It halts when you send the halt command to openocd. Basically, you turn on the scope, then start openocd, then you send commands to openocd (or if you set up an openocd.cfg file, it will execute the commands in the config file when you run it, so it's useful to put the halt command in the config file). You want to execute the halt command immediately after the logo disappears and the options menu appears, showing you how long you have left on the trial features.
My suspicion is that they added code that after it checks the status of the licenses, it clears the keys from memory, so if you let the scope sit idle for awhile, when you do the memory dump, you won't be able to generate licenses from it, but if you take the memory dump right away as soon as that screen comes up, it won't have run that cleanup code yet and the memory dump will be useable. That's just speculation on my part, but it seems like a reasonable enough theory.
Sent from my m8wl using Tapatalk
