According to the datasheet, Siglent is using digital trigger...
According to Rigol, the DS2000 uses a digital trigger as well - it's just not advertised in the datasheet as a feature.
R&S did spend lot of money to advertise their digital trigger, but Rigol forgot to incude SUCH feature into datasheet?
Not even in DS4000 or DS6000 datasheet?
Seriously, they must have the worst marketing dep. in our and all parallel universes.
As i don't give a shit about marketing papers, let's check facts:
- there is 16bit DAC on the Rigol PCB
- there are buffers and ref mux
- FPGA LVDS input can be easily used as fast speed comparator, so no need to use an extra parts.
- LMH6518 aux output is routed somewhere (usually this signal will be used for triggering), i guess to FPGA
What i don't know:
- is the DAC / mux out routed as well to FPGA?
- what the FPGA design is really doing
So i can't say for sure how the triggering has been implementd. But the fact that Rigol is using two signal paths (and this is one of the reason why there is tigger jitter visible) is reason enought to
NOT call, whatever they really implemented, this an
digital trigger because one of the major points and benefits of digital triggering is single signal path.
Anyway, i'm sure, in case Siglent did used two paths as well, Rigol will then update their datasheets
I don't mind, for me is sufficient to have protocol trigger and decoders (and yes, i know how great digital trigger is), but that's me, other will have other requirements.
