At this point it is obvious that you didn't come here for help but for something else..
Yes, he came here to entertain us!
You bet ....
Look, fellas .... I get it, 'k ....
Some y'all sellin' these Sigs fer a livin', and bad publicity ain't good fer biz. So let every issue be some sort of "OPERATOR ERROR". Use that 'scuse till the POS is outta warranty.
And there are the band-name fanboys. Hey, I know what you mean. I love my Fluke and Tek more than anyone.
And then there are service techs and engineers that have been using the questionable model ... and will defend it to the hilt .... 'cause they don't wanna face the possibility that they mighta UNKNOWINGLY screwed the pooch on upteen service calls or projects ... cuz the gremlin was something called Siglent ... havin' the last laugh.
And the dream goes on .... ![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
Like I said, you can live in a dream world and just keep saying other people are guilty for you being uneducated and rude.
But, all in all, it is ultimately up to you to decide to put in work and make yourself better: more knowledgeable and less rude and obnoxious.
You demonstrated staggering amount of inability to use a device you have and to learn how to use it properly. That by itself is not a problem. But your refusal to try and fix that shortcoming is.
Maybe there is something funny with the scope. We don't know. You worked hard against all of us so we could not prove it either way. You worked hard to just keep it at level of accusations and uncertainty and doubt. I'm not dumb, scope is !
By what you were able to demonstrate, scope you have is fully functional and nothing is broken. You simply don't know how to use it and refuse to follow simple troubleshooting procedures that are meant to prove that scope is functioning properly.
Honestly, all things break sometimes. We
tried to help you prove it is broken so you can verify if you have the problem. We couldn't find anything wrong (well, nothing wrong with the scope, anyways).
It is you that came here with an agenda to prove that scope is broken and POS because you simply cannot be wrong, as perfect as you are... Other people just tried to help you, which they mostly regret now..
I will repeat. Scope seems to be fine. Read the manual. Learn how to use it. Enjoy new found knowledge and skills..
