Author Topic: Tektronix TDS7104 scope hang on splash screen  (Read 1062 times)
Offline STDioTopic starter
  • Country: sg
« on: February 02, 2019, 09:54:05 am »
I did change the NVRAM battery and reconfigure the boot data using TTL to the MAX232 chip,
the acquisition board stops at the below terminal line..
Executing startup script c:\vxBoot\dio_rst.vsh ...
dbFsIoctl: invalid code 3
    ################### topScript starts ###############################
     cd "dbfs:c:/vxBoot"
value = 0 = 0x0
    ld < TekScope.o
value = 23662208 = 0x1690e80
    ld < TekScopeSM.o
value = 23661568 = 0x1690c00
    BoardIdOverride = 21.pDbDev = ramDevCreate(0, 512, 1152, 1152, 0)
BoardIdOverride = 0x1341f8c: value = 21 = 0x15
undefined symbol: pDbDev
Done executing startup script c:\vxBoot\dio_rst.vsh
KERNEL:  RUNNING TIME SLICED AT 10 TICKS PER SLICE!
Was wondering the HDD image wasn't modified yet the NVRAM doesn't let the image load...
« Last Edit: February 02, 2019, 07:42:02 pm by STDio »
Offline TiN
  • Country: ua
    • xDevs.com
Re: Tektronix TDS7104 scope hang on splash screen
« Reply #1 on: February 02, 2019, 01:49:13 pm »
You need to use c:\vxBoot\topScript.hw in standard config.
The following users thanked this post: STDio
  • Country: sg
« Reply #2 on: February 02, 2019, 08:30:30 pm »
Now I got a  ' -' on the LED dianostics after running the boot update file..
    #################### topScript starts ###############################
    #  This script is for standalone prototypes that want to update
    #   their bootROMs to the newest version in the
    #   scope's c:/vxBoot directory.
    sysFlashUpdate ("dbfs:c:/vxBoot/boot.bin")
sysFlashUpdate: TESTING: comparing region
sysFlashUpdate: Erasing flash...done
sysFlashUpdate: Writing flash sectors
s0@0xff800000................
s1@0xff810000................
s2@0xff820000................
s3@0xff830000................
s4@0xff840000................
s5@0xff850000................
s6@0xff860000................
s7@0xff870000................
sysFlashUpdate: SUCCESS: flash written
value = 0 = 0x0
    setLED 0x40
value = -65 = 0xffffffbf = ppp_parms + 0xffc4f02f
    # hopefully you get this message at the end:
    # sysFlashUpdate: SUCCESS: flash written
    # sysFlashUpdate: TESTING: comparing region
    # value = 0 = 0x0
Done executing startup script c:\vxBoot\topScript.vxw
