Author Topic: Siglent's new product- MSO/SDS2000 Series  (Read 252248 times)
Offline Mark_O
Re: Siglent's new product- MSO/SDS2000 Series
« Reply #275 on: January 03, 2014, 05:25:50 pm »
I assume the 2 GSa/s sampling spec is for a single active channel, and with 2 channels enabled, it drops back to 1 GSa/s?
But what's the sampling rate with all 4 channels active?  I think I missed that, and it's not on the Spec sheet.
Offline echen1024
  • 15 yo Future EE
« Reply #276 on: January 03, 2014, 05:30:10 pm »
1GS/s probably for this caliber of scope. It probably uses 2 ADCs like the Agilents.
I'm not saying we should kill all stupid people. I'm just saying that we should remove all product safety labels and let natural selection do its work.
https://www.youtube.com/user/echen1024
Offline marmad
  • Country: aq
    • DaysAlive
« Reply #277 on: January 03, 2014, 05:43:28 pm »
Reported earlier in the thread: 1 ADC per two channels.
Offline rf-loop
« Reply #278 on: January 03, 2014, 06:00:14 pm »
2 channel models:
1 channel in use, max 2GSa/s
2 channel in use, both max 1GSa/s
4 channel models:
There is two groups of channels, (CH1+CH2) and (CH3+CH4)
If use what ever channel alone, max 2GSa/s
If use CH1 and CH2, max 1GSa/s both or CH3 and CH4 1GSa/s both.
If use (CH1 or CH2) and (CH3 or CH4)  both  channels have 2GSa/s
If use more than 2channels, what ever combination,  all used channels max is 1GSa/s
So, if use all 4 channels, all have max 1GSa/s simultaneously.
Offline Mark_O
« Reply #279 on: January 03, 2014, 06:11:38 pm »
Quote from: marmad
Thanks, Mark.  Do you memorize all this stuff?  :D  Or are you able to go back through 20 pages and find it again?
2 channel models:
4 channel models:
Thanks for all the details, rf-loop.  So in 4-chan mode, it's 4x faster than the DS1000Z.  And in 2-chan mode, the SDS2xx4 is twice as fast as the SDS2xx2.
Offline kebogen
  • User banned.
« Reply #280 on: January 04, 2014, 01:32:21 am »
[/quote]
[/quote]
I think rf-loop meant  CH1 and CH2 share one ADC,CH3 and CH4 share another ADC, that is to say, in 2-chan mode,only turn on CH1 and CH3(CH2 and CH4),the SDS2xx4 is twice as fast as the SDS2xx2. If turn on CH1 and CH2, the unit will only one ADC works. :scared:
Offline Mark_O
« Reply #281 on: January 04, 2014, 09:41:25 am »
Quote from: Mark_O
Right.  I understood that.  Sorry if my comments made things less clear.
I probably should have said, "in 2-chan mode, the SDS2xx4 can be twice as fast as the SDS2xx2."  I was simply trying to highlight the fact that the 4-channel version had a performance advantage that wasn't immediately obvious, at first glance.  (To me, anyway.)
Offline rf-loop
« Reply #282 on: January 04, 2014, 11:39:15 am »
Quote from: Mark_O
Yes, if buy 4 channel model but typically need 2 channel, it give 2GSa/s for both channels (range from 1ms/div to 1ns/div)
If buy 2 channel model and typically also use 2 channels it give 1GSa/s for both channels (range from 1ms/div to 1ns/div)
btw, in SDS2304 test thread there is something about freq response, and also about pass/fail mask test speed. (it is hardware based fast mask test, capable  up to ~110k waveforms pass/fail test per second). It looks like Siglent claim about HW based mask test is true if look its speed (?).
Now scope is disassembled for HW investigations so very limited possible to make any more tests. I want also try solve/test  what it means that window zoom function is HW based (Siglent claim).
Offline pascal_sweden
  • Country: no
« Reply #283 on: January 04, 2014, 03:32:38 pm »
It's a pity that their Logic Analyzer only supports 8 digital channels? Or do they have support for 16 digital channels on some models?
The Rigol entry model DS1102D did already support 16 digital channels, and so are the more advanced Rigol units like MSO4014.
So maybe a Rigol MSO4014 is better choice than Siglent SDS 2074?
How do they compare in features/pricing?
How is internal impedance on SDS2000 series? Is the internal capacitance taken out when you switch from 1M to 50 ohm like in the more expensive scopes? I read this is not the case on Rigol DS2074A.
Offline Mark_O
« Reply #284 on: January 04, 2014, 09:05:45 pm »
Why?  What do you need more than 8 for?  I'm genuinely curious if you have a real application in mind, or just want more for the sake of more?
Not that they've advertised yet.  Perhaps on the later SDS3000-series.
Even farther back than that.  The old DS1102CD model did as well.  I know, because I've owned one for 4 years.
...and so are the more advanced Rigol units like MSO4014.
That's correct.  And of course, more is always better.  No matter what.  I also have one LA with 32 channels, and another with 136 channels.  It's a pity these new MSOs have less.    :'(  ::)
It must be, if it has more LA channels.   :palm:  Pricing on the MSO version of the SDS2000 hasn't been announced yet, AFAIK.  But I suspect the Rigol you mentioned will cost perhaps around twice as much.
Still, obviously worth it for 8 more LA channels.    :-DD
Pretty much worthless without at least 16 digital channels.  I guess Agilent should probably shit-can their MSOX2000-series units, with only 8 digital channels.  And Hameg as well, their whole HMO Compact line, with only 8 LA channels.  I mean, what are these companies thinking?   :-//  Why build a more affordable product that covers >90% of the use-cases?
[/sarcasm]
Offline kebogen
  • User banned.
« Reply #285 on: January 05, 2014, 08:56:53 am »
Yes,8 digital channels will meet my needs,but the problem is that SDS2102 on alibaba doesn't  have the MSO fuction.
http://siglent.en.alibaba.com/product/1495430096-220476572/Siglent_SDS2102_DPO_Oscilloscope_digital_oscilloscope_100MHz_2_channels.html
If I buy it now,how to get the MSO fuction later? Just pay some money or need to sent back to the store,maybe back to SIGLENT shenzhen? :'( :'(
« Reply #286 on: January 05, 2014, 09:18:17 am »
Originally MSO was to be an option but now it seems it will be a different product so an upgrade to MSO will not be possible.
We all wait for more information.
Offline rf-loop
« Reply #287 on: January 05, 2014, 09:43:04 am »
Yes.
(but on the main board there is all or nearly all ready for it.... without components... )
Offline echen1024
  • 15 yo Future EE
« Reply #288 on: January 05, 2014, 05:54:44 pm »
I think they have seen what has happened to Rigol products, and are now scared. Next they will require us to send the unit back to the factory for firmware update  :scared:
Offline z01z
« Reply #289 on: January 05, 2014, 09:08:10 pm »
Yes.
Have you taken pictures from the front side of the PCB? I suppose the missing components must be there because on the back side only the ch3&4 stuff is missing.
Offline kebogen
  • User banned.
« Reply #290 on: January 06, 2014, 01:00:12 am »
Thanks very much,tautech, I just misunderstood by the title
:-// :-//,that is to say,only SDS2000 series.
Offline rf-loop
« Reply #291 on: January 06, 2014, 07:44:11 am »
[/quote]
What ch3 and 4 missing? I have preliminary version of SDS2304.
Yes, I have lot of pictures but I need carefully look what are public and what not. Unit what I have is _preliminary_ demo version of SDS2304 made late November 2013.
(This is not unit what have sold to end users in domestic markets in China)
Offline kebogen
  • User banned.
« Reply #292 on: January 07, 2014, 12:37:20 am »
What happened to Rigol products? ;D
Offline echen1024
  • 15 yo Future EE
« Reply #293 on: January 07, 2014, 01:18:59 am »
Well, you see, they can be "upgraded" to improve the price/performance ratio  ;D
Offline kebogen
  • User banned.
« Reply #294 on: January 07, 2014, 09:35:51 am »
Aha?I think SIGLENT will not do that, I haven't  found anything about MSO2000 on www.siglent.com/en
Maybe Herman got the wrong imformation >:D
But thanks very much,Herman, SDS2000 is a great scope,I just want one.
Offline z01z
« Reply #295 on: January 07, 2014, 01:14:53 pm »
I've meant the picture on page 3, apparently posted by Herman.
Offline Farrari
« Reply #296 on: January 10, 2014, 12:43:40 am »
Yeah, as you I know, now SIGLENT only have SDSxxxx series,MSO is an option. :box:
Offline z01z
« Reply #297 on: January 10, 2014, 01:56:34 pm »
Has anyone noticed that on the siglent.eu page the 200 and 300MHz versions are in stock?
Who's brave enough? ;)
Offline marmad
  • Country: aq
    • DaysAlive
« Reply #298 on: January 10, 2014, 02:08:31 pm »
You mean who's got enough spare cash laying around to lend it interest-free for awhile? ;D
Offline z01z
« Reply #299 on: January 10, 2014, 02:15:19 pm »
Well, you can call that bravery I guess :).
