Author Topic: Hack of Sigllent spectrum analyzer ssa3021X?  (Read 444118 times)
Offline OP-SEC
Re: Hack of Sigllent spectrum analyzer ssa3021X?
« Reply #1225 on: June 16, 2024, 02:18:49 pm »
So, I now have a SVA1032X.  Happy Fathers Day to me!
And after some experimentation, it seems that I have no use for my return loss bridge now.  Oh well... It sure is pretty.
Thanks to everyone for the assistance.
Offline waverunner62
« Reply #1226 on: June 24, 2024, 02:59:32 pm »
hi All and thanks for this great forum
i am a proud owner of a Siglent SSA3021X
i wish i could do this hack to go to the 3.2Ghz mark, and to permanently keep all my options, but before i have few things to ask
i have read multiple times all the post of this forum concerning this but there are so many, and it not easy for me to clarify alone.
here are the data of my SSA:
Version:
  SW1 1.3.9.7
  SW2 20201230-1
  SW3 000000FA
  HW  00.03.00
Options:
  EMI Sta: ON   Valid: with residual time
  AMK Sta: ON   Valid: with residual time
  TG Sta: ON   Valid: Permanent
  Refl Sta: ON   Valid: with residual time
i tried to telnet on few ports  seen on this thread and nothing work, ping is ok
as i cant find very much post  on this firmware version 1.3.9.7 hacked here are my questions:
i think i should unlock permanently the options before doing the mod, is that right?
i think i will have to install telnet_xxxx.ADS to get the telnet access, what it the last version of this file? and where can i safely download it?
on the reply #866 i use as basis for my mod  i should downsload this:
https://www.eevblog.com/forum/testgear/siglent-ssa3000x-spectrum-analyzers/?action=dlattach;attach=269048
i get this reply when i click the link:
"You are not allowed to access this section"
maybe because i am a beginner on this forum? does somebody can tell me what to do to get access?
with those things i maybe go forward. i apologize,my questions may seem stupid but i don't want to break this baby
i am doing step by step and i want to be sure to do it well, if i follow your help i am sure i can do it
my English is not also very good but i try to do my best without google
all your help is very welcome
by advance many thanks
Eric
Offline ozkarah
  • Country: tr
« Reply #1227 on: June 24, 2024, 03:55:03 pm »
I have SSA3021X Plus. You don't need a telnet connection to convert it to SSA3032X Plus.
Running a python script on the web link and load the option keys generated is enough.
I think it is the same with SSA3021X (non Plus version). If it is correct:
1- Go to this web page: https://www.online-python.com/PX3v0J8nbs
2- Edit the script with your own HOSTID (@System Info screen)
3- Uncomment the line: Model = 'SSA3000X_Plus' in the script
4- Run the script
5- Load the "ALL" option key using the screen keyboard of the SA.
6- If ALL does not work load the portion keys needed one by one.
Then you will have an SSA3032X/SSA3032X Plus
Telnet is necessary only if :
1- You want to take backup of your system files in the device
2- You want to convert it to SVA1032X
« Last Edit: June 24, 2024, 03:58:47 pm by ozkarah »
The following users thanked this post: waverunner62
Offline 807
« Reply #1228 on: June 24, 2024, 09:57:10 pm »
@waverunner62 If you get invalid licence for Refl, then change Refl for CAT in the "otheropt =" line in the python script.
Also, as you have the non-plus model, you need to uncomment the line:-
Model = 'SSA3000X'
btw...I also get the same error message when following that link in your post. The hack has moved on since that post you quoted (almost 4 years old). It's much simpler now, as ozkarah has pointed out.
« Last Edit: June 24, 2024, 10:10:47 pm by 807 »
« Reply #1229 on: June 25, 2024, 01:15:10 pm »
you OZKARA and 807,  thank you so much  :-+ :-+
i have to thank too BitByBit and TV84 for that wonderful script, unbelievable !!
all worked at the first try
i had to change Refl for CAT to get that option and it worked too
now i get my SSA3032X thanks to you
only thing is i can't get the AMK option unlocked
i tryed many time the key, verified again and again my typping but no ways to get it working
any idea for that is welcome
i will search if there is a trick like CAT for te reflection option
anyways you cant know how happy i am, no telnet, no hard things to do... it was so easy
THANKS
Eric
The following users thanked this post: 807, ozkarah
Offline hfleming
  • Country: no
« Reply #1230 on: June 25, 2024, 02:24:03 pm »
The options I have enabled on my SSA3000X is
TG
EMI
Meas
CAT
Offline 807
« Reply #1231 on: June 25, 2024, 03:05:34 pm »
...only thing is i can't get the AMK option unlocked
i will search if there is a trick like CAT for te reflection option...
You could try adding Meas to the otheropt = line. Or replace AMK with Meas & use that key to see if it unlocks AMK, as hfleming has done.
« Reply #1232 on: June 25, 2024, 03:15:17 pm »
hi all
as hfleming told me his options, and 807 confirmed, i search the key for Meas.
and.. perfect it works
thank u too hfleming and 807 again
everything is unlock now
now, i don't need to for now, but i think i can safely upgrade the firmware with that mod keys installed since the firmware as not been modified, true?
thanks to all of you for this help, you are great
Eric
« Last Edit: June 25, 2024, 03:17:09 pm by waverunner62 »
Offline 807
« Reply #1233 on: June 25, 2024, 03:22:24 pm »
I upgraded the firmware on my "Plus" model after the hack with no problems.  :-+
Offline hfleming
  • Country: no
« Reply #1234 on: June 26, 2024, 10:52:01 am »
Yeah, I have upgraded my SSA3000X (non Plus) to the latest firmware version 1.3.9.10 without any problems.
Offline retronexus
« Reply #1235 on: July 11, 2024, 10:15:16 am »
Hi all,
where would I find the latest description, on how I get the SSA3021 upgraded to the SVA version? I see bits of information around it, but is there a starting point I should look for?
Thanks
Offline hfleming
  • Country: no
« Reply #1236 on: July 11, 2024, 11:39:35 am »
Ssa3021+ or ssa3021 (non-plus). The non-plus can only be unlocked to give you higher bandwidth and all the options. The plus can be further upgraded.
Offline retronexus
« Reply #1237 on: July 12, 2024, 08:30:50 am »
Yea, I am aiming to get the SSA3021X Plus, but I cannot find a complete description of how to apply the SVA firmeware cross platform. Where would I find that?
Offline Bicurico
  • Country: pt
    • VMA's Satellite Blog
« Reply #1238 on: July 12, 2024, 10:00:48 am »
You can't find the description because all new users that want to do the cross flash will ask for instructions, do it and disappear again.
Few are willing to contribute some time with compiling the lastest instructions.
Even less are willing to spend some time searching them...
Read this post and the following ones:
https://www.eevblog.com/forum/testgear/hack-of-sigllent-spectrum-analyzer-ssa3021x/msg5528557/#msg5528557
Once you get everything up and running, write a better guide and publish it!
The following users thanked this post: Performa01, ironcurtain, coromonadalix, Martin72, mawyatt, ozkarah
Offline retronexus
« Reply #1239 on: July 12, 2024, 07:43:55 pm »
In my defense, I was searching, but there was a lot of very scattered info sometimes very contradicting.
I appreciate the help! And yes... i should write a guide then
Offline Dreikor
« Reply #1240 on: August 02, 2024, 12:09:55 am »
I am wondering if anyone has successfully updated the firmware of a cross modded unit.
I have a SSA 3021x Plus that is running SVA 1032X firmware version 3.2.2.4.0r2. I would like to update this to fix bugs that I am running into.
Would I need to revert this back with my backup files or can I just upgrade it with SVA firmware? My concern is that my S/N is showing as XXXXXXXXXXXX. Thanks
Offline demute
« Reply #1241 on: August 02, 2024, 06:22:53 am »
For those of you who have an SSA3032X-R, here's how to upgrade it to a SSA3075X-R with all options enabled.
It's really dead simple, the only thing you have to do is to rename a file from nsp_data_b1 to nsp_data_b1x and suddenly it's a 7.5 GHz model.
Quick howto:
Step 1 (optional backup):
Backup files. Read other posts in this thread on how to do it.
Step 2 (optional fw update):
Update FW. Just download the latest FW from Siglent and follow the instructions. This may not be necessary but perhaps nice anyway.
At the time of writing, the latest FW was SSA3000X-R_Firmware_V3.2.2.6.2R5 (Release Date 06.28.24 )
Step 3 (optional backup):
Step 4 (get a shell):
Go to 'System' -> 'Interface' and read off the IP address, then telnet into port 5024:
telnet 192.168.0.123 5024
Type the command DEBTTT and press enter. You won't get any reply but this starts a telnet daemon on port 23.
Exit the current telnet shell (killall telnet) and telnet again to the device but now by using the default port:
Login credentials are root/ding1234
/usr/bin/siglent #
Step 5 (rename file):
Make the file system writable, rename the file and reboot:
/usr/bin/siglent # mount -o remount,rw firmdata0
/usr/bin/siglent # cd firmdata0
/usr/bin/siglent/firmdata0 # mv nsp_data_b1 nsp_data_b1x
/usr/bin/siglent/firmdata0 # sync
/usr/bin/siglent/firmdata0 # reboot
Step 6 (verify):
Go to 'System' -> 'System Info' and you should now see your Model being "SSA3075X-R" and serial being "XXXXXXXXXX" with all options enabled.
Step 7 (enjoy):
:popcorn: :bullshit: :-DMM
« Last Edit: August 02, 2024, 06:35:17 am by demute »
Offline Bicurico
  • Country: pt
« Reply #1242 on: August 02, 2024, 09:32:59 am »
Why do it like this when you can just generate a regular activation key, with no risk attached?
Offline tv84
  • Country: pt
« Reply #1243 on: August 02, 2024, 09:51:56 am »
As Confucius would say “Life is simple, but we insist on making it complicated.”
« Reply #1244 on: August 02, 2024, 10:21:46 am »
This, and a big this ^^^
With a BW license, it will be received and activated or not without any risk.
Offline pagrei
« Reply #1245 on: August 02, 2024, 11:42:15 pm »
Apologies in advance, as I originally posted this request in https://www.eevblog.com/forum/testgear/siglent-sva1015x-1-5ghz-spectrum-vector-network-analyzer-(coming)/msg5591935/#msg5591935
I'm in the process of trying to recover the lost factory cal on an SVA1032X.  My plan is to obtain a quality SOLT kit, characterise it on a lab grade VNA, then cal the SVA1032X.
Based on a strings dump of Aladdin, I believe that the factory cal files reside in:
/usr/bin/siglent/usr/config/usr_vna_o_calib_log.bin
/usr/bin/siglent/usr/config/usr_vna_s_calib_log.bin
/usr/bin/siglent/usr/config/usr_vna_calib_log.bin
/usr/bin/siglent/usr/config/usr_vna_ref_log.bin
/usr/bin/siglent/usr/config/enh_rsp_calib_log.bin
/usr/bin/siglent/usr/config/usr_vna_e_calib_log.bin
/usr/bin/siglent/usr/config/usr_vna_e_ref_log.bin
/usr/bin/siglent/usr/config/usr_vna_o_calib.bin
/usr/bin/siglent/usr/config/usr_vna_s_calib.bin
/usr/bin/siglent/usr/config/usr_vna_calib.bin
/usr/bin/siglent/usr/config/usr_vna_ref.bin
/usr/bin/siglent/usr/config/enh_rsp_calib.bin
/usr/bin/siglent/usr/config/usr_vna_e_calib.bin
/usr/bin/siglent/usr/config/usr_vna_e_ref.bin
As I don't have access to the original cal, I don't know what the internal format of the cal files is, or the parameters used to generate said cal files (Number of points, Start Freq, Stop Freq, etc)
Access to copies of the above will help my journey of discovery.   ;D
« Last Edit: August 03, 2024, 12:41:23 am by pagrei »
