Hi rf-loop.
In DS2000 data sheet there read: Realtime Waveform Record,Replay & Analysis (Up to 65,000 frames)
I can not find segmented memory capturing.
What is this "record" function?
Edit/add: How this "record" works related to example what HP and later Agilent use when they name it segmented.
Yes, the 'Record' function on the Rigol is the segmented memory function - and, from what I understand, it works more or less the same as the Agilent. Although I don't know if the lower-end Agilent's have the nice segment analysis function (with histograms
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
) built-in.
Why did Rigol decide to call it 'Record'? I don't know: perhaps because they thought it would be more easy to 'sell it' as a feature - or perhaps because they had a similar feature on their older models called that - or maybe because the terminology is patented by HP (Agilent)? In any case, as Mark_O pointed out, it's not well-described in their literature.
Do it wait trig between these segments or just new frame after this time interval?
If it wait trigger why there is time interval setting?
Yes - the 'recording' of the segment (or frame, as Rigol calls it) is caused by your trigger settings. But of course, the fastest that the DSO can capture segments is always limited by the maximum wfrm/s rate. Since the DS2000 has a maximum rate of ~50k wfrm/s, it's minimum time between segments will never be shorter than ~20us + the minimum time interval setting (100ns); i.e. the re-arm time.
But you can use the time interval setting to force a wait between segment captures - so if you wanted, for example, to test the stability of a repeating signal over 24 hours, you can set the number of segments to 65000, then set the time interval to 1.33 seconds - then run the analysis tool on the captured segments the next day.
Do you know if the new SDS2000 series will have some kind of segment/record feature? It's strange that they don't mention anything of it (or the History function) in the datasheet.
