Resistors.
Minimum value - 0.1 mOhms.
First, it is necessary to perform a good zeroing of the readings with the tweezers probes closed. The upper part of the button from the old equipment was chosen as a device. The tips fit very tightly inside and provide a very reliable high-quality contact.
In this position, the tweezers were tested for 1 hour to understand what kind of drift it had. Within half an hour, the drift was 0.2 mOhms. At the end of the tests, it increased to 0.3 mOhms.
After a short break due to battery charging, I continued to study the drift of the tweezers in the milliohm range.
In the closed probe mode, the tweezers worked for 4 hours until the battery was completely discharged. Working for 3 hours with a green glow of the battery charge indicator, the drift did not change.And the most interesting thing is that with a red glow of the battery charge indicator, this drift remained at the same level until the battery was completely discharged.
In addition to studying the drift of the tweezers, my device for the zeroing mode of readings has proven its high reliability.
Resistor 1%.
