0 Members and 12 Guests are viewing this topic.
cybernet good work - what do you mean by crc cracking?
Why do you say downgrade to FW 05 from FW 03 - would that be upgrade?Is there somewhere that details the FW release versions and also has them available for download?
FW 05 came out first, then a subsequent version was released.. FW 03
Quote from: cybernet on June 28, 2013, 12:29:09 pm= bootloader checks a CRC (i assume) -> making it possible to load our own software, with a patched firmware i can boost TB to 500ps ;-)Do you know the location of the CRC? Is it a CRC32? Is it encrypted or changed in some way?
Alan - the actual FW version numbers are:FW#00.00.01.00.05FW#00.01.00.00.03
People here can give you copies of either FW if/when you need them, but I have to say - I suspect delays of Rigol gear to NA (and elsewhere) are likely to get longer
nope - when u find it, let us know ;-)
TEquipment says they should be receiving some in a couple days, we shall see how long it takes to get the one I ordered.
So there have only been two releases then? Can you PM these to me? I can PM you my email address if that is easier.
Availability: The supply of this article (DS2072) is expected in approx. 11 to 21 days.
Quote from: Carrington on June 28, 2013, 01:06:57 pmAvailability: The supply of this article (DS2072) is expected in approx. 11 to 21 days.Translation from Sales-Speak to Human: "We don't know when it will be available. Check back in 3 weeks to see if we know then."
Quote from: alank2 on June 28, 2013, 12:37:43 pmTEquipment says they should be receiving some in a couple days, we shall see how long it takes to get the one I ordered.Well, I hope it works out - but as reported by van-c here, Tequipment told him 10-12 days on June 25th - and he already had one on order for awhile.
Quote from: alank2 on June 28, 2013, 12:37:43 pmSo there have only been two releases then? Can you PM these to me? I can PM you my email address if that is easier.Early DS2000s came with FW#00.00.01.00.02 - although I've never seen anyone with a copy of that GEL.FW#00.00.01.00.05 is here.FW#00.01.00.00.03 is here.
What is the size of the eeprom that the firmware lives on?Is the firmware compressed in any way?
I scanned the first 3 pages - what happens if you try to modify a single byte you deem safe to modify and load the modified firmware? Does it reject loading it, or reject booting with it?
Yesterday I was told by tequipment that they have an order coming in within 2-3 days and that 6 were still not sold from that older...
Hello Wim13,you wrote: "YES it can be deleted..., just tried, do: uninstall"how can I do an uninstall ?DSAA does not work. DS2072 does not accept it.Best regards,egonotto
