Here's the Windows app.
I tried for quite a while to get it to run under .NET 2.0, but Visual Studio 2010 gimped VC++'s ability to roll back the .NET version. This means it'll require .NET 4.0. 4.0 is 3 years old now, and I've included the web installer in the package.
How to use:
- You enter the private key in the first field. If you don't know where to get it, click the "Information" link.
- Enter the serial number from your scope into the second field.
- Select which options you'd like. The option code will be generated on the fly in the Option Code box. For those of you that want to play with the option codes, you can edit it by hand.
- Click Generate. It will take all the information and generate a key into the textbox.
Note: If User Account Control in Windows complains that it needs permissions, it's because the miracl library and cybernet's part of the code was compiled "unmanaged", and the GUI is "managed." This managed/unmanaged mess is what took so long.
Enjoy.
Edit: I was going to put the source project up on my website, but apparently my site is down. Once I get that figured out, I'll put it up.
