Here's my experience "testing" the ability to setup MSO1074z scope option capabilities:
I do not have a JTAG cable to get a memory dump. I researched alternatives (USB Blaster, Bus Pirate, etc) and I saw the following:
https://github.com/synthetos/PiOCD/wiki/Using-a-Raspberry-Pi-as-a-JTAG-Dongle. As I use Windows 10 I liked the idea of avoiding driver issues by using openocd on Linux.
I purchased a Raspberry Pi 3 (thanks Amazon for same day delivery!). I hooked it up and followed the instructions from the article to get openocd compiled. I removed the 2 references to "--enable-ft2232_libftdi" as "configure" indicated that that driver is obsolete and I wasn't planning on using it anyway. I stopped following the instructions where downloading of the tcl script (i.e. "sudo wget
https://gist.github...") is indicated as from there the instructions are for connecting the Pi to an Arduino Due.
With the Raspberry Pi and openocd ready I proceeded to open the scope as documented by others. I initially attempted to remove the warranty sticker using a plastic instrument only. After seeing some label separation I used a heat gun on low heat to soften the glue. It was much easier that way. I highly recommend using heat!
To figure out how to connect the Raspberry Pi GPIO pins to the scope JTAG port I used info from the article above, the scope JTAG information in
https://www.eevblog.com/forum/testgear/sniffing-the-rigol's-internal-i2c-bus/msg720691/#msg720691, reviewed the sysfsgpio-raspberrypi.cfg interface file and
http://pinout.xyz/pinout/uart. Here's what I came up with:
JTAG signal | Scope Header Pin | Pi GPIO Signal | Pi Header Pin |
TCK | 1 | 11 | 23 |
TMS | 3 | 25 | 22 |
TDI | 5 | 10 | 19 |
TDO | 4 | 9 | 21 |
TRST | 7 | 11 | 26 |
Gnd | 8 | Gnd | 25 |
I used very short cables (~6 inches) and quadrupled checked my connections as I was a bit paranoid about wrecking the scope processor. You should verify yours too
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
I started openocd using the following command line:
openocd -d2 -f interface/sysfsgpio-raspberrypi.cfg -f target/imx28.cfgI installed telnet (sudo apt-get install telnet) and connected to openocd using:
telnet localhost 4444Next turned the scope on. Once I saw the scope options screen I tried to halt the processor from the telnet session (i.e. "halt") but got an error saying that openocd could not communicate with the target. I checked the scope and it was clearly not stopped. I turned off the scope, reviewed my wiring. Everything was ok so I reviewed the openocd output and noticed an error in the openocd logging during startup indicating that it couldn't setup events. I surmised that openocd expected to be able to communicate with the target right from the get go so I decided to start the scope first and then start openocd.
That sequence worked and I was able to halt the processor. I did a small (4KB) memory dumps. The contents looked binary so I figured it was probably ok. The download rate was 6KB/s. I tried using various commands I found to turn up the speed (e.g. adapter_khz) but it appeared that those are not implemented by the Raspberry PI GPIO interface. I tried a larger dump of 1MB and found the rate consistent. That meant the required 64MB dump was going to take 3 hours.
I started the dump. As the scope case was not closed I decided to check whether anything was running hot. The device with a heatsink was running at ~130F so I hooked up a case fan to push air towards it and it cooled to ~90F. After ~3 hours the dump completed.
I built rigup 0.4.1 for the MSO1000Z using the content at
http://gotroot.ca/rigol/rigup-0.4.1-mso1000z.zip. Note that you need to change the makefile replacing "-dead_strip" with "--gc-sections -s". I used make clean to remove the existing/prebuild objects. I then used rigup to scan for the various keys. That worked! Next I generated a key for the triggers option (0x1c001). I double checked the key and input it in the scope. The scope accepted the key -- those options now showed "Official". I generated the other keys (0x1c002, 0x1c004, 0x1c008 and 0x1c080) and input them. I made a few mistakes inputting the keys in the scope so some were initially rejected but after correction all were accepted. I restarted after adding the last one (0x1c080 - Bandwidth) and now the scope reported itself as an MSO1104z with all options "Official".
I am thankful for all those who figured out the JTAG pin out, how to get the keys from the dump, wrote rigup. Thank you also to all who documented their experience to make mine possible -- it's great that this community exists!
