Increased the maximum Waveform Update Rate from 110,000
wfm/s to 140,000 wfm/s
Increased the maximum Waveform length from 28Mpts to
70Mpts (with an option key)
Optimized the effect of waveform display at big time base
Accelerated the Single/Stop/Sequence/History processing by
hardware
Optimized Date Preview to improve customer experience when
changing the horizontal and vertical settings
Eliminated the obvious displayed trigger jitter at some time base
Added Eres Mode under “Acquisition” and remove high resolution
mode
Optimized measurement algorithm on some vertical parameters
Added gating measurement
Added some parameters, such as stdev, delay
Cursors- Optimized the operating experience
Digital Channels -Optimized operating experience
Defects & Bugs-Fixed the defects/bugs which exist in firmware 1.0:
Known Issues
MSO MSO will not be fully supported until Oct. 2015.
Decoder CAN, LIN will not be supported in decoder until Oct. 2015
Power Analysis Power Analysis option is not fully verified. To be released in Dec. 2015[/u]
We hope more eevblogers test the firmware for us.
If you have any questions, do not hesitate to contact us
support@siglent.com
