I have this unit that was returned to the factory for startup failures, now no more start issues, but the voltage measurements are wrong, shows 70% of actual voltage. DC and AC are same, I tried with different probes, I made several calibrations but it's still the same.
SDS1104x-e, upgrade to 1204 on factory when repair startup failure.
Software version 8.1.6.26. with the last firmware 6.1.33 the measurement voltage is wrong, same value 70%
FPGA version 2018-07-26
Hadware version 01-04
Thanks in advance for yours comments.
