Author Topic: Siglent SVA1015X and SVA1032X 1.5, 3.2GHz Spectrum & Vector Network Analyzers  (Read 249214 times)
Offline tubularnut
File sizes, and (last line of) script, and filesystem sizes look correct.
NB. The filesystem list does not show memory usage, just filesystem sizes. The ecomb app is not a filesystem.
Can you do the following, this will tell you for sure if Aladdin is running.
  ps -ef | grep Aladdin
  689 root       6:00 /usr/bin/siglent/Aladdin    <<----- Important one!
  901 root       0.00 grep Aladdin
If you don't see it, then Aladdin hasn't started.
« Last Edit: December 30, 2020, 04:12:10 pm by tubularnut »
The following users thanked this post: Kibabalu
Offline tv84
  • Country: pt
My wild guess:
When you do an upgrade from the USB stick, the .ADS occupies disk space in the USB disk. Then it decompresses to the filesystem upgrade dir.
When you do and upgrade via web, you must download the .ADS to the filesystem spending precious space. When it decompresses, it consumes further space...
I wonder if it is really possible to do any upgrade via web on the current SSAX+ and/or SVAs...  :-//
Try to see if you any content in the filesystem's upgrade directory and delete all that content. I would assume it should start at the next reboot...
Nonetheless, I don't fully grasp what this problem could be.
Offline Kibabalu
Hi tuburlanut,
yes ist runs:
  956 root       0:00 grep Aladdin
Offline Kibabalu
My wild guess:
Hi tv84,
where should the upgrade directory be located?
under /usr/bin/siglent/usr/usr?
it's empty
Offline tubularnut
Hi tuburlanut,
yes ist runs:
Actually it’s not running, that is just the grep command itself. There should be another line for /usr/bin/siglent/Aladdin.
So for some reason it is not starting.
As tv84 says, try removing the upgrade contents.
Edit: Apologies. I left out the 'grep' process from the ps output for clarity (or so I thought) but have added it back in to my post.
« Last Edit: December 30, 2020, 04:13:31 pm by tubularnut »
Offline Kibabalu
when I start Aladdin manually, I'm seeing this :
/usr/bin/siglent/usr/tmp # init log error[File /usr/bin/siglent/usr/tmp/config/log/log4cpp.properties does not exist]
log init finished
[ 7414.066490] spidev spi1.1: setup: unsupported mode bits f8
mac ioctl error
Udisk = U-disk0  not found notes
the u-disk sum = -1 is error
 remove udisk /usr/bin/siglent/usr/mass_storage/U-disk0
not erase the udisk = U-disk0
[ 7414.154089] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
        挂载U盘 /usr/bin/siglent/usr/mass_storage/U-disk0    device = /dev/sda1
udhcpc: started, v1.26.0.git
Setting IP address 0.0.0.0 on eth0
sh: write error: Device or resource busy
udhcpc: sending discover
terminate called after throwing an instance of 'std::bad_alloc'
  what():  std::bad_alloc
mod_if_exit_handler:signal=6
Clean Up Ready!
Clean Up - dev_thread
Clean Up - dev_interpreter
Clean Up - SCPI
Clean Up - USBTMC
Clean Up - VXI_11
Clean Up - telnet_scpi
Clean Up - socket
Clean Up - GPIB
Clean Up - nsp adapter
Clean Up Over!
udhcpc: sending select for 192.168.42.76
[ 7414.253652] <<-GTP-INFO->> System resume.
[ 7414.253664] gpio-963 (GTP INT IRQ): _gpiod_direction_output_raw: tried to set a GPIO tied to an IRQ as output
[ 7414.273275] <<-GTP-INFO->> GTP wakeup sleep.
[ 7414.273285] gpio-963 (GTP INT IRQ): _gpiod_direction_output_raw: tried to set a GPIO tied to an IRQ as output
udhcpc: lease of 192.168.42.76 obtained, lease time 864000
Setting IP address 192.168.42.76 on eth0
Deleting routers
route: SIOCDELRT: No such process
Adding router 192.168.42.1
Recreating /usr/bin/siglent/usr/etc/resolv.conf
 Adding DNS server 192.168.42.1
Offline tv84
  • Country: pt
Do like this:
chmod -R 777 /usr/bin/siglent/usr/usr/upgrade/*
sync
mount -o sync,rw,remount /usr/bin/siglent/
sync
rm  /usr/bin/siglent/usr/usr/upgrade/*.zip
rm  /usr/bin/siglent/usr/usr/upgrade/*.ADS
rm  /usr/bin/siglent/usr/*.zip
rm  /usr/bin/siglent/usr/*.ADS
sync
I extracted this from the start of the upgrade.sh (initial script run in an .ADS update).
Offline Kibabalu
the folder /usr/bin/siglent/usr/usr/upgrade/ isn't existing. Maybe, that's the problem?
I can create it, but than it is still empty. Should the .ADS file be located there?
« Last Edit: December 30, 2020, 04:30:27 pm by Kibabalu »
Offline tubularnut
I wonder if something wasn't copied across during the upgrade because of space filling up. Which you won't see now as any temporary files may have been removed when rebooted.
I would suggest running the upgrade (again) from a USB drive, but I have no idea how to do that from the internal serial port. @tv84 ??
Offline tv84
  • Country: pt
Don't worry with the things that don't exist.
Ensure that you have those *.ADS and *.zip deleted.
The best is to do it via the app. Let him do the deletes and see where that goes.
« Last Edit: December 30, 2020, 04:37:33 pm by tv84 »
Offline Kibabalu
There is no upgrade folder, thus there's nothing to delete.
A search for ADS-files gave just files on the USB stick:
/usr/bin/siglent # find / -name "*.ADS"
/usr/bin/siglent/usr/mass_storage/U-disk0/SVA1032X_V3.2.2.3.2.ADS
/usr/bin/siglent/usr/mass_storage/U-disk0/SVA1032X_backup.ADS
/usr/bin/siglent/usr/mass_storage/U-disk0/SVA1032X_V2.2.1.2.8.ADS
/usr/bin/siglent/usr/mass_storage/U-disk0/._SVA1032X_V2.2.1.2.8.ADS
/usr/bin/siglent/usr/mass_storage/U-disk0/SSA3000X_Plus_telnet.ADS
/usr/bin/siglent/usr/mass_storage/U-disk0/._SSA3000X_Plus_telnet.ADS
/usr/bin/siglent/usr/mass_storage/U-disk0/SVA1032X_telnet.ADS
/usr/bin/siglent/usr/mass_storage/U-disk0/._SVA1032X_telnet.ADS
/usr/bin/siglent/usr/mass_storage/U-disk0/._SVA1032X_backup.ADS
/usr/bin/siglent/usr/mass_storage/U-disk0/SVA1032X_V3.2.2.3.3R1.ADS
No zip-files at all.
Offline Kibabalu
what's about an upgrade from USB disk initiated from the terminal, like tuburlanut said? Is that possible?
What's usually inside the upgrade folder?
Offline Kibabalu
I manually startet Aladdin. Now it's inside the process list:
 1022 root       0:15 /usr/bin/siglent/Aladdin
 1095 root       0:00 grep Aladdin
But there the device still stucks inside the siglent boot screen.
Offline tubularnut
I believe you have access to the internal serial port?
If you capture the output from that, as a normal boot, without the USB drive plugged in, then someone may be able to spot why Aladdin is not starting on normal boot. (Attach as a text file will be best)
Offline Bicurico
  • Country: pt
    • VMA's Satellite Blog
The upgrade should be in folder /usr/bin/siglent/usr/usr/upgrade/.
Here you should see:
Folder: add
Folder: app
Folder: drivers
Folder: plat
Folder: sys
Folder: vnc
upgrade.sh
upgrade_add.sh
upgrade_app.sh
upgrade_drivers.sh
upgrade_plat.sh
upgrade_sys.sh
upgrade_vnc.sh
I suspect that what happend to your device was:
1) You tried to do the web upgrade
2) This downloaded the upgrade to attached USB disk
3) After extraction of files and first reboot you removed USB disk (?)
4) Upgrade was not correctly finished, because USB drive was not present
There is no official way to upgrade manually from USB, as all shell scripts would be pointing to wrong folders.
If you want to try, I can send you the contents of the upgrade folder.
I am not so sure about disk space, which is why it is always best to run the update from within Aladdin.
Anyway, you would have to:
1) mount the /usr/bin/siglent folder as rw:
2) copy the files and folders (of the archive) to /usr/bin/siglent/usr/usr/upgrade/
3) sync
4) cd /usr/bin/siglent/usr/usr/upgrade/
5) ./upgrade.sh
Send me your email per PM.
Regards,
Vitor
Offline tv84
  • Country: pt
Here is the zip with the .ADS contents.
I suggest you do the following:
mount -o sync,rw,remount /usr/bin/siglent/firmdata0
sync
Unzip the .ZIP into:
Sync.
Then manually launch:
/usr/bin/siglent/usr/usr/upgrade/upgrade.sh
Offline Kibabalu
Hi tuburlanut,
see the attached file.
Offline tubularnut
A number of errors are reported for Aladdin, which is either itself corrupted, or the underlying filesystem is corrupted.
% grep corrupted iTerm2\ Session\ 30.\ Dec\ 2020\ at\ 6_04_21\ PM.txt
[    1.748128] UBI-1: ubi_attach_mtd_dev:good PEBs: 288, bad PEBs: 0, corrupted PEBs: 0
[    1.888495] UBI-2: ubi_attach_mtd_dev:good PEBs: 80, bad PEBs: 0, corrupted PEBs: 0
[    2.034812] UBI-3: ubi_attach_mtd_dev:good PEBs: 80, bad PEBs: 0, corrupted PEBs: 0
[    2.520557] UBI-0: ubi_attach_mtd_dev:good PEBs: 800, bad PEBs: 0, corrupted PEBs: 0
*** glibc detected *** /usr/bin/siglent/Aladdin: free(): corrupted unsorted chunks: 0x*** glibc detected *** 00ed0a80/usr/bin/siglent/Aladdin ***
: free(): corrupted unsorted chunks: 0x00ed08d8 ***
*** glibc detected *** /usr/bin/siglent/Aladdin: free(): corrupted unsorted chunks: 0x00fa7ce8 ***
*** glibc detected *** /usr/bin/siglent/Aladdin: free(): corrupted unsorted chunks: 0x00ed0730 ***
*** glibc detected *** /usr/bin/siglent/Aladdin: free(): corrupted unsorted chunks: 0x00ed0588 ***
/usr/bin/siglent/Aladdin: free(): corrupted unsorted chunks: 0x00ed0338 ***
*** glibc detected *** /usr/bin/siglent/Aladdin: free(): corrupted unsorted chunks: 0x00ed01d0 ***
*** glibc detected *** /usr/bin/siglent/Aladdin: free(): corrupted unsorted chunks: 0x00ed0028 ***
*** glibc detected *** /usr/bin/siglent/Aladdin: free(): corrupted unsorted chunks: 0x00ecfe80 ***
*** glibc detected *** /usr/bin/siglent/Aladdin: free(): corrupted unsorted chunks: 0x00ecfcd8 ***
*** glibc detected *** /usr/bin/siglent/Aladdin: free(): corrupted unsorted chunks: 0x00ecf920 ***
*** glibc detected *** /usr/bin/siglent/Aladdin: free(): corrupted unsorted chunks: 0x00ecf6f8 ***
359b2000-359b6000 r-xp 000030/12/2020 15:49:14 /lib/libc.so.6(+0x*** glibc detected *** 636e8/usr/bin/siglent/Aladdin): [0xfree(): corrupted unsorted chunks35a226e8: 0x]
*** glibc detected *** /usr/bin/siglent/Aladdin: free(): corrupted unsorted chunks: 0x00ecf458 ***
*** glibc detected *** /usr/bin/siglent/Aladdin: free(): corrupted unsorted chunks: 0x/lib/libc.so.600ecf360/lib/libc.so.6((exitgsignal+0x+0x143c))[0x[0x359f1270359ebfc8]
[    1.748054] UBI-1: ubi_attach_mtd_dev:good PEBs: 288, bad PEBs: 0, corrupted PEBs: 0
[    1.888402] UBI-2: ubi_attach_mtd_dev:good PEBs: 80, bad PEBs: 0, corrupted PEBs: 0
[    2.034702] UBI-3: ubi_attach_mtd_dev:good PEBs: 80, bad PEBs: 0, corrupted PEBs: 0
[    2.520337] UBI-0: ubi_attach_mtd_dev:good PEBs: 800, bad PEBs: 0, corrupted PEBs: 0
*** glibc detected *** /usr/bin/siglent/Aladdin: corrupted double-linked list: 0x00ef2188 ***
[    1.748233] UBI-1: ubi_attach_mtd_dev:good PEBs: 288, bad PEBs: 0, corrupted PEBs: 0
[    1.888603] UBI-2: ubi_attach_mtd_dev:good PEBs: 80, bad PEBs: 0, corrupted PEBs: 0
[    2.028302] UBI-3: ubi_attach_mtd_dev:good PEBs: 80, bad PEBs: 0, corrupted PEBs: 0
[    2.514028] UBI-0: ubi_attach_mtd_dev:good PEBs: 800, bad PEBs: 0, corrupted PEBs: 0
« Last Edit: December 30, 2020, 05:31:46 pm by tubularnut »
Offline Kibabalu
sync
Sync.
It's a little bit embarrassing, but I'm struggling with copying files from my machine to the device using a terminal emulation. What is the best way to do it? Is there something like scp for UART?
« Last Edit: December 30, 2020, 05:41:34 pm by Kibabalu »
Offline tubularnut
Put the files on your USB disk, plug it in, and you should see the USB path as you found earlier:
Offline Kibabalu
 you are right
Offline Bicurico
  • Country: pt
Copy the files to USB, insert USB and reboot SSA.
1) Copy files from ZIP to an "upgrade" folder in the root of USB
2) Connect via telnet/serial and you should find the files on /usr/bin/siglent/usr/mass-storage/U-disk0
3) Do the mount and sync commands
4) Use cp -r upgrade /usr/bin/siglent/usr/usr to copy the upgrade folder on USB
5) sync
6) run upgrade.sh as explained before
Offline Kibabalu
tuburlanut, tv84 and Bicurio,
Thanks a lot to you.
It's booting now.
If you are ever in Stuttgart, don't hesitate to contact me. I'll try to give you a little bit back from the joy I'm feeling in this moment!
The following users thanked this post: tubularnut
Offline tubularnut
Excellent  :D
Nice work chaps.  :clap:
 :phew:
