Siglent released a new firmware version
Version SVA1000X Firmware_V3.2.2.6.2R5 (Release Date 06.28.24 ).
21 MB
https://int.siglent.com/upload_file/zip/firmware/Spectrum_analyzer/SVA1000X_V3.2.2.6.2R5_EN.zipRelease notes
Notice:
This firmware must be upgraded from V3.2.2.4.0 or later. If your analyzer has an earlier version, please update to V3.2.2.4.0 first and then proceed to update to the latest version.
1. New Functionality:
Add Picture Viewer
Add Open Source Acknowledge
Add Remote Control Mode, when entering, the interface displays system time, limit status, system messages, etc., shielding UI refresh. SCPI: DISPlay:WINDow:ENABle ON|OFF
Save the configuration every 60 seconds, and load it when Power On is turned Last
SA/VNA mode Limit Setup adds Fail to Save, which automatically saves screenshot and trace data when the Limit Test result is Fail. It can only be used when Fail to Stop is turned ON
2. Improvements:
Preset optimization: When pressing the Preset button, it will first jump to the Preset menu instead of directly performing Preset; Touch Assist's Preset adds preset option
Optimization System Info display content
When taking screenshots, do not capture the message indicating successful screenshot
Limit the length of numbers entered on the screen and keypad
Add SCPI commands to read system messages:SYSTem:MESSage?
Added screenshot function under the Help window
Set the FFT menu to invalid when the SA mode cannot select FFT
SA mode can open the Freq Counter for markers other than marker 1
The SA mode peak table displays the peak of the current trace
The SA mode peak table displays the peak of the current trace, rather than the current marker’s trace
The dBc parameter range of the SA mode OBW is changed to negative numbers
When Noise Marker is turned on in SA mode, set Detect Type to Average
In SA/MA/EMI mode, Wait for Trigger is displayed only if Trigger is not triggered for 2 seconds.
Add Display Line in SA/VNA/DTF/MA/EMI mode
When using markers in SA/VNA/DTF/MA/EMI modes, display the marker info enlarged in the upper left corner of the screen
SA/EMI mode display more information of limit fail and pass
Return more marker information when using SCPI command :CALCulate#:MARKer#:Y? in SA mode
The MA mode supports the SCPI command: TRACe#[:DATA]? to get trace data
SCPI command for setting marker X in MA mode: TRACe#:MARKer#:X supports specifying time units
3. Solved Issues:
Fix the problem of the inconsistency between the numerical accuracy displayed in SA mode Freq menu Ref Offset and the status bar on the left
Fix the problem of Marker display unit error when Noise Marker is turned on in SA mode
Fix the problem of the SCPI command TRACe#:MODE in the SA mode setting trace type, which causes a crash when the selected trace exceeds the range.
Fix the problem of not adding Freq Offset to the marker x value in SA mode
Fix the problem of Correction errors when switching between X-Scale Lin and Log in SA mode
Fix the problem of inconsistent units and settings for values obtained by SCPI commands :DISPlay:WINDow:TRACe:Y:RLEVel? in SA/EMI mode
Fix the problen where Sweep Time may be incorrect when set EqLPF to Auto in MA mode
