Manufacture date code in serial no.:
DS1ZA yy ww xxxxx
Update: Another member generated keys with his complied code and everything worked. So I was doing something wrong or my compiled rigup didn't work. so Yes, rigup still works for Software 4.03.SP2, Board 6.1.4, without JTAG header.Quote
It was actually loaderr's version from Reply #4308 compiled with VS2013 Just to clarify.
The file I have attached was compiled on a windows 7 machine.
Use Rigol instead of rigup for the commands.
Hi all,
I uploaded fixed rigup sources to https://www.dropbox.com/sh/1yrh8s90ityn90s/AAA6PXlJk9gGQwoDOwO6TDQua?dl=0, feel free to use.
There are still some bugs as psysc0rpi0n was unable to unlock so far so use cautiously
I did some investigation how licenses are stored and it looks like they just programmed to flash and never erased. On startup FW scans all of them to decide which one to use. As longs as rigup works no need to worry about trials.
SYSTem: OPTion:UNINSTall is deleting "All official options removed" or something like this.
But after some mem dumps I found 36 Hours Trial License Key ... key. Like for DP832
there is the same for DS1054Z too in here http://www.gotroot.ca/rigol/riglol/
And this is V for generating trial keys for DS1054Z
Option VSER is all options like DSER but 36 hours trial version.
So others can be
DS1000z device options:
first character: D = official, V = trial
DSAB - Advanced Triggers
DSAC - Decoders
DSAE - 24M Memory
DSAJ - Recorder
DSBA - 500uV Vertical
DSEA - 100MHz
DSFR - all options
DSER - all options - 500uV Vertical
Currently I have DS1000Z-00.04.04.00.07 firmware.
Now if I add official license, all options are official and after delete
all options continue trial time. (and mem dump is messier at key regions
like he is generating all separate trial keys but factory ones are there too. )
So others can be
DSAC - Decoders
DSAE - 24M Memory
DSAJ - Recorder
DSEA - 100MHz
DSFR - all options
Sorry if this should have been clear after reading the last 10 pages...
I am just trying to understand if the www.gotroot.ca/rigol/riglol generated key still works for the newer DS1054Z?
software version: 00:04:04
board version: 0.1.4
I tried it, but no love.
Thanks for any help!
Now the later firmware for the DSA815 includes 10 Hz resolution, rendering the most useful hack obsolete, did anyone work out how to remove licence keys from an 815?
fun to see that this rigol hacking is still going on ;-)
doing that since about a week or so - but the discovered TWI functions so far a slave mode, not master mode - a lot of stuff is happening via DMA transfers to from the fpga (assumption). they use VDK and threads, which makes reversing a pain in the ass, 8k subs, thousands of pointers ... im slowly approaching the right subs. if anyone has ida with the blackfin cpu from rigol homebrew, im happy to share my custom GEL loader, and IDA DB.
