Short summary:
Make the Keygen:mkdir MIRACL
cd MIRACL/
wget
https://github.com/CertiVox/MIRACL/archive/master.zipunzip -j -aa -L master.zip
bash linux (or bash linux64 if running 64bit OS)
Paste the code from cybernet into rikey.c (make sure to add in the private key!) -> rikey.c code:
https://www.eevblog.com/forum/testgear/sniffing-the-rigol%27s-internal-i2c-bus/msg264876/#msg264876gcc rikey.c -I ./ miracl.a -o rikey
How to use it?./rikey <DSA2XXXXXXXXX> <OPTS>
where:
<DSA2XXXXXXXXX> = S/N of the device.
<OPTS> = DSAx for official [Permanent Options] or VSAx for trial [Temporary Options].
All Possible Options:Code table: Use DSAx for a official key, and use VSAx for a trial key.
x 200, 100, Mem, Dec, Trig
A none
B == == == == on
C == == == on ==
D == == == on on
E == == on == ==
F == == on == on
G == == on on ==
H == == on on on
Note: keys A..H wont change the model, only ADD an option.
2102:
J == on == == ==
K == on == == on
L == on == on ==
M == on == on on
N == on on == ==
P == on on == on
Q == on on on ==
R == on on on on <- All 2102
2202:
S on == == == ==
T on == == == on
U on == == on ==
V on == == on on
W on == on == ==
X on == on == on
Y on == on on ==
Z on == on on on <- All 2202
DONT USE BELOW Not recommended, as activates 2102 and also 2202:
2 on on == == ==
3 on on == == on
4 on on == on ==
5 on on == on on
6 on on on == ==
7 on on on == on
8 on on on on ==
9 on on on on on
How install/unistall keys?Using a SCPI command via Rigol Ultra Sigma, connect DSO via USB, boot the DSO, start Ultra Sigma, open SCPI Control Panel, and type the following:
:SYSTem:OPTion:INSTall <GeneratedKey>
Then, if you want to get rid of it, enter:
:SYSTem:OPTion:UNINSTall
