Author Topic: Sniffing the Rigol's internal I2C bus  (Read 1905295 times)
Offline dtran11
Re: Sniffing the Rigol's internal I2C bus
« Reply #2200 on: December 28, 2013, 08:34:11 pm »
Does anyone know what the unknown option for the DS1000Z is for yet? I just installed it but would like to know what it is for. Also how do I revert back to DS1074Z?
Thanks
Offline AndersAnd
« Reply #2201 on: December 28, 2013, 08:43:13 pm »
I already mention that in a previous answer to your question: https://www.eevblog.com/forum/testgear/sniffing-the-rigol's-internal-i2c-bus/msg355312/#msg355312
Also is there anyway to revert the options if I need to send in for repair?
Use the SCPI command ":SYSTem:OPTion:UNINSTall" to remove installed option keys again. Search this topic for :SYSTem:OPTion:UNINSTall
« Last Edit: December 28, 2013, 10:03:05 pm by AndersAnd »
Offline m-joy
« Reply #2202 on: December 28, 2013, 09:14:47 pm »
neamyalo thank you for your work - would you be willing to upgrade to the latest firmware and repeat the full dump?
Your dump says it is 00.02.00.00.04 and the latest fw I know of is 00.02.01.00.03.
Thanks!
Does that change anything?where is cybernet btw...
Offline Avotronics
    • Rigol Hacks
« Reply #2203 on: December 28, 2013, 09:37:06 pm »
Thanks!
[/quote]
[/quote]
What are we, his nannies? Lol ;-)
Why would you buy something ready made when you can make it yourself with half the features for twice the money!
Offline tirulerbach
« Reply #2204 on: December 28, 2013, 09:52:51 pm »
Hello,
I remembered I'm owning a JTAG-Dongle...  :-/O It is an Olimex ARM-USB-OCD. In the meantime I opened my DS2202A, attached the JTAG, downloaded the bfin-uclinux stuff and started urjtag:
jtag> cable arm-usb-ocd
Connected to libftdi driver.
jtag> frequency 500000
Setting TCK frequency to 500000 Hz
jtag> detect
warning: TDO seems to be stuck at 0
jtag>
Lower frequencies didn't work either...
So after fiddling a little bit I assume that the Utst  Voltage (3.3V) on Pin 1 on the JTAG header is to weak. According to the schematic posted above it is connected via a pull-up of 10k to 3.3 Volts. The voltage drops to about 1.8V when I connect the JTAG-dongle. That is about 150uA.
So, do you think I just can use an external 3.3V supply for the JTAG-dongle?
Maybe this is the same issue which neamyalo very slow jtag speed? What do you think?
Offline Flipp
« Reply #2205 on: December 28, 2013, 09:53:37 pm »
Lol:
DS2000 Series is a new generation oscilloscope. It has 2 channels. It has a sibling version with logic analyser DS2000D. The maximum bandwidth is 200M, and the peak sampling rate is up to 1G.
 :-DD
From HTML Page inside Jtag Dump
Flip :wtf:
Offline AndersAnd
« Reply #2206 on: December 28, 2013, 10:01:24 pm »
Hello,
jtag> detect
jtag>
From what I have understood from Cybernet's posts about Rigol JTAG interfacing you have to add the 10k and 3k9 pull-up resistors externally yourself. Did you measure the resistance from SRST [pin 2] and TRST [pin 10] to 3.3V [pin 1]?
Just managed to discover the BF526 on the JTAG chain :-DD  >:D
Pinout:
   3,3V      (1)   (2) /EMU, /SRST (use a 10k pullup to 3,3V)
   no pin   (3)   (4)  unused (seems to be GND)
   nc         (5)   (6) TMS
   GND      (7)   (8) TCK
   GND      (9)   (10) /TRST (use a 10k pullup to 3,3V)
   GND    (11)  (12) TDI
   GND    (13)  (14) TDO
The 14pin header near the Blackfin. I actually think i fried my 3,3V on Pin1 - even if loaded with 10k it drops down to 1V,
so im running the pullup for pin (2) to the 4 pin connector on the opposite side of the PCB labeled VCC (3,3V) instead of pin1
CAUTION: the usual ADI JTAG has pin1 connected to GND (this shorts VCC to GND), which probably killed my VCC there ...
Scope is still fine, so just fried some output stage somewhere i guess ;)
For the jtag adapter itself im using the Amontec JTAG Key Tiny (30$) - TopJTAG eval discovers an Analog Devices BF526 (IDCODE=227E0CBh) ... next up trying urJTAG + bfin-gdb.
JTAG Key: http://www.amontec.com/
started dumping memory via JTAG on the DG4000 - no probs at all exact same layout as the DS2000's JTAG - aux 3,3V can be stolen from the header next to it if needed for jtag adapter.
« Last Edit: December 28, 2013, 10:25:37 pm by AndersAnd »
Offline tirulerbach
« Reply #2207 on: December 28, 2013, 10:07:32 pm »
jtag> frequency 5000000
Setting TCK frequency to 5000000 Hz
jtag> detect
IR length: 5
Chain length: 1
Device Id: 00100010011111100100000011001011 (0x227E40CB)
  Manufacturer: Analog Devices, Inc. (0x0CB)
  Part(0):      BF526 (0x27E4)
  Stepping:     2
  Filename:     ./../share/urjtag/analog/bf527/bf527
jtag>
 :-DD No risk no fun... There is a "SPI BOOT" header oh the right side of the PCB. Pin 7 has 3.3 Volts and it works...  8)
So now I'm learning how to dump that beast....
Offline m-joy
« Reply #2208 on: December 28, 2013, 10:22:09 pm »
Dumpy dumpy dooo!
The only Problem that i see is.... Cybernet seems to be the only one that can handle the dump xD
Offline tirulerbach
« Reply #2209 on: December 28, 2013, 10:45:19 pm »
Yeah, looks like that dumping works. About 50 KByte/s.  :=\
Results are consistent.  :-+
So, I have questions:  ::)
a.) How large is the RAM? 64 Meg?
b.) How to enter into the boot-loader on startup? I read somewhere the dump in boot-loader mode is also needed?
« Last Edit: December 28, 2013, 10:57:47 pm by tirulerbach »
Offline Avotronics
    • Rigol Hacks
« Reply #2210 on: December 28, 2013, 11:10:40 pm »
Cybernet surely does love them big fresh dumps :-)
Offline neamyalo
« Reply #2211 on: December 28, 2013, 11:42:05 pm »
I think the SDRAM is only 32 MB. I could only see one 32 MB IC connected on the PCBA and in a post a while back Alan2k (I think) also mentioned that the register values corresponded with only 32MB of SDRAM, starting at address 0.
Offline Dave Turner
« Reply #2212 on: December 28, 2013, 11:45:46 pm »
My DS1074Z-S reports a software version - 00.02.00.SP1.
Has anyone seen a later version?
Offline dtran11
« Reply #2213 on: December 28, 2013, 11:48:50 pm »
Sorry, I thought the 100mhz was a different animal. So that command will remove all options (keys) at once? thanks
Offline neamyalo
« Reply #2214 on: December 28, 2013, 11:57:14 pm »
Thanks!
Hi Alan, no problem with the dumps so far - my pleasure - but I'd rather not do another if I can help it - my JTAG link's so slow (its 14 hours of continuous dumping just for one snapshot).
I think S/W 00.02.00.00.04 will be good enough for our purposes  ;) Also, let's see how tirulerbach gets on - it sounds like his link is blazing @ 50 kB/s  8)
Offline alank2
« Reply #2215 on: December 29, 2013, 12:23:47 am »
The only problem is that 00.02.00.00.04 is an unknown one in that nobody has a gel file for it.  I know it is a lot to ask for another dump, but the 00.02.01.00.03 is available in gel and can be analyzed.  If you can at some point that would be appreciated - either way thank you for your work!
Offline tirulerbach
« Reply #2216 on: December 29, 2013, 12:33:31 am »
My first dump is completed.  :-+
DS2202A unmodified, firmware 00.02.00.00.04 and booted to normal operating mode...
Now, somebody would like to tell me how to enter the boot loader?
Have fun! :-DD
https://mega.co.nz/#!6FcXUKYT!XsgK-3tIaJp2inP6UBlzWXDfs8VIkfkpQJNPXjY5_yA
(Sorry for the file hosting...   :-\ Do you have some better site?)
« Last Edit: December 29, 2013, 01:46:06 pm by tirulerbach »
Offline AndersAnd
« Reply #2217 on: December 29, 2013, 12:41:59 am »
https://mega.co.nz very fast and the same site as neamyalo used to host his dump: https://www.eevblog.com/forum/testgear/sniffing-the-rigol's-internal-i2c-bus/msg355266/#msg355266
And you can get the Avotronics who posted in this topic earlier today to host it on his Rigol hacking site: http://rigol.avotronics.co.uk
Offline Avotronics
    • Rigol Hacks
« Reply #2218 on: December 29, 2013, 01:17:51 am »
I'm on ipad now, but tomorrow I'll post them up on rigol.avotronics.co.uk just in case they get removed.
Lot of dumps today... I should lay off the eggs :-/
Offline AndersAnd
« Reply #2219 on: December 29, 2013, 01:20:07 am »
I blame all the christmas food  :-DD
Offline Avotronics
    • Rigol Hacks
« Reply #2220 on: December 29, 2013, 01:31:46 am »
true, combined with not knowing when to stop eating ;-)
Offline tirulerbach
« Reply #2221 on: December 29, 2013, 01:51:44 am »
I updated my DS2202A to latest firmware 00.02.01.00.03 and made a new dump (just after reboot from update):  :-DD
https://mega.co.nz/#!uUUBXJQC!U8smoyLwcdVIXXxy82DoGSy457oJDYQhZUIRccF9ZSU
Have Fun!  8)
Offline jkw13
« Reply #2222 on: December 29, 2013, 02:09:17 am »
I really apologize if this has been answered already in this thread, but I'm late to the game and pouring over 141 pages of posts is a bit daunting.  But are there firmware limitations on the use of Keygens on Rigol equipment (namely the DP832 and DS1074Z)?  For instance, do the keys not work with newer firmwares, and has anyone lost keygen activated features after upgrading the firmware on the equipment?
Well I have lost keygen feaures on DP832 after down/upgrade and ADC not working,
The output meters mean nothing now :scared:
« Last Edit: December 29, 2013, 02:17:12 am by jkw13 »
Offline nerdms
« Reply #2223 on: December 29, 2013, 07:20:38 am »
Hi, I have the DS2072 with HW version 2.0 and FW version 01_01_00_02.  I used the DSAZ to generate the key and everything seems to have gone fine (all options enabled) but I discovered that the vertical and horizontal position knobs are acting funny.  If I move the vertical knob in one direction then it always moves in that direction no matter which way I rotate the knob and the horizontal always moves in one direction.  I updated the FW to 02_01_00_03 thinking that would fix the issue but nope.  Pushing the knobs centers everything fine.  Has anyone encountered that?  Very weird.
Thanks.
Offline cybermaus
« Reply #2224 on: December 29, 2013, 09:58:40 am »
Hi guys
sorry if I missed it during search, but was any download location or change-list given for the latest DS1000Z (DS1074Z-S) firmware?
Also, if anyone wants to know, the DSAB Adv Trigger / DSAC Decoders / DSAE 24M Memory / DSAJ Recorder features work on the -S model without any apparent side effects.
Did not try the "DSFR All Options" though because it is described as "turns it into a DS1104Z".
I do not want it to turn into a DS1104Z ! Not without the -S !
I wonder if the 'unknown' feature is the signal generator. People without the hardware would not notice it active or missing. Except maybe for the grayed out tabs under the screen.
To be honest, for the stuff I do i do not really need the bandwidth (or any of the other features for that matter). Only two month ago I was still happy with my 20MHz analog.
