Hello!
I am trying to measure Source-Drain voltage drop in switching DC-DC converter with Siglent SDS1072CML:
![](http://img.radiokot.ru/files/47221/thumbnail/7cj3n3hot.png)
Source-Gate voltage drops down to -13V to open MOSFET fully:
![](http://img.radiokot.ru/files/47221/thumbnail/7cj7hg357.png)
I have a 750mA load connected.
Peak current across Drain-Source is about 1A ( measured on Rx resistor):
![](http://img.radiokot.ru/files/47221/thumbnail/7cj8dz270.png)
![](http://img.radiokot.ru/files/47221/thumbnail/7cj9r4y4t.png)
The Drain-source image looks like this:
![](http://img.radiokot.ru/files/47221/thumbnail/7cjbk8v75.png)
The voltage drop across open MOSFET is 900mV! The accuracy of oscilloscope is 0.2 * V/div, so there is +-100mV error range.
According to datasheet, voltage drop can not be more then 500mV:
![](http://img.radiokot.ru/files/47221/thumbnail/7cjf22sz1.png)
And if calculated from RdsOn=0 .14Ohm, it should be about 140mV, which is far from 900mV displayed.
The strange behaviour of oscilloscope is that increasing V/div drifts Vmax and it eventually goes above zero to 1V with 10V/div!
I can accept it with 10V/div because error is 0.2 * V/div = 0.2*10 = 2V, but with 500 mV/div readings should be close to reality, otherwise it is impossible to find out whether I am correctly driving MOSFET.
I have latest firmware. I've been trying switching probe ( and oscilloscope settings ) to 1x/10x without improvement.
I took my old USB oscilloscope from the shelf, and it shows Drain-Source voltage drop <300mV and does not have that strange zero drift with V/div encrease:
![](http://img.radiokot.ru/files/47221/thumbnail/7ga8etzgb.gif)
How could I correctly measure Drain-Source drop with my Siglent?
