time.
Offline PA0PBZ
« Reply #940 on: August 15, 2013, 06:12:04 pm »
Where do these names come from, I don't see them in the .GEL file?
Offline DL5TOR
« Reply #941 on: August 15, 2013, 06:17:16 pm »
DS2000
Those are no menus These are Subs in the Firmware the Names are added from cybernet  read that post to 100% thén you will know
Offline PA0PBZ
« Reply #942 on: August 15, 2013, 06:17:39 pm »
I guess he bought the official key, and now he's sic(k) of it  ;)
(The official key shows as "offcial" on the screen, so that is what he tried to type but he made a mistake quoting the mistake...)
The Latin adverb sic ("thus"; in full: sic erat scriptum, "thus was it written") added immediately after a quoted word or phrase (or a longer piece of text), indicates that the quotation has been transcribed exactly as found in the original source, complete with any erroneous spelling or other nonstandard presentation.
Offline PA0PBZ
« Reply #943 on: August 15, 2013, 06:20:53 pm »
Is there an IDA database for grabbing somewhere?
Offline Rory
« Reply #944 on: August 15, 2013, 06:21:32 pm »
Hi Rory,
REgards
F
offical (sic) was meant as joke to poke fun at Rigol's chinglish spelling of 'official' in the option info screen. (sic) means "this is how they spelled it, don't blame me for it".
Take a look at these two screen shots. One is before the hacked codes, the other after. Note that Option no. 5, which is the VSWR option, has the real official code from Rigol's website key code generator, generated from my unit's serial number and a code on the key certificate they emailed me when I purchased the optional kit which includes hardware.  Notice also that in both instances, the trial key still shows up with "Left Time".
Offline Rory
« Reply #945 on: August 15, 2013, 06:24:47 pm »
Hahaha you're right. I make a lot of mistakes...
Offline cybernet
« Reply #946 on: August 15, 2013, 07:02:22 pm »
from the list with temp keys .. the temporary editions are SAAB (tm?), SAAC, SAAD, SAAE, SAAF ... .e.g. S=temp, A=perm
temp keys
80001 - SAAB
80002 - SAAC
80003 - SAAD
80004 - SAAE
80005 - SAAF
perm keys
00001 - AAAB
00002 - AAAC
00003 - AAAD
00004 - AAAE
00005 - AAAF
somebody with lxi could test other "bit positions" - to find other stuff ...
here is the not elegant way to come from option code to hexcode used ...
* DS2000 license options reverse bruteforcer
* (c) CyberNet, 2013.
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
#include <ctype.h>
unsigned char codemap_ee00d0[]={ 0x0, 0x0, 0x18, 0x19, 0x1a, 0x1b, 0x1c, 0x1d, 0x1e, 0x1f,
0x0, 0x0, 0x0,  0x0,  0x0,  0x0,  0x0,  0x0,  0x1,  0x2,
0x3, 0x4, 0x5,  0x6,  0x7,  0x0,  0x8,  0x9,  0xa,  0xb,
0xc, 0x0, 0xd,  0xe,  0xf,  0x10, 0x11, 0x12, 0x13, 0x14,
0x15,0x16, 0x17 };
unsigned char codemap_20688e[]={ 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30,  /* 0-9 = 0x30 */
                                 0x37, 0x37, 0x37, 0x37, 0x37, 0x37 };       /* A-F = 0x37 */
unsigned char vb[]={'A', 'B', 'C', 'D', 'E', 'F', 'G', 'H', 'J', 'K', 'L', 'M', 'N', 'P', 'Q', 'R', 'S', 'T', 'U', 'V', 'W', 'X', 'Y', 'Z', '2', '3', '4', '5', '6', '7', '8', '9'};
** convert string to uppercase chars
unsigned char *strtoupper(unsigned char *str)
    unsigned char *newstr, *p;
    p = newstr = (unsigned char*) strdup((char*)str);
    while((*p++=toupper(*p)));
    return newstr;
unsigned char code_map_206846(unsigned char i)
 if ((i >= 'A') && (i <= 'F')) return(i-0x37);
 if ((i >= '0') && (i <= '9')) return(i-0x30);
 return(0x0);
** Encryption Routine 1
unsigned char *lic_code_map(unsigned char *lic_skipped)
 unsigned char lv1,lv2;
 unsigned char b1_mapped, b1_shifted, b1_remapped;
 unsigned char b2_mapped, b2_shifted, b2_remapped;
 unsigned char b3_mapped, b3_shifted, b3_remapped;
 unsigned char b4_mapped, b4_shifted, b4_remapped;
 unsigned char b5_shifted, b5_remapped;
 unsigned char *lic_mapbytes;
 lic_mapbytes=calloc(28, 1);
 if (!lic_mapbytes) return(0);
 lv1=lv2=0;
 while(lv1 < strlen((unsigned char*)lic_skipped))
    b1_mapped =  codemap_ee00d0[ *(lic_skipped+lv1) - 0x30 ];
    b1_shifted = (b1_mapped / 2) & 0xf;
    b1_remapped = b1_shifted + codemap_20688e[b1_shifted];
    lic_mapbytes[lv2++]=b1_remapped;
    b1_mapped = b1_mapped & 0x1;
    b2_mapped =  codemap_ee00d0[ *(lic_skipped+lv1+1) - 0x30 ];
    b2_shifted =  ((b1_mapped << 0x3) | (b2_mapped / 4)) & 0xF;
    b2_remapped = b2_shifted + codemap_20688e[b2_shifted];
    lic_mapbytes[lv2++]=b2_remapped;
    b3_mapped = codemap_ee00d0[ *(lic_skipped+lv1+2) - 0x30 ];
    b3_shifted = ((b3_mapped / 8) | ( (b2_mapped & 0x3) << 2 )) & 0xF;
    b3_remapped = b3_shifted + codemap_20688e[b3_shifted];
    lic_mapbytes[lv2++]=b3_remapped;
    b4_mapped = codemap_ee00d0[ *(lic_skipped+lv1+3) - 0x30 ];
    b4_shifted = ((b4_mapped / 16 ) |((b3_mapped & 0x7) << 0x1)) & 0xf;
    b4_remapped = b4_shifted + codemap_20688e[b4_shifted];
    lic_mapbytes[lv2++]=b4_remapped;
    b5_shifted = b4_mapped & 0xF;
    b5_remapped = b5_shifted + codemap_20688e[b5_shifted];
    lic_mapbytes[lv2++]=b5_remapped;
    lv1 = lv1 + 4;
  return(lic_mapbytes);
unsigned char * find_match5(unsigned char *code5)
  unsigned char c1,c2,c3,c4;
  unsigned char *input;
  input=calloc(40,1);
  /* lets bruteforce it ;-) */
  for (c1=0;c1<sizeof(vb);c1++) {
   for (c2=0;c2<sizeof(vb);c2++) {
    for (c3=0;c3<sizeof(vb);c3++) {
     for (c4=0;c4<sizeof(vb);c4++) {
      input[0]=vb[c1];
      input[1]=vb[c2];
      input[2]=vb[c3];
      input[3]=vb[c4];
      input[4]='\0';
      lic_mapbytes=lic_code_map(input);
      if (!strcmp(lic_mapbytes, code5))
           printf(" Match found with map bytes: %s\n\n", input);
           return(input);
  return(0); // no match
int main(int argc, char *argv[0])
 unsigned char *lic_code;
 unsigned char  lic_code_len;
 if (argc < 2)
  exit(-1);
 if (argc==2)
   lic_code=strtoupper((unsigned char*)argv[1]);
 printf("target-code:     %s\n", lic_code);
 lic_code_len=strlen((char*)lic_code);
 if (lic_code_len < 5) { fprintf(stderr, "code is to short !\n"); exit(-1); }
 if (lic_code_len > 5) { fprintf(stderr, "code is to long !\n"); exit(-1); }
 input=calloc(40,1);
         input[0]=vb[c1];
input[1]=vb[c2];
input[2]=vb[c3];
input[3]=vb[c4];
input[4]='\0';
       //  printf("input: %s\tlic_mapbytes: %s\n", input, lic_mapbytes);
if (!strcmp(lic_mapbytes, lic_code))
   return(0);
 printf(" No match found\n\n");
 return(-1);
___________________
R0=-0x18;
UNLINK;
RTS;
Offline Rory
« Reply #947 on: August 15, 2013, 07:50:02 pm »
But not this time. They actually spelt it 'offical'  !
Offline PA0PBZ
« Reply #948 on: August 15, 2013, 08:08:00 pm »
They keep trying and eventually will get it right, in the DS2000 series it is "offcial" !
Offline Carrington
« Reply #949 on: August 15, 2013, 09:07:04 pm »
DS2000
MODEL_....
Sub-algorithms in firmware. Right? I said before functions, no menu.
But I'm sure there is a hidden menu, that use some of this subs, and I think that in this forum only a few guys have the knowledge to find it.
We already know this: "Press the [Menu7][Menu6][Menu7][Utility] buttons one after another quickly."
Cheers.
« Last Edit: August 15, 2013, 09:16:21 pm by Carrington »
Space Weather.
