I haven't read through all the pages, so forgive me if this has been posted before.
Has someone done a comparison, or can I compare similar numbers of the samples/sec vs time base etc between SDS2000 vs Agilent DSOX2000 and DSOX3000 series? Does the SDS2000 sit right between the two agilent series?
I have this from Siglent and no doubt there will be comments to its accuracy.
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
Main Data Comparison
SIGLENT SDS2000 series AGILENT 2000X series
Analog channel 2/4 ? 2/4 ?
MSO 8 integrated channels ? 8 integrated channels ?
Bandwidth 70MHz,100MHz,200MHz,300MHz ? 70MHz,100MHz,200MHz X
Max realtime sampling 2GSa/s ? 2GSa/s ?
Max storage depth 14M(single channel) 50K(single channel)
28M?half channel? ? 100K?half channel? X
Segmented Memory sequence function ? support ?
Waveform recording and
analysis history function ? None X
Power analysis support ? support ?
Max waveform refresh
rate 110000 ? 50000 X
Built-in function/
arbitrary wave generator
1uHz?25MHz Support arbitrary wave ? 0.1Hz?20MHz Support arbitrary wave X
Waveform operation Add, subtract, multiply, divide,
FFT, integral,Differential, square root,? Add, subtract, multiply, FFT X
Statistical
measurement Current value, average,
minimum,maximum,Standard deviation,
statistical times? None X
Automatic measurement
parameter 32 kinds ? 25 kinds X
Trigger mode
9 kinds?Edge, Pulse Width, 4 kinds?Edge, Pulse Width?
Video,Slope, Interval,Runt, Window, Pattern?Video X
Pattern, Dropout ?
Serial decoding/trigger
Support I2C, SPI, UART/RS232,CAN,LIN ? Support I2C, SPI, ?
Input impedance 1M?/50? ? 1M? X
Display sizes and
resolution 8 inches?800*480 ? 8.5 inches?800*480 ?
Display range 8*14 division ? 8*10 division X
Price Good price ? 8000~24000 RMB ?highprice? X
E&OE.
Edit
? = tick
Copy & paste did not copy ticks.
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
