Ok, found the problem. Rigup was modified to work with the MSO1000z series by looking for a block of bytes beginning with the sequence 01 00 84 00 10 00, while the DS1000z (and other models?) use 02 00 84 00 10 00. By poking around with a hex editor in the dump files, I found that for my scope at least, that sequence is 02 00 84 00 10 00, which you're not supposed to see in an MSO. So not all MSOs are alike.
Just for clarity, this MSO1104Z with firmware 00.04.04.SP1 uses the sequence 0x02 0x00 0x84 0x00 0x10 0x00.
Fix: if you download the rigup-0.4.1-mso1000z.zip from gotroot.ca, open utils.c, in the function ScanKeys() uncomment the first static const and comment out the second, so it looks like this afterwards:
const unsigned int sequenceSize = 6 + 16 + 2 + 2*16 + 2 + 8 + 2 + 64;
static const uint8_t seq_1_ref[] = {0x02, 0x00, 0x84, 0x00, 0x10, 0x00};
//static const uint8_t seq_1_ref[] = {0x01, 0x00, 0x84, 0x00, 0x10, 0x00};
Then recompile:
make clean
make all
After this, I got all the keys, could generate all licenses, and all of them were accepted. Yay!
