3) playback in sequence mode does not seem to work
I have just tested (only tiny quick test)
Utility menu "History"
It can playback all captured segments, up to 80000 segment or other maximum depending other settings.
There is normal automatic playback (playback speed is not settable)
It can play forward and backward automatic and also by hand using adjust knob whole segment memory (max over 100MSa/channel).
In acquire - sequence menu function
It can display also up to max 80000 segments.
It can playback but some amount different.
It can select that it display single segment or 2-20 segments overlayed or as "waterfall". (using overlay or waterfall is more easy to find some anomalies in signal (default is 20 segment overlay/waterfall)) (1)
It can playback all these segments what user have selected as limits. Automatic playback is only forward and this Siglent need do better. If go once to forward to upper limit there is no reset or return backward. It can do only using adjust this mutifunction knob.
Also cursors can use in playback mode.
Also zoom in - out can use in playback (in history menu playback and acquire - sequence menu)
(full display zoom in/out using t/div knob, not splitted display zoom)
EDIT; (1) add
it need clarify.
It can sequentially playback whole max 80000 frames (segments) memory. In this mode user can select how many segments is one playback step.
If selected (max) 20 segments then playback show 20 segments (waterfall or overlay) and then in next step it show next 20 segments etc. This user can slect between 1 to 20. Same if use manual playback using knob for step forward or backward.
