Hi Siglent Support,
I have an SDS 2074 and installed the latest firmware. I have a question regarding roll mode. Will zoom function be enabled in future firmware releases? Today it pops up a message "Function isn't useable"
I thought it was possible to adjust the scale and effectively zoom in this way, but the waveform is not zoomed in on the center of the screen. So if you have an event you want to zoom in on, you can move horizontal position to find it. But once you adjust the scale, the event disappears and you are effectively zooming in on a different area. So this is not an effective equivalent of zoom function.
On a side note, I believe others in the forum were interested in knowing if peak detect in roll mode was supported, and it appears to be supported in latest firmware (FYI to forum members).
Thanks,
Don
