Upgrade log part 2
[ 2.057098] UBI-3: ubi_attach_mtd_dev:available PEBs: 0, total reserved PEBs: 80, PEBs reserved for bad PEB handling: 9
[ 2.067882] UBI-3: ubi_thread:background thread "ubi_bgt3d" started, PID 590
[ 2.070055] UBI-0: ubi_attach_mtd_dev:attaching mtd8 to ubi0
[ 2.470806] UBI-0: scan_all:scanning is finished
[ 2.483096] UBI-0: ubi_attach_mtd_dev:attached mtd8 (name "datafs", size 100 MiB)
[ 2.490537] UBI-0: ubi_attach_mtd_dev:PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 2.499140] UBI-0: ubi_attach_mtd_dev:min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 2.507666] UBI-0: ubi_attach_mtd_dev:VID header offset: 2048 (aligned 2048), data offset: 4096
[ 2.516372] UBI-0: ubi_attach_mtd_dev:good PEBs: 800, bad PEBs: 0, corrupted PEBs: 0
[ 2.524109] UBI-0: ubi_attach_mtd_dev:user volume: 1, internal volumes: 1, max. volumes count: 128
[ 2.533060] UBI-0: ubi_attach_mtd_dev:max/mean erase counter: 13/7, WL threshold: 4096, image sequence number: 626955013
[ 2.543946] UBI-0: ubi_attach_mtd_dev:available PEBs: 0, total reserved PEBs: 800, PEBs reserved for bad PEB handling: 40
[ 2.554922] UBI-0: ubi_thread:background thread "ubi_bgt0d" started, PID 594
[ 2.574878] UBIFS: background thread "ubifs_bgt1_0" started, PID 597
[ 2.606420] UBIFS: recovery needed
[ 2.746423] UBIFS: recovery completed
[ 2.750095] UBIFS: mounted UBI device 1, volume 0, name "siglent"
[ 2.756147] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 2.765267] UBIFS: FS size: 34410496 bytes (32 MiB, 271 LEBs), journal size 4952064 bytes (4 MiB, 39 LEBs)
[ 2.774927] UBIFS: reserved for root: 0 bytes (0 KiB)
[ 2.779960] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 0327D069-3DA9-4070-95A1-3E1D117AABDE, small LPT model
[ 2.824779] UBIFS: recovery needed
[ 2.868505] UBIFS: recovery deferred
[ 2.872087] UBIFS: mounted UBI device 2, volume 0, name "firm0", R/O mode
[ 2.878830] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 2.887957] UBIFS: FS size: 7237632 bytes (6 MiB, 57 LEBs), journal size 1650688 bytes (1 MiB, 13 LEBs)
[ 2.897346] UBIFS: reserved for root: 0 bytes (0 KiB)
[ 2.902385] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 68D1D634-0B41-44C3-8EE7-5B148BE8F0D7, small LPT model
[ 2.916088] UBIFS: background thread "ubifs_bgt3_0" started, PID 600
[ 2.947719] UBIFS: recovery needed
[ 2.970471] UBIFS: recovery completed
[ 2.974165] UBIFS: mounted UBI device 3, volume 0, name "log"
[ 2.979839] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 2.988991] UBIFS: FS size: 7237632 bytes (6 MiB, 57 LEBs), journal size 1650688 bytes (1 MiB, 13 LEBs)
[ 2.998380] UBIFS: reserved for root: 0 bytes (0 KiB)
[ 3.003430] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 35E3C92F-68EC-461E-A46E-9F549FBFB3F1, small LPT model
[ 3.016864] UBIFS: background thread "ubifs_bgt0_0" started, PID 602
[ 3.048336] UBIFS: recovery needed
[ 3.125471] UBIFS: recovery completed
[ 3.129147] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[ 3.135109] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 3.144233] UBIFS: FS size: 94597120 bytes (90 MiB, 745 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
[ 3.153883] UBIFS: reserved for root: 0 bytes (0 KiB)
[ 3.158923] UBIFS: media format: w4/r0 (latest is w4/r0), UUID AB78C81C-0D18-4506-91AE-D6D46AF0DBD0, small LPT model
[ 5.601129] Unhandled fault: external abort on non-linefetch (0x818) at 0x36f1c380
Bus error
[ 5.628773] irq = 170
[ 5.640179] <<-GTP-INFO->> GTP driver installing...
[ 5.645226] <<-GTP-INFO->> GTP Driver Version: V2.4<2014/11/28>
[ 5.651076] <<-GTP-INFO->> GTP Driver Built@22:06:06, Apr 27 2018
[ 5.657201] <<-GTP-INFO->> GTP I2C Address: 0x14
[ 5.661800] 0-0014 supply vdd_ana not found, using dummy regulator
[ 5.668136] 0-0014 supply vcc_i2c not found, using dummy regulator
[ 5.674307] <<-GTP-INFO->> Guitar reset
[ 5.803831] <<-GTP-INFO->> IC Version: 928_1060
[ 5.814504] <<-GTP-INFO->> X_MAX: 1024, Y_MAX: 600, TRIGGER: 0x00
[ 5.833351] <<-GTP-INFO->> create proc entry gt9xx_config success
[ 5.839632] input: goodix-ts as /devices/virtual/input/input0
[ 5.845620] <<-GTP-INFO->> GTP works in interrupt mode.
[ 5.861240] gpib_usb_init
[ 5.864015] usbcore: registered new interface driver usb-gpib
startup_app.sh start++++++++++
rm -f /usr/bin/siglent/usr/*.ADS
upgrade_app1: starting
-rpf /usr/bin/siglent/usr/usr/upgrade/app/* /usr/bin/siglent/
upgrade_app1: ending
/usr/bin/siglent/usr/backup/upgrade_app1.sh
rm /usr/bin/siglent/usr/backup/upgrade_app1.sh -rf
rm /usr/bin/siglent/usr/usr/upgrade/* -[ 10.470122] UBIFS: background thread "ubifs_bgt1_0" stops
rf
startup_app.sh end++++++++++
[ 11.580464] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 11.592180] ehci-pci: EHCI PCI platform driver
[ 11.634512] e0002000.usb supply vbus not found, using dummy regulator
[ 11.641398] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 11.646505] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 11.673372] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 11.678901] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 11.685713] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 11.692896] usb usb1: Product: EHCI Host Controller
[ 11.697778] usb usb1: Manufacturer: Linux 3.19.2-omg-xilinx-svn35686 ehci_hcd
[ 11.704917] usb usb1: SerialNumber: ci_hdrc.0
[ 11.710067] hub 1-0:1.0: USB hub found
[ 11.713832] hub 1-0:1.0: 1 port detected
[ 11.719484] e0003000.usb supply vbus not found, using dummy regulator
[ 11.782258] usbcore: registered new interface driver usb-storage
[ 11.813185] usbcore: registered new interface driver usbhid
[ 11.818839] usbhid: USB HID core driver
[ 11.828922] mousedev: PS/2 mouse device common for all mice
[ 12.033456] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[ 12.040055] macb e000b000.ethernet eth0: link up (100/Full)
[ 12.209127] usb 1-1: New USB device found, idVendor=154b, idProduct=00ee
[ 12.215816] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 12.222927] usb 1-1: Product: USB 2.0 FD
[ 12.226843] usb 1-1: Manufacturer: PNY
[ 12.230558] usb 1-1: SerialNumber: No!
[ 12.236388] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 12.245830] scsi host0: usb-storage 1-1:1.0
[ 13.247158] random: Aladdin urandom read with 21 bits of entropy available
log init finished
[ 13.407710] spidev spi1.1: setup: unsupported mode bits 50
set_output_level ===============10.000000
[ 13.509200] UBIFS: completing deferred recovery
[ 13.538289] UBIFS: deferred recovery completed
[ 13.543169] UBIFS: background thread "ubifs_bgt2_0" started, PID 773
route: SIOCDELRT: No such process
system cmd error!WEXITSTATUS(result) = 1
route del default: Success
[ 13.600205] UBIFS: background thread "ubifs_bgt2_0" stops
[ 13.624381] UBIFS: background thread "ubifs_bgt2_0" started, PID 785
[ 13.667743] UBIFS: background thread "ubifs_bgt2_0" stops
[ 13.682381] UBIFS: background thread "ubifs_bgt2_0" started, PID 795
[ 13.700014] UBIFS: background thread "ubifs_bgt2_0" stops
[ 13.715190] UBIFS: background thread "ubifs_bgt2_0" started, PID 800
[ 14.143379] UBIFS: background thread "ubifs_bgt2_0" stops
[ 14.159201] UBIFS: background thread "ubifs_bgt2_0" started, PID 812
[ 14.178515] UBIFS: background thread "ubifs_bgt2_0" stops
[ 14.194933] UBIFS: background thread "ubifs_bgt2_0" started, PID 817
[ 14.219471] UBIFS: background thread "ubifs_bgt2_0" stops
[ 14.241242] UBIFS: background thread "ubifs_bgt2_0" started, PID 822
[ 14.261210] UBIFS: background thread "ubifs_bgt2_0" stops
[ 14.648871] <<-GTP-INFO->> System resume.
[ 14.648882] gpio-963 (GTP INT IRQ): _gpiod_direction_output_raw: tried to set a GPIO tied to an IRQ as output
[ 14.663516] <<-GTP-INFO->> GTP wakeup sleep.
[ 14.663525] gpio-963 (GTP INT IRQ): _gpiod_direction_output_raw: tried to set a GPIO tied to an IRQ as output
[ 14.852156] UBIFS: background thread "ubifs_bgt2_0" started, PID 827
[ 14.886746] UBIFS: background thread "ubifs_bgt2_0" stops
[ 14.921098] UBIFS: background thread "ubifs_bgt2_0" started, PID 832
[ 14.936315] UBIFS: background thread "ubifs_bgt2_0" stops
rotationAngle: 0 invertx: false inverty: false
[ 15.455346] scsi 0:0:0:0: Direct-Access PNY USB 2.0 FD PMAP PQ: 0 ANSI: 6
[ 15.464911] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 15.470572] sd 0:0:0:0: [sda] 30294016 512-byte logical blocks: (15.5 GB/14.4 GiB)
[ 15.480642] sd 0:0:0:0: [sda] Write Protect is off
[ 15.487130] sd 0:0:0:0: [sda] No Caching mode page found
[ 15.492371] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 15.510395] sda: sda1
insert~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
[ 15.521404] sd 0:0:0:0: [sda] Attached SCSI removable disk
devName ==sda
devName ==sda1
sda1
sleep time == 0
[ 15.548167] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
/usr/bin/siglent/usr/tmp/sda1_U-disk0
device:IVISoftwareModuleName:: node error!device:ManufacturerDescription:: node error!found the dir = /usr/bin/siglent/usr/mass_storage/U-disk0
[ 17.045293] UBIFS: background thread "ubifs_bgt2_0" started, PID 857
[ 17.070323] UBIFS: background thread "ubifs_bgt2_0" stops
0x00000000
0x00000000
Initializing framebuffer device /dev/fb0...
xres=1024, yres=600, xre[ 21.994683] input: PolyVision Touch Screen as /devices/virtual/input/input1
sv=1024, yresv=600, xoffs=0, yoffs=0, bpp=16
Initializing touch device /dev/input/event0 ...
Reading From :(goodix-ts)
buttonMask: xmin:0
xmax: 1024
ymin:0
ymax: 600
Initializing VNC server:
width: 1024
height: 600
bpp: 16
port: 5900
Initializing server...
25/01/2021 02:29:06 Listening for VNC connections on TCP port 5900
rcS Complete
(none) login:
usbtmc_para = insmod /usr/bin/siglent/drivers/g_usbtmc.ko idVendor=0xf4ec idProduct=0x1301 iManufacturer=Siglent iProduct=SVA1032X iSerialNum=No!
insmod: can't insert '/usr/bin/siglent/drivers/libcomposite.ko': File exists
insmod: can't read '/usr/bin/siglent/drivers/udc-xilinx.ko': No such file or directory
insmod /usr/bin/siglent/drivers/libcomposite.ko;insmod /usr/bin/siglent/drivers/udc-xilinx.ko;: No such file or directory
[ 30.526827] ######################### usb_gadget_probe_driver 3f09d738 ##################
[ 30.535106] usbtmc_bind+++
[ 30.539994] SIGLENT_DEV: SIGLENT_DEV, version: 2007 OCT 06
[ 30.546478] usbtmc_open()++
[ 30.549212] dev->usbtmc_cdev_open ret = 0
[ 30.553232] ret = 0
[ 30.555355] usbtmc_open--
[ 30.558067] show_send_buffer_size = 61440
