Hi, could someone please post a hint how to connect to the device and how to add the two missing calibration files, thanks.
SSA3021X+ already crossflashed to SVA, current FW is 3.2.2.3.3R1.
C:\>ftp 192.168.1.151
Verbindung mit 192.168.1.151 wurde hergestellt.
220 (vsFTPd 2.3.4)
Benutzer (192.168.1.151:(none)): ftp
230 Login successful.
ftp> ls
200 PORT command successful. Consider using PASV.
150 Here comes the directory listing.
SMA.cal
lna.csv
226 Directory send OK.
FTP: 27 Bytes empfangen in 0,03Sekunden 0,82KB/s
ftp> ls -l
-rw-r--r-- 1 ftp ftp 132925 Sep 05 2020 SMA.cal
-rwxr-xr-x 1 ftp ftp 81544 Sep 06 2020 lna.csv
FTP: 195 Bytes empfangen in 0,02Sekunden 10,83KB/s
ftp>
directory is /local/ as seen in the instruments File menu. Files are old user data.
how to proceed? WinSCP does not connect. Thanks....
