Dave has been offered a Siglent to review,
Well, as long as you get one review
I will however try to answer any queries about the GUI and UI that may arise.
Does the DSO have user-selectable memory depths - or does it automatically select memory size all of the time?
If the DSO does have user-selectable memory depths, what are the sizes?
If the DSO does have user-selectable memory depths, could you take 5 minutes and measure the waveform update rates with each of the user-selectable memory depths at 1ms/div?
For example (using the DS2000):
14kPts 140kPts 1.4MPts 14MPts 56MPts Memory Depth
1ms/div 70 56 52 29 15 wfrm/s
How exactly does the DSO capture and display segments?
100kHz input CH1. Trig out to HP53131A
CH1 on
Dots, sin(x)/x off, trigger normal, holdoff off
1ms/div
Memory 7k, 14k, 70k, 140k, 700k, 1,4M, 7M, 28M (setting 14M)
samplerate 500k, 1M, 5M, 10M, 50M, 100M, 500M, 2G
Trig out with all these around 67.5 to 67.9 / second
Display 14 div, whole capture allways 14div (not capturing out of screen)
(If stop and zoom in, always get full resolution related to sampling speed and memory lenght - of course)
