Hi Steve,
Everything you have experienced is absolutely identical to my experience.
There are several folk going out of their way to be helpful and it is not for me to question them about whether they are using genuine SVA1032X or not but so far I am not aware of anyone with a cross flashed SVA1032X that is saying theirs works normally with respect to the 1-Port Cal routine. i.e. those who are confident that their way of using the machine gives a proper result are all using genuine SVA1032X and so replicating their advice is not fixing the problem.
I've played around with this quite a bit now and my interpretation of events is that the one port cal is buggy in my cross flashed SVA. There is no combination of button pressing will get you the little "Cor" label after a one port CAL. It is necessary to follow it with an Open CAL or a Short CAL in order to do so. These latter two will of course provide you with the "Cor" label regardless of whether you did the 1 Port first. They should be superfluous with regard to a 1 port cal since the one port cal includes these CALs anyway.
The good news is that having done a 1 port CAL the machine does indeed seem to be calibrated, even though it doesn't say so. Before a 1 port CAL with a short but fairly dodgy piece of coax attached to the port the Smith Chart seems to be all over the place with the 50 ohm load. Afterwards, you get a nice dot in the centre of the chart with the same 50 ohm load.
As long as you don't change the Frequency Span or any Amplitude settings the calibration seems to function well.
There are some obvious conclusions - one is that if you are serious about using the VNA for anything other than hobby educational purposes then you really need to buy the genuine article to feel confident. The other is that until someone steps forward with a cross flashed SVA1032X to say that theirs works ok, it is clear that the behaviour of Cross Flashed SVAs is different to that of natural born ones (easy test - do a 1-port CAL, if the "Cor" label comes up at the end then it is behaving itself, if only -- or OFF comes up at the end of the CAL routine then it is behaving like the badly behaved cross flashed unit that Steve and I have been describing.).
Thanks everyone, for your contributions
Regards
Eloso
