Author Topic: Magnova oscilloscope  (Read 100367 times)
Online joeqsmith
Re: Magnova oscilloscope
« Reply #375 on: September 12, 2024, 09:01:57 pm »
The 1 M input termination must be used with the supplied passive probes.
Reading the manual, is the above statement accurate?  Does the scope have proprietary 10x probes that must be used?   Other probes that would meet the required compensation are not supported?
After reading the manual, there are a few minor things that may need cleaned up but these could be from running the translator (see previous post for attached English translation).   For my purposes, this manual was good enough.
It's one thing to read how that UI works but I think I would just need to try and run it.   Having used a mechanical UI since my first Dumont oscilloscope, I can see really liking it or hating it.
The one thing I really see missing is a programmers manual.   I commonly will use test equipment as part of a larger test and am used to rolling custom software to automate them.  I would like to see this interface well documented.  I also would like to see metrics published on what sort of data transfer rates we could expect.
All in all,  it looks good and I am still very interested.   Get that thing certified for sale in the USA or just ship one of the prototypes and lets have a look.
« Last Edit: September 12, 2024, 09:21:17 pm by joeqsmith »
Online Martin72
  • Testfield Technician
« Reply #376 on: September 12, 2024, 09:11:53 pm »
Where did you find this, which page?
(Kierkegaard)
Online Martin72
« Reply #377 on: September 12, 2024, 09:25:11 pm »
I found it(page17).
It only says that you have to switch the input to 1M if you want to use the supplied probes.
Which makes sense, because they are designed for 1M.
(Kierkegaard)
Online egonotto
« Reply #378 on: September 12, 2024, 09:40:04 pm »
Hello,
there must be a few owners of a Magnova by now. It would be nice if one of them would write here.
Best regards
egonotto
Online egonotto
« Reply #379 on: September 12, 2024, 09:54:36 pm »
Hello,
Question for Batronix and Martin72:
@Batronix: Is it possible to operate the Magnova from remote via internet?
If so, you could connect an interesting signal to each input and give Martin72 access for a certain time.
@Martin72: Would you participate?
Best regards
egonotto
Offline ebastler
« Reply #380 on: September 12, 2024, 10:12:47 pm »
I'm not sure that would that do justice to a scope where the UI is one of the distinguishing features. You could not really experience the user interface with the large screen and the four flexible rotary encoders right next to it, acting as "soft knobs". And you could not experience screen update rates and smoothness (or lack thereof) when moving things around either.
These aspects don't matter that much if you are purely after an "analytical scope". But my feeling is that the Magnova -- while hopefully providing comprehensive and accurate measurements and analytics -- puts a lot of focus on interactive use and how that handles and feels.
Online joeqsmith
« Reply #381 on: September 12, 2024, 11:03:46 pm »
I found it(page17).
Note the quotation, this was copied from the Google translated manual verbatim.   So, are you suggesting that this is a problem with the translation and that the original language tells us something different?   This would make sense but I have no way of knowing, which is why I asked.
Online egonotto
« Reply #382 on: September 12, 2024, 11:26:17 pm »
Hello,
On page 17 under 4 it says: “Bei den mitgelieferten passiven Tastköpfen muss die 1 MΩ Eingangsterminierung verwendet werden”.
This means that if you use the supplied passive probes, than you must set the input to 1 MOhm.
It does not say that you have to use the supplied probes. So this is no different to most other scopes.
Best regards
egonotto
Online joeqsmith
« Reply #383 on: September 12, 2024, 11:44:13 pm »
Ok, so a Google translation problem.   Thanks as I was thinking this was going to be a deal breaker.   Imagine a scope that couldn't use standard 10X probes.... :-DD
Offline LoneWolf6912
« Reply #384 on: Yesterday at 05:27:00 am »
Sadly, I still didn't received the scope.
Offline DK3BH
« Reply #385 on: Yesterday at 05:38:20 am »
At least I can confirm: Its real and it works :)
I received my magnova scope yesterday.
The boottime is rather quick (~29 seconds) and the unit is well put together.
The display is indeed really crisp and the UI seems even more responsive than the UI of the Tektronix Series 5 we have at work.
Any suggestions what I should test first during the weekend?
Online Martin72
« Reply #386 on: Yesterday at 07:14:15 am »
Looks like a TV....
(Kierkegaard)
The following users thanked this post: egonotto, RAPo, moerm
Offline woody
« Reply #387 on: Yesterday at 08:06:38 am »
Looks like a TV....
Go wash your mouth!  ;D
The following users thanked this post: RAPo
Offline FloBX
« Reply #388 on: Yesterday at 01:22:31 pm »
The English-language manual is almost ready and will also be made available online in a few days.
Looking forward to reading it.
An English-language manual is now available at https://www.batronix.com/magnova/en/downloads or via the Magnova product pages.
We will need a few weeks before we can provide documentation of remote control features (Rest API/USBTMC/HiSLIP/Raw). We have just joined the LXI Consortium but do not yet have a certified product.
Looks like a TV....
I personally prefer applying some tilt to the screen. ;)
We are now looking forward to the first customer feedback. Thanks to DK3BH so far!
Best regards,
Florian
(Batronix)
The following users thanked this post: egonotto, joeqsmith, Andre77
Online nctnico
« Reply #389 on: Yesterday at 01:24:54 pm »
Looks like a TV....
Learn to recognise a compliment  :) If it looks like a TV, it has a very high WAF https://en.wikipedia.org/wiki/Wife_acceptance_factor
The following users thanked this post: egonotto, tooki, KungFuJosh, Martin72, FloBX
Offline woody
« Reply #390 on: Yesterday at 02:03:51 pm »
Looks like a TV....
But is that what you really want? Honey, that tiny TV set you left on your desk, that did not work. I tried it but only got static on all channels. As I was going into town anyway I dropped it at the recycling plant for you. Saves you a ride, no? >:D
Online egonotto
« Reply #391 on: Yesterday at 02:19:08 pm »
Hello,
have fun with the Magnova.
What bandwidth does your device have?
Did you buy a function generator with it?
Did you buy one or two logic probe sets?
How do you cope with the position of the BNC connectors on the right?
Best regards
egonotto
Online joeqsmith
« Reply #392 on: Yesterday at 04:29:00 pm »
Thank you for turning around that English manual so fast.   It is much better than the Google translated version.
For the software interface manual,  even if you just have a list of the basic commands and not the full documentation, I would like to see it.  Just to have some idea how to interface with it.
In the long term, do you plan to provide sample test software in various languages to get people started with writing their own custom software?
I notice your avoidance to respond to my question about availability to the USA.  If certification is the concern and you would like to have it tested, maybe we could help out.  Shoot me a PM if interested and we can talk about it.
Online Martin72
« Reply #393 on: Today at 06:17:03 am »
Well, I guess I will too, then.
(Kierkegaard)
