Author Topic: Sniffing the Rigol's internal I2C bus  (Read 1885434 times)
Offline Jonson.poisk
Re: Sniffing the Rigol's internal I2C bus
« Reply #4025 on: September 26, 2015, 01:34:47 pm »
Hello dear!
You could help me?
Are there any have this firmware unlocking methods other than soldering pins FRAM?
Analyzer DSA815-TG
Firmware 00.01.09
Boot 00.01.04
Mainboard 00.07
Radio board 00.05
FPGA 00.04
Thank you
Offline smgvbest
    • Kilbourne Astronomics
« Reply #4026 on: September 26, 2015, 11:13:38 pm »
Hello dear!
You could help me?
Analyzer DSA815-TG
Firmware 00.01.09
Boot 00.01.04
Mainboard 00.07
Radio board 00.05
FPGA 00.04
Thank you
Currently the U1105 hack is the only way to keep you're features enabled on the DSA815
I'm trying to figure it out but am new to this so my approach is to educate myself but I am missing one thing
I'm looking for a memory dump of a DSA815 with the boot 1.03 when it it was possible.   I want to trace exactly what rigup did to find the private key then see if I can duplicate with boot 1.04 but so far no one has offered up a dump with boot 1.03 so nothing is is happening for now.
Sandra
(Yes, I am a Woman :p )
Offline MiataMuc
« Reply #4027 on: September 27, 2015, 02:22:45 pm »
Hi
I have a DSA 815, Bootloader 00.01.03, Firmware 00.01.12, all options enabled..
I'd be willing to help you. Do I have to read the flash by network or by an adapter?
Offline longview
  • Oh god how did this get here I am not good with co
« Reply #4028 on: September 27, 2015, 04:19:08 pm »
FRAM can be read out over USB/Network, at least part of it.
I use Rigol Bildschirmkopie to send commands, mostly for convenience:
:SYST:FRE? 0,1048576
:SYST:FRE? 1048576,1048576
:SYST:FRE? 2097152,1048576
:SYST:FRE? 3145728,1048576
I've got an Atmel ICE coming soon, can I use the JTAG in that to do an SDRAM dump?
« Reply #4029 on: September 27, 2015, 05:44:04 pm »
Well, that have proposed the post above  ;D
Offline smgvbest
« Reply #4030 on: September 27, 2015, 07:31:33 pm »
FTI
Tha'ts a SDRAM dump not a fram dump.    the first 8M of memory in the Blackfin is from 0000 0000 - 007F FFFF and only 4M is used.  the 2nd 4M is a copy of the first 4.
FRAM is not memory mapped into the address space of blackfin from what I can tell.  the FRAM is a I2C device and would have to be read out directly    Howardlong can correct me if I'm wrong
If someone can get me the first 4Mb of SDRAM using this commands who has a boot 1.03 It would help allot.
you can save each memory block then combine them at either a dos prompt or linux commandline and let me know how to get it
right now I've dumped 1.14 with boot 1.04 and looking at it I see nothing that look like the same eye catchers
rigup used this
      0      02 00 84 00 10 00
      6      <16 bytes of XXTEAKey>
     22      20 00
     24      <16 bytes of RC5Key1>
     40      <16 bytes of RC5Key2>
     56      08 00
     58      <8 bytes of bit-shuffled ECC public key>
     66      40 00
     68      <64 bytes of some ASCII-HEX data>
    132      <END>
for the MSO1000Z the only change was offset zero for the eye catcher
      0      01 00 84 00 10 00
then a change to how things are encrypted.
I see nothing like that in the dump I have so they could have simple bit shifted things to scramble them for example.
That's why I want to see a dump of boot 1.03 SDRAM
Sandra
Offline MiataMuc
« Reply #4031 on: September 28, 2015, 07:00:47 pm »
pm
Offline smgvbest
« Reply #4032 on: September 29, 2015, 12:48:46 am »
pm
Thank you.   this confirms to me that the keys for the DSA815 where found in another manner.  the eye catchers are not there in your dump or mine with V1.14 and boot 1.04 which means to me they where found in another way
Sandra
Offline Orange
« Reply #4033 on: September 29, 2015, 08:42:18 am »
pm
On the DS2000 the change came when a new hardware revision was introduced. With new hardware on the DS2000A RIGOL also introduced customized encryption parameters for each unit. Perhaps they did the same on the DS815. I don't think the boot code plays a role here, apart from the fact that you cannot downgrade.
Have you tried scanning the dumps for license keys with 'rigup search [KEYFILE] DUMPFILE'
BTW on a DS2000A you need at least 32Meg to get results
« Last Edit: September 29, 2015, 08:45:26 am by Orange »
Offline smgvbest
« Reply #4034 on: September 30, 2015, 01:07:44 am »
pm
Yes I did,  I also tried a 8MB dump on mine and neither found anything.   I also tried dumping over SCPI the first 32Meg and it could not find anything either
Sandra
Offline Orange
« Reply #4035 on: September 30, 2015, 08:34:39 am »
pm
I scanned my DSA815 via dumping over SCPI, it is an early one.
Boot is 01.02
Version of main board is 00.04
Firmware is 1.09
I found 5 license keys in the lower part of the flash memory, basically the four I put in myself, and there was already one present, probably for the tracking gen.
Also i tried to find the known private key in the flash (32 meg) and did not find it.
Offline smgvbest
« Reply #4036 on: September 30, 2015, 10:40:46 am »
Yes,  Looking at a pre boot 1.04 I was able to find the same in even a 4Meg dump but in mine at 1.04 a search turned up nothing at all.
The eye catcher bytes seem to typically be there but not on the DSA's.  I manually went through the 32Meg dump and saw nothing that looked familiar
I do have one throught and maybe something that's been tried before but I was thinking if I went into the licensing screen and entered even a bad key it would maybe have a deciphered bit strings in memory at that point so I'm going to try that out next
Sandra
Offline cybernet
  • pm deactivated, use the search function ...
« Reply #4037 on: October 10, 2015, 11:30:08 pm »
if u are after the bootloader for the DSA than i would assume that it is located at 0x2000 0000 in the Flash as a LDR stream. (thats how the DS2x does it)
0x2000 0004 contains the length of the LDR stream for the bootloader
try to dump that and use a tool like ldrviewer to see if it actually contains a LDR stream if so - i have a nice LDR loader for ida pro that i can share.
usually the bootldr (again DS2x knowledge) then loads yet another LDR which is the actual APP image.
dumping from 0x0 onwards is RAM - which gets overwritten by the bootloader with the APP image, so i doubt u get that data out with SCPI.
best to use gdb, and break the boot process before the APP image gets executed.
from my old notes
BootMode (BMODE) is 0001b
The kernel boots from address 0x20000000 in asynchronous memory bank 0.
The first byte of the boot stream contains further instructions whether the memory is eight or 16 bits wide.
BootLoader takes care of:
bfin init (EBIU, PLL, PORTS, DMA, SPORT)
fpga init
lcd init and displaying ultravision & rigol logo
load the application image LDR from flash @0x20040000+0x4 (first 4 bytes contain length of LDR stream)
optionally firmware upgrade via DS2000Update.GEL
run bfin executable from RigolDsExe.ldr (you need to disable any interrupts quickly or it will crash)
___________________
"all rights reversed :-)"
R0=-0x18;
UNLINK;
RTS;
Offline Macbeth
« Reply #4038 on: October 11, 2015, 06:50:53 pm »
Hi cybernet,
Please share... anything about Rigol and Blackfin. I'm quickly learning about it as I just bricked my DM3058E doing a firmware downgrade using the Rigol method of a supplied file on a USB stick plugged into it. I've flashed these firmwares before and not had a problem, but this time Murphy got me :(
I've been reading up on the ADSP-BF531 documentation and the Rigol binary file appears to follow the LDR format, just prefixed with a null terminated RIGOL firmware ID string. An example is the previous DM3058 firmware available here.
I've got the 90 day trial of VisualDSP running and tried that LDRViewer application, but it doesn't seem to like the Rigol files even when I strip the header firmware string out and start on the 4 byte address, 4 byte count, and 2 byte flag immediately after it. But following the headers and blocks manually in a hex editor it seems ok.
Now, I have to re-flash using the JTAG port. I'm guessing the supplied rigol firmware minus the id string is probably ok. I only have an Altera USB blaster so had a look at the official tools and nearly had a heart attack at the prices  :-DD - is it possible to flash with the USB blaster? I also noticed an Olimex ARM-USB-OCD tool that looks reasonably priced and supports debugging so would be worthwhile for me to have a go at reversing this thing and fixing bugs that Rigol are so slow to...
I've also got an, ahem, evaluation version of IDA Pro 6.6+SDK and found a Blackfin module but haven't had much luck getting it to work, it seems to be for an earlier version :(
Anyway, any help much appreciated ;)
Sorry to move off track from the DSA guys, but there is a lot of info here relevant to my DMM. Why do Rigol love the Blackfin DSP so much? It seems like total overkill for a simple DMM  :-// Though I guess if they paid for all the licensed tools for their scopes and stuff... and their devs are used to it... maybe it makes sense?
Offline Asmyldof
  • Freelancer - Persnicketist - Do'er of stuff
    • Asmyldof's Home. It's old, not quite impressive, but it's there.
« Reply #4039 on: October 17, 2015, 10:46:49 pm »
Hey Guys and Gals,
I want to aware-nize you all of this post I made in chat:
New Bootloaders for DG5 and DP800
Also, @smgvbest, once I have time again from the freelance assignment from hell (should be soon), as I am interested in hacking the DS815 myself as well, I could look into the rigup code, possibly confer about what I see and how that fits the "old dump" you have and how that might be adapted to the new one.
If it's a puzzle, I want to solve it.
If it's a problem, I need to solve it.
If it's an equation... mjeh, I've got Matlab
(not really though, Matlab annoys me).
Offline smgvbest
« Reply #4040 on: October 18, 2015, 10:35:08 pm »
Thank you cybernet
I need to get a header on my JTAG port as I looks like mine was no populated then I will try that
I'm sure others have noticed but the newer keys seem to be mixed case vs. uppercase.
not sure what that implies though.
from my old notes
fpga init
Sandra
Offline JHERCULEES1
private key for rigol ds4000
« Reply #4041 on: October 21, 2015, 09:42:59 pm »
DS4000 series Bandwidth (model type) Option Codes.
For those who have an interest in the DS4000, I have found the option codes for selecting the bandwidth .
This also sets the model type.
For example the code FAB9 will select 500Mhz, (DS405x), with all Decoders enabled.
The attached file contains all the details.
There are also two un-documented, possibly future, options called "Power Analysis" and "MA".
The option codes have been tested with firmware ver 00.02.00.00.04 and ver 00.02.01.00.03.
here he mentions unlocking the options in the rigol 4000 series but no mention of the private key that is needed for the tool to work ?
does anyone know what posts talk about the private key for the 4000 series , i located the private keys for both the 1000 and 2000 series but no 4000  private key
Offline Macbeth
« Reply #4042 on: October 21, 2015, 10:14:26 pm »
Re: Dead Rigol DM3058. Thanks to a lot of pointers in this thread I've managed to fix my DMMs corrupt flash.  :-+ Rigol wanted me to send it to them for some weird reason. Other manufacturers like Keithley have not had issue sending me raw chip level firmware files so I can hardware flash my own, but Rigol wouldn't. Sorry, but I prefer to DIY.
Oh. Windows 10 appears to be rubbish with this sort of stuff. BSOD's constantly since trying to get drivers to work with Olimex and Altera Blaster. The absurd driver protection scheme rules out most FTDI based devices. Linux is a far more sensible environment. Dual Boot FTW (with the grub loader remembering what OS I last booted)  :-+
Offline MarkF
Re: private key for rigol ds4000
« Reply #4043 on: October 21, 2015, 11:56:38 pm »
I have a DS1000Z series scope.  However, if the DS4000 series is the same, the Riglol key generator will fill in the private key after you enter your serial number..
Offline nbritton
« Reply #4044 on: October 22, 2015, 09:03:32 pm »
What is the DS4064? I did a strings dump on the firmware update and that was in there.
$ strings DS4000Update.GEL | grep DS406
DS4064
Given Rigol's model naming system that would imply a 600 MHz DS4000 exists.
« Last Edit: October 23, 2015, 12:34:32 am by nbritton »
Offline wyx
« Reply #4045 on: October 31, 2015, 04:20:31 pm »
Hi, I am a EE student in US. I recently purchased a MSO2072scope and I follow the hack instruction using ubuntu to unlock my scope feature. However, there's always some error message while compiling the code from github. Can anyone help me with that? My scope is running software 03.01 and hardware 2.2 is it able to be upgraded using that hack??
Offline nbritton
« Reply #4046 on: November 01, 2015, 06:48:41 pm »
What is the error message? What version of Ubuntu are you using, I would recommend the 14.04 LTS release.
Offline Macbeth
« Reply #4047 on: November 01, 2015, 10:41:30 pm »
Just remember with Ubuntu you often have to use sudo to do stuff. Like when compiling something you need to do sudo make install rather than make install.
I know obvious, but I wasted a whole day when I didn't realise that just accessing serial ports or USB also requires root privilege!  :palm:
Offline farzadb82
« Reply #4048 on: November 02, 2015, 01:38:46 am »
It sounds like you need to create a udev rule for your device. You should really avoid running things as sudo when possible. The only time you'd absolutely have to is when you're installing something into the system. Other than that, you shouldn't have to run commands using sudo.
Here's a good reference for creating udev rules (http://ubuntuforums.org/showthread.php?t=168221). It talks specifically about creating rules for external media, but the same concepts can be applied to any usb device.
Offline Macbeth
« Reply #4049 on: November 02, 2015, 05:31:05 am »
Yes, that is exactly what I ended up doing. Thanks for reminding me!
I also had to add my account to the dialout group to allow me to use /dev/ttyUSBx
Oh, one thing that bugs me. I've installed the blackfin toolchain and whenever I am using UrJTAG (bfin-jtag) I've found the cursor keys seem to be mapped to something strange and so I just get things like "[]]]" output when I press a key. It makes recalling command history a PITA. I've also tried UrJTAG from the official repo using apt-get-install and with that version the command history and editing using cursor keys works as expected.  :-//
