Author Topic: Searching for a modern Fluke 45: List of currently made dual display meters?  (Read 4117 times)
Offline cvancTopic starter
Hi all-
Tried some searching but came up empty - are there any dual display meters made these days?  (Like the old Fluke 45, able to show two parameters at the same time.)  I do a fair bit of power supply work and would love to simultaneously read AC & DC off one pair of test leads... thanks.
Offline BravoV
  • +++ ATH1
Fluke 287 / 289.
Offline PedroDaGr8
  • A sociable geek chemist
Multiple Brymen handhelds like the 867/869
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." -George Carlin
Offline HighVoltage
If it comes to benchtop instruments, look at the Agilent 34410A and the Agilent 34411A
Or the newer models from Keysight 34461A to 34470A
They all have dual display capabilities.
Offline forrestc
There are quite a few out there - unfortunately a lot of them read AC then read DC, then switch back to AC and repeat the cycle.  This wouldn't be bad, but a lot of them also use a Relay to do so...  with at the bare minimum will drive you nuts with the click click click click.   The fluke 45 apparently does this as well with some combinations.   See below, around 9:35.
My Rigol DM3058E does the same thing.
A while back I asked about models which actually did simultaneous AC+DC readings (https://www.eevblog.com/forum/testgear/bench-dmm-with-simultaneous-dcac-rms/) without relay clicking.   Someone recommended a HAMEG HMC8012.
There's a quick demo of the HAMEG HMC8012 simultaneous reading here:
And a longer review here:
I can't give you a real review of the HAMEG, but I can say that one is currently on order (finally, after over a year of delay) for my bench.  For power supply work, look at the screen in the review at around 8:10... Voltage, Current, AND calculated power.  Also look at the stats screen around 7:00.
As others have pointed out it's only a 5 3/4 digit, and the 1 year accuracy on some ranges isn't all that hot, but the readings should be far more accurate than I need for my work.
« Last Edit: September 10, 2015, 03:54:45 pm by forrestc »
Offline K5HJ
The BK Precision 2831E does.
We just picked one up for about $300 US.
Randy
Offline Paul Moir
TES PROVA 903 - this is a handheld model.
Offline commongrounder
Fluke 8845a, 8846a, Tektronix DMM4040, and DMM4050 have dual display functionality.  These are more accurate, more digits, than the 45, but I keep my old 45s on the bench with my DMM4050 and 4040, because they still do some things, like audio amplifier power measurement, more easily.
Offline 001
  • Country: aq
Sorry for necroposting
What about GW Instek GDM-8245 ?
