Author Topic: Small/cheap programmable PSU?  (Read 2125 times)
Offline Per WestermarkTopic starter
« on: June 13, 2022, 03:14:42 pm »
Anyone know about some smaller and reasonably cheap programmable PSU suitable for automatic testing?
Most programmable laboratory PSU are normally quite big and bulky.
What I'm interested in is having 5-10 programmable PSU 0-30V and maybe 0-1A per channel and controllable using any of USB, RS-485, RS-232, Ethernet.
Either multiple small units or some PSU with maybe 2-4 channels or intended to stack together for arbitrary channel count.
Potentially also programmable voltage sources as low as 10-25 mA current capacity for driving stimuli to analogue inputs.
No need for lots of fancy displays capabilities.
The intention is just to be able to run automatic firmware testing, power save logic, analogue input processing etc for quite low-powerd equipment running supporting 9-30V operation and power consumption in the 1-10W range.
Filling the table with many 150-300 W laboratory PSU would be a big waste of space.
Offline MLXXXp
Re: Small/cheap programmable PSU?
« Reply #1 on: June 13, 2022, 04:15:23 pm »
If a switching supply is acceptable (considering output noise), something like this might work for you:
https://www.aliexpress.com/item/1000004279003.html
You would have to feed it with a high enough fixed DC voltage and sufficient current. You might be able to use a single supply to feed all the multiple modules you're looking to have. You  also might need a case or panel to mount them in. The company does sell cases for them.
I believe the control protocol is documented. I think third party "hacked" alternative firmware is also available.
The following users thanked this post: Bobson
« Reply #2 on: June 13, 2022, 04:32:23 pm »
Switched is definitely acceptable. It's only maybe 1-2 channels for testing analogue inputs that might have an advantage of less noise - but equipment for automotive use really can't put much depands on well-filtered input voltages.
I'll have to take a look if they looks reasonable - how to control them and any issues with isolation.
Offline MLXXXp
« Reply #3 on: June 13, 2022, 05:34:04 pm »
Some information on the control protocol:
https://sigrok.org/wiki/RDTech_DPS_series
Offline MLXXXp
« Reply #4 on: June 13, 2022, 06:15:56 pm »
Here the thread for Dave's review of a similar model,
https://www.eevblog.com/forum/blog/eevblog-1030-$20-diy-bench-power-supply!/
This post links to some fairly good info for communicating with the DPS3005.
https://www.eevblog.com/forum/blog/eevblog-1030-$20-diy-bench-power-supply!/msg1319709/#msg1319709
Offline Fungus
« Reply #5 on: June 13, 2022, 07:05:18 pm »
There's also these, which come in a finished box:
https://www.aliexpress.com/item/1005004242560393.html
« Reply #6 on: June 14, 2022, 06:26:23 am »
Seems like I should aquire one or two modules and check out. Either using the USB control board or potentially use the internal serial port directly.
They are significantly smaller than full-size laboratory power supplies.
And seems there are also buck/boost variants, in which case a PC PSU could deliver 12V to lots of modules.
Looks like I could have a vacation project.
Offline Fungus
« Reply #7 on: June 14, 2022, 07:24:01 am »
The USB port on the one I posted goes directly to a CH340 USB-to-serial chip.
Offline jeremy
« Reply #8 on: June 14, 2022, 08:09:43 am »
This would let you have 6 channels per unit with ethernet/USB:
https://www.envox.eu/eez-bb3/
https://www.envox.eu/dc-power-modules/dcm224-power-module/
No idea about stock levels though I'm afraid, I know that it uses the dreaded STM32s as the main MCU.
« Reply #9 on: June 14, 2022, 10:02:51 am »
OK. Because it seems some photos I saw have an external board that is either USB or BT which implies that these boards are connecting to maybe a 3V3 logic-level UART on the main module, in which case one ESP32 could be a WiFi bridge for two power modules.
« Reply #10 on: June 14, 2022, 10:07:18 am »
Seems the DCM224 would end up a wee bit low on voltage - 0-30V would be needed to do a decent job of looking like a 24V lead-acid battery in a vehicle.
But I'm bookmark it - I might have other tasks where this could be a good option.
