This can be measured relatively easy with a small DUT resistor, say 1 Ω.
There are different ways to check.
I got the result that interested me. To do this, I had to put my hands on it and work a little. These capabilities are embedded in these tweezers, you just have to try to implement them. Such measurements are not an end in themselves, but a way to check real parameters.
A lot of talk about the diode function.
Actually, we must not forget that the tweezers are a bridge LCR meter. The D function is additional. But it is not made like in multimeters. That is, it is not finished. FNIRSI should either finish it or remove it altogether. And instead of a diode, make a measurement of the DCR resistance. This is done in the MS8911.
And if possible, then do it like in the LCR Pro1 Plus.
In a short period of time, an analysis of the serviceability of the semiconductor junctions of the diodes and transistors is carried out for breakage, partial or complete breakdown.
After the analysis, we see the result on the display.
