I found yet another bug on the SDS1202X-E.
1. Feed a sine wave into channel B, Vmin = 600mV, Vmax = 27V
2. Press Auto Setup
3. Turn the vertical adjustment knob twice to the right, so the scale is at 1 Volt per division (note that the purple zero indicator is below the bottom of the wave)
4. And now, turn the vertical position up. Now it is perfectly possible to move the zero indicator to far above bottom of the wave! This is clearly a bug.
Note that if the vertical scale is changed to 2 Volts per division instead of 1 Volt per division, the vertical adjustment works as expected.
Also note that a sine wave on channel A, Vmin = 800mV, Vmax = 10.2V does not show this bug.
Also note that after step 2 on each subsequent turn of the vertical scale knob Vmin gets another value.
Koen
Software Version 5.1.3.8
FPGA version: 2017-03-21
Hardware version: 00-01
Product Type: SDS1202X-E
Serial No:
Scope ID:
