Author Topic: Siglent SVA1015X and SVA1032X 1.5, 3.2GHz Spectrum & Vector Network Analyzers  (Read 243129 times)
0 Members and 17 Guests are viewing this topic.
Online tv84
  • Country: pt
One of the things they change is the bootloader (uboot).
Hence as tautech said: "This version can not be rolled back"
Maybe we'll see the full impact in the next episodes.  ;)
PS: Maybe this is the right time to get yourselves a full NAND backup... BEFORE doing this update.
**********  Zynq-7000 SoC Boot Header  **********
00000000 -            ARM Vector Table: 8 x EAFFFFFE
00000020 -             Width Detection: AA995566
00000024 -            Header Signature: XLNX
00000028 -                  Key Source: 00000000  -  Not Encrypted
0000002C -                     Version: 01010000  (0x01010000)
00000030 -           FSBL Image Offset: 00001700
00000034 -           FSBL Image Length: 00014010
00000038 -     FSBL Load Address (RAM): 00000000
0000003C -     FSBL Exec Address (RAM): 00000000
00000040 -           Total FSBL Length: 00014010
00000044 -          QSPI Configuration: 00000001  (0x00000001)
00000048 -        Boot Header Checksum: FC16C520  CHKSUM OK
0000004C -                User Defined: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
00000098 -   Image Header Table Offset: 000008C0
0000009C - Partit. Header Table Offset: 00000C80
**********  Zynq-7000 SoC Device Register Initialization Table  **********
000000A0 - Register Initialization Pairs  [000000A0-0000089F]
**********  Zynq-7000 SoC Device Image Header Table  **********
000008C0 -                     Version: 01020000  (0x01020000)
000008C4 -             # Image Headers: 00000003
000008C8 - 1st Partition Header Offset: 00000C80
000008CC -     1st Image Header Offset: 00000900
000008D0 -   Header Auth Certif Offset: 00000000
000008D4 -                    Reserved: FFFFFFFF
**********  Zynq-7000 SoC Device Image Headers  **********
           Partitio Reserved  Length  Name
00000900 - 00000C80 00000000 00000001 fsbl.elf
00000940 - 00000CC0 00000000 00000001 fpga_top_sva3000x.bit
00000980 - 00000D00 00000000 00000001 u-boot.elf
**********  Zynq-7000 SoC Device Partition Headers  **********
           EncryLen UnencLen TotalLen DestLoad DestExec ImgOffst AttrBits Sections Checksm  ImHdOffs AuthOffs HdChkSum
00000C80 - 00014010 00014010 00014010 00000000 00000000 00001700 00000010 00000001 00000000 00000900 00000000 FFFF07E2   CHKSUM OK
00000CC0 - 003DBB00 003DBB00 003DBB00 00000000 00000000 00080000 00000020 00000001 00000000 00000940 00000000 FFCFB14E   CHKSUM OK
00000D00 - 0006E860 0006E860 0006E860 04000000 04000000 00580000 00000010 00000001 00000000 00000980 00000000 F7E4CF46   CHKSUM OK
Maybe it's nothing important... (haven't checked)
« Last Edit: January 22, 2021, 11:05:22 am by tv84 »
Online Bicurico
  • Country: pt
    • VMA's Satellite Blog
At least it seems safe regarding the ecomb and ecomb_p names.
It should correctly upgrade no matter if the main executable is called ecomb, ecomb_p or Aladdin.
But indeed it will ugrade uImage, somthing that did not happen in any of the known/available FW releases.
Online tv84
  • Country: pt
uImage is the same as an old SVA1015X version.
What is definitely different from previous is the boot.bin. But can be because of the FPGA...
Online Bicurico
  • Country: pt
You are of course right.
But note that uboot.bin has already been updated by previous FW release SVA1032X_V3.2.2.3.3R1, too. So this is not the first time, but the second time this happens (at least on the FW releases I have access to),
The version in SVA1032X_V3.2.2.4.0_EN is different, though.
Regards,
Vitor
Offline Elasia
Down the rabbit hole we go.. lets see what happens!
Offline Elasia
Hmmmm  :-//
Since updating to V3.2.2.4.0, I can't use the old telnet ADS files to get back in and re-enable telnet in the startup script? This worked fine on the last update to R1.
Have they removed / moved the telnet binary?
telnet working normal here.. no changes to busybox / link locations
Upgrade log
7777777777777777777777777
Archive:  /usr/bin/siglent/usr/usr/upgrade/config.zip
   creating: add/
   creating: add/help/
   creating: add/help/sva1000x/
   creating: add/help/sva1000x/cn/
  inflating: add/help/sva1000x/cn/image001.png
  inflating: add/help/sva1000x/cn/image002.png
  inflating: add/help/sva1000x/cn/image003.png
  inflating: add/help/sva1000x/cn/image004.png
  inflating: add/help/sva1000x/cn/image005.jpg
  inflating: add/help/sva1000x/cn/image006.jpg
  inflating: add/help/sva1000x/cn/image007.jpg
  inflating: add/help/sva1000x/cn/image008.jpg
  inflating: add/help/sva1000x/cn/image009.png
  inflating: add/help/sva1000x/cn/image010.png
  inflating: add/help/sva1000x/cn/image011.png
  inflating: add/help/sva1000x/cn/image012.png
  inflating: add/help/sva1000x/cn/image013.png
  inflating: add/help/sva1000x/cn/image014.png
  inflating: add/help/sva1000x/cn/image015.jpg
  inflating: add/help/sva1000x/cn/image016.png
  inflating: add/help/sva1000x/cn/image017.jpg
  inflating: add/help/sva1000x/cn/image018.png
  inflating: add/help/sva1000x/cn/image019.png
  inflating: add/help/sva1000x/cn/image020.jpg
  inflating: add/help/sva1000x/cn/image021.jpg
  inflating: add/help/sva1000x/cn/image022.png
  inflating: add/help/sva1000x/cn/image023.png
  inflating: add/help/sva1000x/cn/image024.png
  inflating: add/help/sva1000x/cn/image025.png
  inflating: add/help/sva1000x/cn/image026.jpg
  inflating: add/help/sva1000x/cn/image027.jpg
  inflating: add/help/sva1000x/cn/image028.jpg
  inflating: add/help/sva1000x/cn/image029.jpg
  inflating: add/help/sva1000x/cn/image030.jpg
  inflating: add/help/sva1000x/cn/image031.jpg
  inflating: add/help/sva1000x/cn/image032.jpg
  inflating: add/help/sva1000x/cn/image033.png
  inflating: add/help/sva1000x/cn/image034.jpg
  inflating: add/help/sva1000x/cn/image035.png
  inflating: add/help/sva1000x/cn/image036.png
  inflating: add/help/sva1000x/cn/image037.png
  inflating: add/help/sva1000x/cn/image038.jpg
  inflating: add/help/sva1000x/cn/image039.jpg
  inflating: add/help/sva1000x/cn/image040.png
  inflating: add/help/sva1000x/cn/image041.png
  inflating: add/help/sva1000x/cn/image042.jpg
  inflating: add/help/sva1000x/cn/image043.png
  inflating: add/help/sva1000x/cn/image044.jpg
  inflating: add/help/sva1000x/cn/image045.png
  inflating: add/help/sva1000x/cn/image046.png
  inflating: add/help/sva1000x/cn/image047.jpg
  inflating: add/help/sva1000x/cn/image048.jpg
  inflating: add/help/sva1000x/cn/image049.jpg
  inflating: add/help/sva1000x/cn/image050.jpg
  inflating: add/help/sva1000x/cn/image051.jpg
  inflating: add/help/sva1000x/cn/image052.jpg
  inflating: add/help/sva1000x/cn/image053.jpg
  inflating: add/help/sva1000x/cn/image054.png
  inflating: add/help/sva1000x/cn/image055.jpg
  inflating: add/help/sva1000x/cn/image056.jpg
  inflating: add/help/sva1000x/cn/image057.jpg
  inflating: add/help/sva1000x/cn/image058.jpg
  inflating: add/help/sva1000x/cn/image059.jpg
  inflating: add/help/sva1000x/cn/image060.jpg
  inflating: add/help/sva1000x/cn/image061.png
  inflating: add/help/sva1000x/cn/image062.png
  inflating: add/help/sva1000x/cn/image063.jpg
  inflating: add/help/sva1000x/cn/image064.jpg
  inflating: add/help/sva1000x/cn/image065.jpg
  inflating: add/help/sva1000x/cn/image066.png
  inflating: add/help/sva1000x/cn/image067.jpg
  inflating: add/help/sva1000x/cn/image068.jpg
  inflating: add/help/sva1000x/cn/image069.png
  inflating: add/help/sva1000x/cn/image070.png
  inflating: add/help/sva1000x/cn/image071.png
  inflating: add/help/sva1000x/cn/image072.png
  inflating: add/help/sva1000x/cn/image073.jpg
  inflating: add/help/sva1000x/cn/image074.png
  inflating: add/help/sva1000x/cn/image075.png
  inflating: add/help/sva1000x/cn/image076.png
  inflating: add/help/sva1000x/cn/image077.png
  inflating: add/help/sva1000x/cn/image078.png
  inflating: add/help/sva1000x/cn/image079.png
  inflating: add/help/sva1000x/cn/image080.png
  inflating: add/help/sva1000x/cn/image081.png
  inflating: add/help/sva1000x/cn/image082.png
  inflating: add/help/sva1000x/cn/image083.png
  inflating: add/help/sva1000x/cn/image084.png
  inflating: add/help/sva1000x/cn/image085.png
  inflating: add/help/sva1000x/cn/image086.jpg
  inflating: add/help/sva1000x/cn/image087.jpg
  inflating: add/help/sva1000x/cn/image088.png
  inflating: add/help/sva1000x/cn/image089.jpg
  inflating: add/help/sva1000x/cn/image090.png
  inflating: add/help/sva1000x/cn/image091.jpg
  inflating: add/help/sva1000x/cn/image092.png
  inflating: add/help/sva1000x/cn/image093.png
  inflating: add/help/sva1000x/cn/image094.jpg
  inflating: add/help/sva1000x/cn/image095.png
  inflating: add/help/sva1000x/cn/image096.jpg
  inflating: add/help/sva1000x/cn/image097.jpg
  inflating: add/help/sva1000x/cn/image098.jpg
  inflating: add/help/sva1000x/cn/image099.jpg
  inflating: add/help/sva1000x/cn/image100.jpg
  inflating: add/help/sva1000x/cn/image101.jpg
  inflating: add/help/sva1000x/cn/image102.png
  inflating: add/help/sva1000x/cn/image103.png
  inflating: add/help/sva1000x/cn/image104.jpg
  inflating: add/help/sva1000x/cn/image105.jpg
  inflating: add/help/sva1000x/cn/image106.jpg
  inflating: add/help/sva1000x/cn/image107.png
  inflating: add/help/sva1000x/cn/image108.png
  inflating: add/help/sva1000x/cn/image109.png
  inflating: add/help/sva1000x/cn/image110.jpg
  inflating: add/help/sva1000x/cn/image111.png
   creating: add/help/sva1000x/en/
  inflating: add/help/sva1000x/en/image001.png
  inflating: add/help/sva1000x/en/image002.png
  inflating: add/help/sva1000x/en/image003.png
  inflating: add/help/sva1000x/en/image004.png
  inflating: add/help/sva1000x/en/image005.jpg
  inflating: add/help/sva1000x/en/image006.png
  inflating: add/help/sva1000x/en/image007.png
  inflating: add/help/sva1000x/en/image008.png
  inflating: add/help/sva1000x/en/image009.png
  inflating: add/help/sva1000x/en/image010.png
  inflating: add/help/sva1000x/en/image011.png
  inflating: add/help/sva1000x/en/image012.png
  inflating: add/help/sva1000x/en/image013.png
  inflating: add/help/sva1000x/en/image014.png
  inflating: add/help/sva1000x/en/image015.png
  inflating: add/help/sva1000x/en/image016.jpg
  inflating: add/help/sva1000x/en/image017.jpg
  inflating: add/help/sva1000x/en/image018.png
  inflating: add/help/sva1000x/en/image019.png
  inflating: add/help/sva1000x/en/image020.png
  inflating: add/help/sva1000x/en/image021.png
  inflating: add/help/sva1000x/en/image022.png
  inflating: add/help/sva1000x/en/image023.png
  inflating: add/help/sva1000x/en/image024.jpg
  inflating: add/help/sva1000x/en/image025.png
  inflating: add/help/sva1000x/en/image026.jpg
  inflating: add/help/sva1000x/en/image027.png
  inflating: add/help/sva1000x/en/image028.jpg
  inflating: add/help/sva1000x/en/image029.png
  inflating: add/help/sva1000x/en/image030.jpg
  inflating: add/help/sva1000x/en/image031.jpg
  inflating: add/help/sva1000x/en/image032.jpg
  inflating: add/help/sva1000x/en/image033.png
  inflating: add/help/sva1000x/en/image034.png
  inflating: add/help/sva1000x/en/image035.jpg
  inflating: add/help/sva1000x/en/image036.png
  inflating: add/help/sva1000x/en/image037.png
  inflating: add/help/sva1000x/en/image038.png
  inflating: add/help/sva1000x/en/image039.jpg
  inflating: add/help/sva1000x/en/image040.jpg
  inflating: add/help/sva1000x/en/image041.jpg
  inflating: add/help/sva1000x/en/image042.jpg
  inflating: add/help/sva1000x/en/image043.jpg
  inflating: add/help/sva1000x/en/image044.jpg
  inflating: add/help/sva1000x/en/image045.jpg
  inflating: add/help/sva1000x/en/image046.png
  inflating: add/help/sva1000x/en/image047.jpg
  inflating: add/help/sva1000x/en/image048.jpg
  inflating: add/help/sva1000x/en/image049.png
  inflating: add/help/sva1000x/en/image050.png
  inflating: add/help/sva1000x/en/image051.jpg
  inflating: add/help/sva1000x/en/image052.jpg
  inflating: add/help/sva1000x/en/image053.jpg
  inflating: add/help/sva1000x/en/image054.jpg
  inflating: add/help/sva1000x/en/image055.jpg
  inflating: add/help/sva1000x/en/image056.jpg
  inflating: add/help/sva1000x/en/image057.jpg
  inflating: add/help/sva1000x/en/image058.jpg
  inflating: add/help/sva1000x/en/image059.jpg
  inflating: add/help/sva1000x/en/image060.jpg
  inflating: add/help/sva1000x/en/image061.png
  inflating: add/help/sva1000x/en/image062.jpg
  inflating: add/help/sva1000x/en/image063.jpg
  inflating: add/help/sva1000x/en/image064.jpg
  inflating: add/help/sva1000x/en/image065.jpg
  inflating: add/help/sva1000x/en/image066.png
  inflating: add/help/sva1000x/en/image067.png
  inflating: add/help/sva1000x/en/image068.png
  inflating: add/help/sva1000x/en/image069.png
  inflating: add/help/sva1000x/en/image070.png
  inflating: add/help/sva1000x/en/image071.jpg
  inflating: add/help/sva1000x/en/image072.jpg
  inflating: add/help/sva1000x/en/image073.png
  inflating: add/help/sva1000x/en/image074.jpg
  inflating: add/help/sva1000x/en/image075.jpg
  inflating: add/help/sva1000x/en/image076.png
  inflating: add/help/sva1000x/en/image077.png
  inflating: add/help/sva1000x/en/image078.png
  inflating: add/help/sva1000x/en/image079.png
  inflating: add/help/sva1000x/en/image080.png
  inflating: add/help/sva1000x/en/image081.png
  inflating: add/help/sva1000x/en/image082.png
  inflating: add/help/sva1000x/en/image083.png
  inflating: add/help/sva1000x/en/image084.png
  inflating: add/help/sva1000x/en/image085.png
  inflating: add/help/sva1000x/en/image086.png
  inflating: add/help/sva1000x/en/image087.png
  inflating: add/help/sva1000x/en/image088.png
  inflating: add/help/sva1000x/en/image089.png
  inflating: add/help/sva1000x/en/image090.jpg
  inflating: add/help/sva1000x/en/image091.png
  inflating: add/help/sva1000x/en/image092.png
  inflating: add/help/sva1000x/en/image093.jpg
  inflating: add/help/sva1000x/en/image094.jpg
  inflating: add/help/sva1000x/en/image095.png
  inflating: add/help/sva1000x/en/image096.png
  inflating: add/help/sva1000x/en/image097.png
  inflating: add/help/sva1000x/en/image098.png
  inflating: add/help/sva1000x/en/image099.png
  inflating: add/help/sva1000x/en/image100.png
  inflating: add/help/sva1000x/en/image101.png
  inflating: add/help/sva1000x/en/image102.jpg
  inflating: add/help/sva1000x/en/image103.jpg
  inflating: add/help/sva1000x/en/image104.jpg
  inflating: add/help/sva1000x/en/image105.jpg
  inflating: add/help/sva1000x/en/image106.jpg
  inflating: add/help/sva1000x/en/image107.jpg
  inflating: add/help/sva1000x/en/image108.png
  inflating: add/help/sva1000x/en/image109.png
  inflating: add/help/sva1000x/en/image110.jpg
  inflating: add/help/sva1000x/en/image111.jpg
  inflating: add/help/sva1000x/en/image112.jpg
  inflating: add/help/sva1000x/en/image113.png
  inflating: add/help/sva1000x/en/image114.png
  inflating: add/help/sva1000x/en/image115.png
  inflating: add/help/sva1000x/en/image116.jpg
  inflating: add/help/sva1000x/en/image117.png
  inflating: add/help/sva1000x/en/image118.jpg
  inflating: add/help/sva1000x_manual_cn.xml
  inflating: add/help/sva1000x_manual_en.xml
   creating: add/Limits/
   creating: add/Limits/EN/
   creating: add/Limits/EN/55011/
  inflating: add/Limits/EN/55011/EN 55011, Cond, Class A, Group 1, GT 20kVA, Average.lim
  inflating: add/Limits/EN/55011/EN 55011, Cond, Class A, Group 1, GT 20kVA, Quasi-P.lim
  inflating: add/Limits/EN/55011/EN 55011, Cond, Class A, Group 1, LTE 20kVA, Average.lim
  inflating: add/Limits/EN/55011/EN 55011, Cond, Class A, Group 1, LTE 20kVA, Quasi-P.lim
  inflating: add/Limits/EN/55011/EN 55011, Cond, Class A, Group 2, GT 75kVA, Average.lim
  inflating: add/Limits/EN/55011/EN 55011, Cond, Class A, Group 2, GT 75kVA, Quasi-P.lim
  inflating: add/Limits/EN/55011/EN 55011, Cond, Class A, Group 2, LTE 75kVA, Average.lim
  inflating: add/Limits/EN/55011/EN 55011, Cond, Class A, Group 2, LTE 75kVA, Quasi-P.lim
  inflating: add/Limits/EN/55011/EN 55011, Cond, Class B, Group 1, Average.lim
  inflating: add/Limits/EN/55011/EN 55011, Cond, Class B, Group 1, Quasi-Peak.lim
  inflating: add/Limits/EN/55011/EN 55011, Cond, Class B, Group 2, Average.lim
  inflating: add/Limits/EN/55011/EN 55011, Cond, Class B, Group 2, Quasi-Peak.lim
  inflating: add/Limits/EN/55011/EN 55011, Cond, Ind Cooking, 100V No Gnd, Average.lim
  inflating: add/Limits/EN/55011/EN 55011, Cond, Ind Cooking, 100V No Gnd, Quasi-Peak.lim
  inflating: add/Limits/EN/55011/EN 55011, Cond, Ind Cooking, Average.lim
  inflating: add/Limits/EN/55011/EN 55011, Cond, Ind Cooking, Quasi-Peak.lim
  inflating: add/Limits/EN/55011/EN 55011, Rad, Class A, EDM + Arc Welding.lim
  inflating: add/Limits/EN/55011/EN 55011, Rad, Class A, Group 1, GT 20kVA.lim
  inflating: add/Limits/EN/55011/EN 55011, Rad, Class A, Group 1, LTE 20kVA, Quasi-P (10m).lim
  inflating: add/Limits/EN/55011/EN 55011, Rad, Class A, Group 1, LTE 20kVA, Quasi-P (30m).lim
  inflating: add/Limits/EN/55011/EN 55011, Rad, Class A, Group 1, LTE 20kVA, Quasi-P (3m).lim
  inflating: add/Limits/EN/55011/EN 55011, Rad, Class A, Group 2 (10m).lim
  inflating: add/Limits/EN/55011/EN 55011, Rad, Class A, Group 2 (30m).lim
  inflating: add/Limits/EN/55011/EN 55011, Rad, Class A, Group 2, MagField (10m).lim
  inflating: add/Limits/EN/55011/EN 55011, Rad, Class A, Group 2, MagField (30m).lim
  inflating: add/Limits/EN/55011/EN 55011, Rad, Class B, Group 1.lim
  inflating: add/Limits/EN/55011/EN 55011, Rad, Class B, Group 2, Average (10m).lim
  inflating: add/Limits/EN/55011/EN 55011, Rad, Class B, Group 2, MagField (3m).lim
  inflating: add/Limits/EN/55011/EN 55011, Rad, Class B, Group 2, Quasi-Peak (10m).lim
  inflating: add/Limits/EN/55011/EN 55011, Rad, Commercial Ind Cooking, MagField.lim
  inflating: add/Limits/EN/55011/EN 55011, Rad, Domestic Ind Cooking, MagField, Horiz.lim
  inflating: add/Limits/EN/55011/EN 55011, Rad, Domestic Ind Cooking, MagField, Vert.lim
   creating: add/Limits/EN/55012/
  inflating: add/Limits/EN/55012/EN 55012, Rad, Average (10m).lim
  inflating: add/Limits/EN/55012/EN 55012, Rad, Average (3m).lim
  inflating: add/Limits/EN/55012/EN 55012, Rad, Peak, 120kHz RBW (10m).lim
  inflating: add/Limits/EN/55012/EN 55012, Rad, Peak, 120kHz RBW (3m).lim
  inflating: add/Limits/EN/55012/EN 55012, Rad, Peak, 1MHz RBW (10m).lim
  inflating: add/Limits/EN/55012/EN 55012, Rad, Peak, 1MHz RBW (3m).lim
  inflating: add/Limits/EN/55012/EN 55012, Rad, Quasi-Peak, 120kHz RBW (10m).lim
  inflating: add/Limits/EN/55012/EN 55012, Rad, Quasi-Peak, 120kHz RBW (3m).lim
   creating: add/Limits/EN/55013/
  inflating: add/Limits/EN/55013/EN 55013, Conducted, Average.lim
  inflating: add/Limits/EN/55013/EN 55013, Conducted, Quasi-Peak.lim
  inflating: add/Limits/EN/55013/EN 55013, Disturbance, Average.lim
  inflating: add/Limits/EN/55013/EN 55013, Disturbance, Quasi-Peak.lim
  inflating: add/Limits/EN/55013/EN 55013, Rad, FM Sound, Rx+PCTuner - Harm.lim
  inflating: add/Limits/EN/55013/EN 55013, Rad, FM Sound, Rx+PCTuner - LO.lim
  inflating: add/Limits/EN/55013/EN 55013, Rad, FM Sound, Rx+PCTuner - Other.lim
  inflating: add/Limits/EN/55013/EN 55013, Rad, Indoor Sat TV+Sd Rx,IR Rmt+Headphone.lim
  inflating: add/Limits/EN/55013/EN 55013, Rad, Sat Rx Outdoor Unit - EquivRadPW.lim
  inflating: add/Limits/EN/55013/EN 55013, Rad, Sat Rx Outdoor Unit - LO.lim
  inflating: add/Limits/EN/55013/EN 55013, Rad, Sat TV+Sd Rx, TunerUnit - LO+Harm.lim
  inflating: add/Limits/EN/55013/EN 55013, Rad, TV, VidRec, PCTuner - Harm.lim
  inflating: add/Limits/EN/55013/EN 55013, Rad, TV, VidRec, PCTuner - LO.lim
  inflating: add/Limits/EN/55013/EN 55013, Rad, TV, VidRec, PCTuner - Other.lim
   creating: add/Limits/EN/55014/
  inflating: add/Limits/EN/55014/EN 55014, Cond, Household, Average.lim
  inflating: add/Limits/EN/55014/EN 55014, Cond, Household, Quasi-Peak.lim
  inflating: add/Limits/EN/55014/EN 55014, Cond, Motors 700to1000W, Average.lim
  inflating: add/Limits/EN/55014/EN 55014, Cond, Motors 700to1000W, Quasi-Peak.lim
  inflating: add/Limits/EN/55014/EN 55014, Cond, Motors GT 1000W, Average.lim
  inflating: add/Limits/EN/55014/EN 55014, Cond, Motors GT 1000W, Quasi-Peak.lim
  inflating: add/Limits/EN/55014/EN 55014, Cond, Motors LT 700W, Average.lim
  inflating: add/Limits/EN/55014/EN 55014, Cond, Motors LT 700W, Quasi-Peak.lim
  inflating: add/Limits/EN/55014/EN 55014, Rad, FAR.lim
  inflating: add/Limits/EN/55014/EN 55014, Rad, Mains, Household, Average.lim
  inflating: add/Limits/EN/55014/EN 55014, Rad, Mains, Household, Quasi-Peak.lim
  inflating: add/Limits/EN/55014/EN 55014, Rad, Mains, Motors 700to1000W, Average.lim
  inflating: add/Limits/EN/55014/EN 55014, Rad, Mains, Motors 700to1000W, Quasi-Peak.lim
  inflating: add/Limits/EN/55014/EN 55014, Rad, Mains, Motors GT 1000W, Average.lim
  inflating: add/Limits/EN/55014/EN 55014, Rad, Mains, Motors GT 1000W, Quasi-Peak.lim
  inflating: add/Limits/EN/55014/EN 55014, Rad, Mains, Motors LT 700W, Average.lim
  inflating: add/Limits/EN/55014/EN 55014, Rad, Mains, Motors LT 700W, Quasi-Peak.lim
  inflating: add/Limits/EN/55014/EN 55014, Rad, OATS or SAC.lim
  inflating: add/Limits/EN/55014/EN 55014, Rad, TEM.lim
   creating: add/Limits/EN/55015/
  inflating: add/Limits/EN/55015/EN 55015, Cond, Control, Average.lim
  inflating: add/Limits/EN/55015/EN 55015, Cond, Control, Quasi-Peak.lim
  inflating: add/Limits/EN/55015/EN 55015, Cond, Load, Average.lim
  inflating: add/Limits/EN/55015/EN 55015, Cond, Load, Quasi-Peak.lim
  inflating: add/Limits/EN/55015/EN 55015, Cond, Mains, Average.lim
  inflating: add/Limits/EN/55015/EN 55015, Cond, Mains, Quasi-Peak.lim
  inflating: add/Limits/EN/55015/EN 55015, Rad, 30-300MHz (10m).lim
  inflating: add/Limits/EN/55015/EN 55015, Rad, 9kHz-30MHz, Loop=2m.lim
  inflating: add/Limits/EN/55015/EN 55015, Rad, 9kHz-30MHz, Loop=3m.lim
  inflating: add/Limits/EN/55015/EN 55015, Rad, 9kHz-30MHz, Loop=4m.lim
   creating: add/Limits/EN/55022/
  inflating: add/Limits/EN/55022/EN 55022, Cond, Class A, Average.lim
  inflating: add/Limits/EN/55022/EN 55022, Cond, Class A, Quasi-Peak.lim
  inflating: add/Limits/EN/55022/EN 55022, Cond, Class A, Telecom, Current, Ave.lim
  inflating: add/Limits/EN/55022/EN 55022, Cond, Class A, Telecom, Current, QP.lim
  inflating: add/Limits/EN/55022/EN 55022, Cond, Class A, Telecom, Voltage, Ave.lim
  inflating: add/Limits/EN/55022/EN 55022, Cond, Class A, Telecom, Voltage, QP.lim
  inflating: add/Limits/EN/55022/EN 55022, Cond, Class B, Average.lim
  inflating: add/Limits/EN/55022/EN 55022, Cond, Class B, Quasi-Peak.lim
  inflating: add/Limits/EN/55022/EN 55022, Cond, Class B, Telecom, Current, Ave.lim
  inflating: add/Limits/EN/55022/EN 55022, Cond, Class B, Telecom, Current, QP.lim
  inflating: add/Limits/EN/55022/EN 55022, Cond, Class B, Telecom, Voltage, Ave.lim
  inflating: add/Limits/EN/55022/EN 55022, Cond, Class B, Telecom, Voltage, QP.lim
  inflating: add/Limits/EN/55022/EN 55022, Rad, Class A, 1 to 6GHz, Average (3m).lim
  inflating: add/Limits/EN/55022/EN 55022, Rad, Class A, 1 to 6GHz, Peak (3m).lim
  inflating: add/Limits/EN/55022/EN 55022, Rad, Class A, 30MHz to 1GHz (10m).lim
  inflating: add/Limits/EN/55022/EN 55022, Rad, Class A, 30MHz to 1GHz (3m).lim
  inflating: add/Limits/EN/55022/EN 55022, Rad, Class B, 1 to 6GHz, Average (3m).lim
  inflating: add/Limits/EN/55022/EN 55022, Rad, Class B, 1 to 6GHz, Peak (3m).lim
  inflating: add/Limits/EN/55022/EN 55022, Rad, Class B, 30MHz to 1GHz (10m).lim
  inflating: add/Limits/EN/55022/EN 55022, Rad, Class B, 30MHz to 1GHz (3m).lim
   creating: add/Limits/EN/55032/
  inflating: add/Limits/EN/55032/EN 55032, Cond, Class A, AMN, 0.15-30MHz, AVG.lim
  inflating: add/Limits/EN/55032/EN 55032, Cond, Class A, AMN, 0.15-30MHz, Quasi-P.lim
  inflating: add/Limits/EN/55032/EN 55032, Cond, Class B, AMN, 0.15-30MHz, AVG.lim
  inflating: add/Limits/EN/55032/EN 55032, Cond, Class B, AMN, 0.15-30MHz, Quasi-P.lim
  inflating: add/Limits/EN/55032/EN 55032, Rad, Class A, FAR, 30MHz-1GHz, Quasi-P (10m).lim
  inflating: add/Limits/EN/55032/EN 55032, Rad, Class A, FAR, 30MHz-1GHz, Quasi-P (3m).lim
  inflating: add/Limits/EN/55032/EN 55032, Rad, Class A, FSOATS, 1-6GHz, AVG (3m).lim
  inflating: add/Limits/EN/55032/EN 55032, Rad, Class A, FSOATS, 1-6GHz, Peak (3m).lim
  inflating: add/Limits/EN/55032/EN 55032, Rad, Class A, OATS, 30MHz-1GHz, Quasi-P (10m).lim
  inflating: add/Limits/EN/55032/EN 55032, Rad, Class A, OATS, 30MHz-1GHz, Quasi-P (3m).lim
  inflating: add/Limits/EN/55032/EN 55032, Rad, Class B, FAR, 30MHz-1GHz, Quasi-P (10m).lim
  inflating: add/Limits/EN/55032/EN 55032, Rad, Class B, FAR, 30MHz-1GHz, Quasi-P (3m).lim
  inflating: add/Limits/EN/55032/EN 55032, Rad, Class B, FM receiver, FAR, 30MHz-1GHz, Quasi-P (10m).lim
  inflating: add/Limits/EN/55032/EN 55032, Rad, Class B, FM receiver, FAR, 30MHz-1GHz, Quasi-P (3m).lim
  inflating: add/Limits/EN/55032/EN 55032, Rad, Class B, FM receiver, OATS, 30MHz-1GHz, Quasi-P (10m).lim
  inflating: add/Limits/EN/55032/EN 55032, Rad, Class B, FM receiver, OATS, 30MHz-1GHz, Quasi-P (3m).lim
  inflating: add/Limits/EN/55032/EN 55032, Rad, Class B, FSOATS, 1-6GHz, AVG (3m).lim
  inflating: add/Limits/EN/55032/EN 55032, Rad, Class B, FSOATS, 1-6GHz, Peak (3m).lim
  inflating: add/Limits/EN/55032/EN 55032, Rad, Class B, OATS, 30MHz-1GHz, Quasi-P (10m).lim
  inflating: add/Limits/EN/55032/EN 55032, Rad, Class B, OATS, 30MHz-1GHz, Quasi-P (3m).lim
   creating: add/Limits/FCC/
  inflating: add/Limits/FCC/FCC Part 15, Cond, Class A, Average.lim
  inflating: add/Limits/FCC/FCC Part 15, Cond, Class A, Quasi-Peak.lim
  inflating: add/Limits/FCC/FCC Part 15, Cond, Class B, Average.lim
  inflating: add/Limits/FCC/FCC Part 15, Cond, Class B, Quasi-Peak.lim
  inflating: add/Limits/FCC/FCC Part 15, Rad, Class A (10m).lim
  inflating: add/Limits/FCC/FCC Part 15, Rad, Class B (3m).lim
   creating: add/Limits/GB9254/
  inflating: add/Limits/GB9254/GB9254, Cond, Class A, Average.lim
  inflating: add/Limits/GB9254/GB9254, Cond, Class A, Quasi-Peak.lim
  inflating: add/Limits/GB9254/GB9254, Cond, Class A, Telecom, Current, Ave.lim
  inflating: add/Limits/GB9254/GB9254, Cond, Class A, Telecom, Current, QP.lim
  inflating: add/Limits/GB9254/GB9254, Cond, Class A, Telecom, Voltage, Ave.lim
  inflating: add/Limits/GB9254/GB9254, Cond, Class A, Telecom, Voltage, QP.lim
  inflating: add/Limits/GB9254/GB9254, Cond, Class B, Average.lim
  inflating: add/Limits/GB9254/GB9254, Cond, Class B, Quasi-Peak.lim
  inflating: add/Limits/GB9254/GB9254, Cond, Class B, Telecom, Current, Ave.lim
  inflating: add/Limits/GB9254/GB9254, Cond, Class B, Telecom, Current, QP.lim
  inflating: add/Limits/GB9254/GB9254, Cond, Class B, Telecom, Voltage, Ave.lim
  inflating: add/Limits/GB9254/GB9254, Cond, Class B, Telecom, Voltage, QP.lim
  inflating: add/Limits/GB9254/GB9254, Rad, Class A, 1 to 6GHz, Average (3m).lim
  inflating: add/Limits/GB9254/GB9254, Rad, Class A, 1 to 6GHz, Peak (3m).lim
  inflating: add/Limits/GB9254/GB9254, Rad, Class A, 30MHz to 1GHz (10m).lim
  inflating: add/Limits/GB9254/GB9254, Rad, Class A, 30MHz to 1GHz (3m).lim
  inflating: add/Limits/GB9254/GB9254, Rad, Class B, 1 to 6GHz, Average (3m).lim
  inflating: add/Limits/GB9254/GB9254, Rad, Class B, 1 to 6GHz, Peak (3m).lim
  inflating: add/Limits/GB9254/GB9254, Rad, Class B, 30MHz to 1GHz (10m).lim
  inflating: add/Limits/GB9254/GB9254, Rad, Class B, 30MHz to 1GHz (3m).lim
  inflating: add/log4cpp.properties
  inflating: add/NSP_config_upgrade_info.xml
   creating: app/
  inflating: app/Aladdin
  inflating: app/config_eth0.sh
  inflating: app/startup_app.sh
  inflating: app/startup_ftp.sh
  inflating: app/upgrade_app1.sh
  inflating: app/vsftpd
   creating: drivers/
  inflating: drivers/g_usbtmc.ko
   creating: plat/
   creating: plat/32/
   creating: plat/32/boot/
  inflating: plat/32/boot/BOOT.bin
   creating: plat/32/devicetree/
   creating: plat/32/fpga/
  inflating: plat/32/fpga/fpga_top.bit
  inflating: plat/32/fpga/load_fpga.sh
  inflating: plat/32/fpga/plat
  inflating: plat/32/fpga/vdma_menu.sh
  inflating: plat/32/fpga/vdma_wave.sh
  inflating: plat/32/upgrade_dtb.sh
  inflating: plat/32/upgrade_fpga.sh
  inflating: plat/32/upgrade_uboot.sh
  inflating: plat/32/upgrade_vnc1.sh
   creating: plat/32/vnc/
  inflating: plat/32/vnc/vdma_vnc.sh
  inflating: plat/32/vnc/vncserver.conf
   creating: sys/
  inflating: sys/uImage
   creating: vnc/
   creating: vnc/lib/
  inflating: vnc/lib/brusvxi11.so
  inflating: vnc/lib/ext_device_driver.so
  inflating: vnc/lib/libEasyLib.so
  inflating: vnc/lib/libvncclient.so
  inflating: vnc/lib/libvncclient.so.1
  inflating: vnc/lib/libvncserver.so
  inflating: vnc/lib/libvncserver.so.1
  inflating: vnc/lighttpd.conf
  inflating: vnc/php.ini
  inflating: vnc/startup_vnc.sh
  inflating: vnc/vdma_vnc.sh
  inflating: vnc/vncserver
   creating: vnc/www/
   creating: vnc/www/attchment/
   creating: vnc/www/css/
   creating: vnc/www/css/device/
  inflating: vnc/www/css/device/device_control.css
  inflating: vnc/www/css/device/main.css
  inflating: vnc/www/css/login.css
  inflating: vnc/www/css/welcome.css
  inflating: vnc/www/deviceupdate.php
  inflating: vnc/www/device_read_write.php
   creating: vnc/www/fonts/
  inflating: vnc/www/fonts/fontawesome-webfont.eot
  inflating: vnc/www/fonts/fontawesome-webfont.svg
  inflating: vnc/www/fonts/fontawesome-webfont.ttf
  inflating: vnc/www/fonts/fontawesome-webfont.woff
  inflating: vnc/www/fonts/fontawesome-webfont.woff2
  inflating: vnc/www/fonts/FontAwesome.otf
   creating: vnc/www/img/
  inflating: vnc/www/img/about.png
  inflating: vnc/www/img/Home1.png
  inflating: vnc/www/img/Home2.png
  inflating: vnc/www/img/ic_login.png
  inflating: vnc/www/img/ic_password.png
  inflating: vnc/www/img/ic_user.png
  inflating: vnc/www/img/Intrument1.png
  inflating: vnc/www/img/Intrument2.png
  inflating: vnc/www/img/LAN1.png
  inflating: vnc/www/img/LAN2.png
  inflating: vnc/www/img/logo.png
  inflating: vnc/www/img/oem_logo.png
  inflating: vnc/www/img/SCPI1.png
  inflating: vnc/www/img/SCPI2.png
  inflating: vnc/www/index.php
   creating: vnc/www/Instrument/
   creating: vnc/www/Instrument/novnc/
  inflating: vnc/www/Instrument/novnc/favicon.ico
   creating: vnc/www/Instrument/novnc/images/
  inflating: vnc/www/Instrument/novnc/images/alt.png
  inflating: vnc/www/Instrument/novnc/images/clipboard.png
  inflating: vnc/www/Instrument/novnc/images/connect.png
  inflating: vnc/www/Instrument/novnc/images/ctrl.png
  inflating: vnc/www/Instrument/novnc/images/ctrlaltdel.png
  inflating: vnc/www/Instrument/novnc/images/disconnect.png
  inflating: vnc/www/Instrument/novnc/images/drag.png
  inflating: vnc/www/Instrument/novnc/images/esc.png
  inflating: vnc/www/Instrument/novnc/images/expand.gif
  inflating: vnc/www/Instrument/novnc/images/favicon.ico
  inflating: vnc/www/Instrument/novnc/images/favicon.png
  inflating: vnc/www/Instrument/novnc/images/full_screen.png
  inflating: vnc/www/Instrument/novnc/images/hide.gif
  inflating: vnc/www/Instrument/novnc/images/keyboard.png
  inflating: vnc/www/Instrument/novnc/images/left.png
  inflating: vnc/www/Instrument/novnc/images/mouse_left.png
  inflating: vnc/www/Instrument/novnc/images/mouse_middle.png
  inflating: vnc/www/Instrument/novnc/images/mouse_none.png
  inflating: vnc/www/Instrument/novnc/images/mouse_right.png
  inflating: vnc/www/Instrument/novnc/images/new-down-24.png
  inflating: vnc/www/Instrument/novnc/images/new-left-24.png
  inflating: vnc/www/Instrument/novnc/images/new-right-24.png
  inflating: vnc/www/Instrument/novnc/images/new-up-24.png
  inflating: vnc/www/Instrument/novnc/images/power.png
  inflating: vnc/www/Instrument/novnc/images/press_new.png
  inflating: vnc/www/Instrument/novnc/images/right.png
  inflating: vnc/www/Instrument/novnc/images/r_left-16.png
  inflating: vnc/www/Instrument/novnc/images/r_right-16.png
  inflating: vnc/www/Instrument/novnc/images/screen_320x460.png
  inflating: vnc/www/Instrument/novnc/images/screen_57x57.png
  inflating: vnc/www/Instrument/novnc/images/screen_700x700.png
  inflating: vnc/www/Instrument/novnc/images/settings.png
  inflating: vnc/www/Instrument/novnc/images/showextrakeys.png
  inflating: vnc/www/Instrument/novnc/images/stop.png
  inflating: vnc/www/Instrument/novnc/images/tab.png
   creating: vnc/www/Instrument/novnc/include/
  inflating: vnc/www/Instrument/novnc/include/base.css
  inflating: vnc/www/Instrument/novnc/include/base64.js
  inflating: vnc/www/Instrument/novnc/include/base_mobile.css
  inflating: vnc/www/Instrument/novnc/include/base_novnc.css
  inflating: vnc/www/Instrument/novnc/include/black.css
  inflating: vnc/www/Instrument/novnc/include/blue.css
   creating: vnc/www/Instrument/novnc/include/chrome-app/
  inflating: vnc/www/Instrument/novnc/include/chrome-app/tcp-client.js
  inflating: vnc/www/Instrument/novnc/include/des.js
  inflating: vnc/www/Instrument/novnc/include/display.js
  inflating: vnc/www/Instrument/novnc/include/input.js
  inflating: vnc/www/Instrument/novnc/include/jsunzip.js
  inflating: vnc/www/Instrument/novnc/include/keyboard.js
  inflating: vnc/www/Instrument/novnc/include/keysym.js
  inflating: vnc/www/Instrument/novnc/include/keysymdef.js
  inflating: vnc/www/Instrument/novnc/include/logo.js
  inflating: vnc/www/Instrument/novnc/include/Orbitron700.ttf
  inflating: vnc/www/Instrument/novnc/include/Orbitron700.woff
  inflating: vnc/www/Instrument/novnc/include/playback.js
  inflating: vnc/www/Instrument/novnc/include/rfb.js
  inflating: vnc/www/Instrument/novnc/include/ui.js
  inflating: vnc/www/Instrument/novnc/include/util.js
   creating: vnc/www/Instrument/novnc/include/web-socket-js/
  inflating: vnc/www/Instrument/novnc/include/web-socket-js/README.txt
  inflating: vnc/www/Instrument/novnc/include/web-socket-js/swfobject.js
  inflating: vnc/www/Instrument/novnc/include/web-socket-js/WebSocketMain.swf
  inflating: vnc/www/Instrument/novnc/include/web-socket-js/web_socket.js
  inflating: vnc/www/Instrument/novnc/include/websock.js
  inflating: vnc/www/Instrument/novnc/include/webutil.js
  inflating: vnc/www/Instrument/novnc/LICENSE.txt
  inflating: vnc/www/Instrument/novnc/README.md
  inflating: vnc/www/Instrument/novnc/vnc.html
  inflating: vnc/www/Instrument/novnc/vnc_auto.html
  inflating: vnc/www/Instrument/novnc/vnc_auto.php
  inflating: vnc/www/Instrument/novnc/vnc_auto_mobile.php
   creating: vnc/www/js/
  inflating: vnc/www/js/cycle.js
   creating: vnc/www/js/device/
  inflating: vnc/www/js/device/t_table.js
  inflating: vnc/www/js/home_info.js
  inflating: vnc/www/js/iscroll.js
  inflating: vnc/www/js/jquery.cookie.js
  inflating: vnc/www/js/jquery.fileupload.js
  inflating: vnc/www/js/jquery.iframe-transport.js
  inflating: vnc/www/js/jquery.min.js
  inflating: vnc/www/js/jquery.pagination.js
  inflating: vnc/www/js/jquery.transit.min.js
  inflating: vnc/www/js/jquery.wordexport.js
   creating: vnc/www/js/JSON-js-master/
  inflating: vnc/www/js/JSON-js-master/cycle.js
  inflating: vnc/www/js/JSON-js-master/json2.js
  inflating: vnc/www/js/JSON-js-master/json_parse.js
  inflating: vnc/www/js/JSON-js-master/json_parse_state.js
  inflating: vnc/www/js/JSON-js-master/README
  inflating: vnc/www/js/json2.js
  inflating: vnc/www/js/json_parse.js
  inflating: vnc/www/js/json_parse_state.js
  inflating: vnc/www/js/lan_config.js
  inflating: vnc/www/js/log_in.js
  inflating: vnc/www/js/main.js
  inflating: vnc/www/js/mcplib.js
  inflating: vnc/www/js/npm.js
  inflating: vnc/www/js/TweenMax.min.js
   creating: vnc/www/js/vendor/
  inflating: vnc/www/js/vendor/jquery.ui.widget.js
  inflating: vnc/www/js/xhtml
  inflating: vnc/www/js/xhtml1-transitional.dtd
  inflating: vnc/www/lan.php
  inflating: vnc/www/lan_setting.php
   creating: vnc/www/log/
  inflating: vnc/www/log/lighttpd_error.log
  inflating: vnc/www/login.php
  inflating: vnc/www/logout.php
  inflating: vnc/www/SCPI_control.php
   creating: vnc/www/src/
  inflating: vnc/www/src/IDN.php
  inflating: vnc/www/src/index.html
  inflating: vnc/www/vncserver.conf
  inflating: vnc/www/welcome.php
  inflating: upgrade.sh
  inflating: upgrade_add.sh
  inflating: upgrade_app.sh
  inflating: upgrade_drivers.sh
  inflating: upgrade_plat.sh
  inflating: upgrade_sys.sh
  inflating: upgrade_vnc.sh
update.sh starting ...
current version:
[  995.736436] UBIFS: background thread "ubifs_bgt2_0" started, PID 1337
rm: can't remove '/usr/bin/siglent/usr/usr/upgrade/*.ADS': No such file or directory
rm: can't remove '/usr/bin/siglent/usr/*.zip': No such file or directory
rm: can't remove '/usr/bin/siglent/usr/*.ADS': No such file or directory
rm: can't remove '/tmp/*.zip': No such file or directory
rm: can't remove '/tmp/*.ADS': No such file or directory
upgrade_app:            starting
cp -rpf /usr/bin/siglent/usr/usr/upgrade/app/startup_app.sh /usr/bin/siglent/
cp -rpf /usr/bin/siglent/usr/usr/upgrade/app/upgrade_app1.sh /usr/bin/siglent/usr/backup/
upgrade_app:            ending
upgrade_add:  upgrade  /usr/bin/siglent/usr/usr/upgrade/add/NSP_config_upgrade_info.xml
upgrade_add:  upgrade  /usr/bin/siglent/usr/usr/upgrade/add/log4cpp.properties
upgrade_add:  upgrade  /usr/bin/siglent/usr/usr/upgrade/add/help
upgrade_add:  upgrade  /usr/bin/siglent/usr/usr/upgrade/add/Limits
upgrade_add:  rm /usr/bin/siglent/usr/usr/upgrade/add -rf
upgrade_add:  ending
upgrade_drivers:                starting
cp -rpf /usr/bin/siglent/usr/usr/upgrade/drivers/*   /usr/bin/siglent/drivers/
upgrade_app:            ending
upgrade_vnc:            starting
-rpf /usr/bin/siglent/usr/usr/upgrade/vnc/startup_vnc.sh /usr/bin/siglent/
-rpf /usr/bin/siglent/usr/usr/upgrade/vnc/vncserver /usr/bin/siglent/
-rpf /usr/bin/siglent/usr/usr/upgrade/vnc/lighttpd.conf /usr/bin/siglent/
-rpf /usr/bin/siglent/usr/usr/upgrade/vnc/php.ini /usr/bin/siglent/
-rpf /usr/bin/siglent/usr/usr/upgrade/vnc/lib /usr/bin/siglent/
rm /usr/bin/siglent/config/www/ -rf
cp -rpf /usr/bin/siglent/usr/usr/upgrade/vnc/www/   /usr/bin/siglent/config/
mv: can't rename '/usr/bin/siglent/config/www/php.ini': No such file or directory
mv: can't rename '/usr/bin/siglent/config/www/lighttpd.conf': No such file or directory
rm: invalid option -- 'p'
BusyBox v1.26.0.git (2016-12-08 18:50:51 CST) multi-call binary.
Usage: rm [-irf] FILE...
Remove (unlink) FILEs
        -i      Always prompt before removing
        -f      Never prompt
        -R,-r   Recurse
rm /usr/bin/siglent/usr/usr/upgrade/vnc -rf
upgrade_vnc:            ending
upgrade_sys:            starting
/usr/bin/siglent/usr/usr/upgrade/sys/uImage upgrade starting
upgrade /usr/bin/siglent/usr/usr/upgrade/sys/uImage
Erasing 128 Kibyte @ 3e0000 -- 100 % complete
Writing at 0x00000000
Writing at 0x00020000
Writing at 0x00040000
Writing at 0x00060000
Writing at 0x00080000
Writing at 0x000a0000
Writing at 0x000c0000
Writing at 0x000e0000
Writing at 0x00100000
Writing at 0x00120000
Writing at 0x00140000
Writing at 0x00160000
Writing at 0x00180000
Writing at 0x001a0000
Writing at 0x001c0000
Writing at 0x001e0000
Writing at 0x00200000
Writing at 0x00220000
Writing at 0x00240000
Writing at 0x00260000
Writing at 0x00280000
Writing at 0x002a0000
Writing at 0x002c0000
Writing at 0x002e0000
/usr/bin/siglent/usr/usr/upgrade/sys/uImage upgrade ending
upgrade_uimage /usr/bin/siglent/usr/usr/upgrade/sys/uImage
upgrade_sys:  /usr/bin/siglent/usr/usr/upgrade/sys/rootfs.cramfs is not exist
upgrade_sys:            ending
upgrade_plat.sh:     starting
upgrade_vnc1:           ending
cp -rpf ./vnc/vdma_vnc.sh               /usr/bin/siglent/
cp -rpf ./vnc/vncserver.conf    /usr/bin/siglent/config/www/
upgrade_fpga:           starting
cp -rpf ./fpga/*.sh  /usr/bin/siglent/config/fpga/
cp -rpf ./fpga/plat  /usr/bin/siglent/config/fpga/
cp -rpf ./fpga/plat  /usr/bin/siglent/firmdata0/
cp ./fpga/fpga_top.bit  /usr/bin/siglent/config/fpga/fpga_top.bit
upgrade_fpga:           ending
upgrade_dtb:            starting
upgrade_app:  there is no *.dtb to upgrade
upgrade_dtb:            ending
upgrade_uboot.sh:     starting
./boot/BOOT.bin upgrade starting
upgrade ./boot/BOOT.bin
Erasing 128 Kibyte @ 760000 -- 100 % complete
Writing at 0x00300000
Writing at 0x00320000
Writing at 0x00340000
Writing at 0x00360000
Writing at 0x00380000
Writing at 0x003a0000
Writing at 0x003c0000
Writing at 0x003e0000
Writing at 0x00400000
Writing at 0x00420000
Writing at 0x00440000
Writing at 0x00460000
Writing at 0x00480000
Writing at 0x004a0000
Writing at 0x004c0000
Writing at 0x004e0000
Writing at 0x00500000
Writing at 0x00520000
Writing at 0x00540000
Writing at 0x00560000
Writing at 0x00580000
Writing at 0x005a0000
Writing at 0x005c0000
Writing at 0x005e0000
./boot/BOOT.bin upgrade ending
upgrade_uboot.sh:     ending
upgrade_plat.sh:     ending
[ 1021.122455] reboot: Restarting system
U-Boot 2014.07-svn118162 (Sep 03 2020 - 12:37:11)
Board:  Xilinx Zynq
I2C:   ready
DRAM:  ECC disabled 128 MiB
NAND:  256 MiB
MMC:   zynq_sdhci: 0
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
int board_late_init(void)+++++
buzzer_off---------------
buzzer_on---------------
int board_late_init(void)-----
Net:   Gem.e000b000
Hit any key to stop autoboot:  0
(Re)start USB...
USB0:   USB EHCI 1.00
scanning bus 0 for devices... 2 USB Device(s) found
USB1:   ULPI request timed out
zynq ULPI viewport init failed
lowlevel init failed
       scanning usb for storage devices... 1 Storage Device(s) found
Copying Linux from USB to RAM...
reading boot_uImage
** Unable to read file boot_uImage **
reading sva1000x_udiskEnv.txt
** Unable to read file sva1000x_udiskEnv.txt **
Copying Linux from NAND flash to RAM...
NAND read: device 0 offset 0x780000, size 0x400000
 4194304 bytes read: OK
NAND read: device 0 offset 0xb80000, size 0x80000
 524288 bytes read: OK
## Booting kernel from Legacy Image at 02080000 ...
   Image Name:   Linux-3.19.2-omg-xilinx-svn35686
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3121840 Bytes = 3 MiB
   Load Address: 00008000
   Entry Point:  00008000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 02000000
   Booting using the fdt blob at 0x2000000
EHCI failed to shut down host controller.
   Loading Kernel Image ... OK
   Loading Device Tree to 06d0d000, end 06d13db2 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 3.19.2-omg-xilinx-svn35686 (ding@ding-T5810) (gcc version 4.6.1 (Sourcery CodeBench Lite 2011.09-50) ) #11 SMP PREEMPT Fri Jan 4 15:28:26 CST 2019
[    0.000000] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: Zynq Zed Development Board
[    0.000000] cma: Reserved 16 MiB at 0x09000000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] PERCPU: Embedded 9 pages/cpu @48e92000 s8128 r8192 d20544 u36864
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 40640
[    0.000000] Kernel command line: console=ttyPS0,115200 root=/dev/mtdblock5 rootfstype=cramfs init=/linuxrc earlyprintk uboot_version=3
[    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Memory: 139704K/163840K available (3835K kernel code, 213K rwdata, 1580K rodata, 196K init, 216K bss, 7752K reserved, 16384K cma-reserved, 0K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0x4a800000 - 0xff000000   (2888 MB)
[    0.000000]     lowmem  : 0x40000000 - 0x4a000000   ( 160 MB)
[    0.000000]     pkmap   : 0x3fe00000 - 0x40000000   (   2 MB)
[    0.000000]     modules : 0x3f000000 - 0x3fe00000   (  14 MB)
[    0.000000]       .text : 0x40008000 - 0x40552200   (5417 kB)
[    0.000000]       .init : 0x40553000 - 0x40584000   ( 196 kB)
[    0.000000]       .data : 0x40584000 - 0x405b96a0   ( 214 kB)
[    0.000000]        .bss : 0x405b96a0 - 0x405ef914   ( 217 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
[    0.000000] L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
[    0.000000] L2C-310 erratum 769419 enabled
[    0.000000] L2C-310 enabling early BRESP for Cortex-A9
[    0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[    0.000000] L2C-310 ID prefetch enabled, offset 1 lines
[    0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[    0.000000] L2C-310 cache controller enabled, 8 ways, 512 kB
[    0.000000] L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
[    0.000000] slcr mapped to 4a804000
[    0.000000] zynq_clock_init: clkc starts at 4a804100
[    0.000000] Zynq clock init
[    0.000010] sched_clock: 64 bits at 333MHz, resolution 3ns, wraps every 3298534883328ns
[    0.000128] timer #0 at 4a806000, irq=17
[    0.000479] Console: colour dummy device 80x30
[    0.000498] Calibrating delay loop... 1332.01 BogoMIPS (lpj=6660096)
[    0.090271] pid_max: default: 32768 minimum: 301
[    0.090420] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.090436] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.091064] CPU: Testing write buffer coherency: ok
[    0.091263] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.091331] Setting up static identity map for 0x39c880 - 0x39c8d8
[    0.240259] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.240337] Brought up 2 CPUs
[    0.240356] SMP: Total of 2 processors activated (2664.03 BogoMIPS).
[    0.240365] CPU: All CPU(s) started in SVC mode.
[    0.240860] devtmpfs: initialized
[    0.241578] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[    0.247188] NET: Registered protocol family 16
[    0.249136] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.271082] cpuidle: using governor ladder
[    0.301045] cpuidle: using governor menu
[    0.309122] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[    0.309139] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.309269] zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0x4a880000
[    0.319863] vgaarb: loaded
[    0.320351] SCSI subsystem initialized
[    0.320750] usbcore: registered new interface driver usbfs
[    0.320838] usbcore: registered new interface driver hub
[    0.320938] usbcore: registered new device driver usb
[    0.321086] phy0 supply vcc not found, using dummy regulator
[    0.321195] phy1 supply vcc not found, using dummy regulator
[    0.321302] --------------usb_udc_init ------
[    0.321561] pps_core: LinuxPPS API ver. 1 registered
[    0.321574] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.321624] PTP clock support registered
[    0.321895] EDAC MC: Ver: 3.0.0
[    0.323332] Switched to clocksource arm_global_timer
[    0.335260] NET: Registered protocol family 2
[    0.336012] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[    0.336063] TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
[    0.336120] TCP: Hash tables configured (established 2048 bind 2048)
[    0.336165] TCP: reno registered
[    0.336182] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.336215] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.336417] NET: Registered protocol family 1
[    0.336783] RPC: Registered named UNIX socket transport module.
[    0.336796] RPC: Registered udp transport module.
[    0.336805] RPC: Registered tcp transport module.
[    0.336813] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.337186] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
[    0.338536] futex hash table entries: 512 (order: 3, 32768 bytes)
[    0.340151] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    0.341179] io scheduler noop registered
[    0.341200] io scheduler deadline registered
[    0.341258] io scheduler cfq registered (default)
[    0.343379] dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
[    0.343399] dma-pl330 f8003000.dmac:         DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
[    0.343869] e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 145, base_baud = 2500000) is a xuartps
[    0.917206] console [ttyPS0] enabled
[    0.921351] xdevcfg f8007000.devcfg: ioremap 0xf8007000 to 4a878000
[    0.928113] [drm] Initialized drm 1.1.0 20060810
[    0.940616] brd: module loaded
[    0.947608] loop: module loaded
[    0.956819] libphy: MACB_mii_bus: probed
[    1.033452] macb e000b000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000b000 irq 149 (00:0a:35:00:01:23)
[    1.043352] macb e000b000.ethernet eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=e000b000.etherne:1e, irq=-1)
[    1.054887] i2c /dev entries driver
[    1.060188] rtc-ds1307 0-0068: rtc core: registered ds1340 as rtc0
[    1.066631] cdns-i2c e0004000.i2c: 400 kHz mmio e0004000 irq 143
[    1.073893] zynq-edac f8006000.memory-controller: ecc not enabled
[    1.080108] Xilinx Zynq CpuIdle Driver started
[    1.085189] ledtrig-cpu: registered to indicate activity on CPUs
[    1.092203] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xda
[    1.098515] nand: Micron MT29F2G08ABAEAWP
[    1.102493] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[    1.110086] nand: WARNING: pl353-nand: the ECC used on your system is too weak compared to the one required by the NAND chip
[    1.121596] Bad block table found at page 131008, version 0x01
[    1.127871] Bad block table found at page 130944, version 0x01
[    1.134010] 12 ofpart partitions found on MTD device pl353-nand
[    1.139857] Creating 12 MTD partitions on "pl353-nand":
[    1.145114] 0x000000000000-0x000000780000 : "fsbl"
[    1.150932] 0x000000780000-0x000000b80000 : "kerneldata"
[    1.157209] 0x000000b80000-0x000000c00000 : "device-tree"
[    1.163553] 0x000000c00000-0x000001100000 : "Manufacturedata"
[    1.170248] 0x000001100000-0x000001600000 : "reserved1"
[    1.176450] 0x000001600000-0x000003e00000 : "rootfs"
[    1.182318] 0x000003e00000-0x000004800000 : "firmdata0"
[    1.188487] 0x000004800000-0x000006c00000 : "siglent"
[    1.194536] 0x000006c00000-0x00000d000000 : "datafs"
[    1.200540] 0x00000d000000-0x00000da00000 : "log"
[    1.206236] 0x00000da00000-0x00000f800000 : "upgrade_cramdisk"
[    1.213038] 0x00000f800000-0x000010000000 : "reserved2"
[    1.221121] TCP: cubic registered
[    1.224613] NET: Registered protocol family 17
[    1.229238] Registering SWP/SWPB emulation handler
[    1.235909] rtc-ds1307 0-0068: setting system clock to 2021-01-25 02:28:45 UTC (1611541725)
[    1.249348] cramfs_fill_nand blocks is 320-----------------------
[    1.249348]
[    1.249348]
[    1.249348]
[    1.262390] VFS: Mounted root (cramfs filesystem) readonly on device 31:5.
[    1.269286] devtmpfs: mounted
[    1.272427] Freeing unused kernel memory: 196K (40553000 - 40584000)
Starting rcS...
[    1.545467] UBI-1: ubi_attach_mtd_dev:attaching mtd7 to ubi1
[    1.693853] UBI-1: scan_all:scanning is finished
[    1.704846] UBI-1 warning: print_rsvd_warning: cannot reserve enough PEBs for bad PEB handling, reserved 3, need 40
[    1.716002] UBI-1: ubi_attach_mtd_dev:attached mtd7 (name "siglent", size 36 MiB)
[    1.723466] UBI-1: ubi_attach_mtd_dev:PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[    1.732032] UBI-1: ubi_attach_mtd_dev:min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[    1.740576] UBI-1: ubi_attach_mtd_dev:VID header offset: 2048 (aligned 2048), data offset: 4096
[    1.749274] UBI-1: ubi_attach_mtd_dev:good PEBs: 288, bad PEBs: 0, corrupted PEBs: 0
[    1.757027] UBI-1: ubi_attach_mtd_dev:user volume: 1, internal volumes: 1, max. volumes count: 128
[    1.765979] UBI-1: ubi_attach_mtd_dev:max/mean erase counter: 17/8, WL threshold: 4096, image sequence number: 1299742721
[    1.776939] UBI-1: ubi_attach_mtd_dev:available PEBs: 0, total reserved PEBs: 288, PEBs reserved for bad PEB handling: 3
[    1.787829] UBI-1: ubi_thread:background thread "ubi_bgt1d" started, PID 582
[    1.790223] UBI-2: ubi_attach_mtd_dev:attaching mtd6 to ubi2
[    1.834489] UBI-2: scan_all:scanning is finished
[    1.845288] UBI-2 warning: print_rsvd_warning: cannot reserve enough PEBs for bad PEB handling, reserved 9, need 40
[    1.856295] UBI-2: ubi_attach_mtd_dev:attached mtd6 (name "firmdata0", size 10 MiB)
[    1.863916] UBI-2: ubi_attach_mtd_dev:PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[    1.872502] UBI-2: ubi_attach_mtd_dev:min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[    1.881044] UBI-2: ubi_attach_mtd_dev:VID header offset: 2048 (aligned 2048), data offset: 4096
[    1.889744] UBI-2: ubi_attach_mtd_dev:good PEBs: 80, bad PEBs: 0, corrupted PEBs: 0
[    1.897398] UBI-2: ubi_attach_mtd_dev:user volume: 1, internal volumes: 1, max. volumes count: 128
[    1.906360] UBI-2: ubi_attach_mtd_dev:max/mean erase counter: 87/43, WL threshold: 4096, image sequence number: 2009223325
[    1.917408] UBI-2: ubi_attach_mtd_dev:available PEBs: 0, total reserved PEBs: 80, PEBs reserved for bad PEB handling: 9
[    1.928216] UBI-2: ubi_thread:background thread "ubi_bgt2d" started, PID 586
[    1.934978] UBI-3: ubi_attach_mtd_dev:attaching mtd9 to ubi3
[    1.974879] UBI-3: scan_all:scanning is finished
[    1.985661] UBI-3 warning: print_rsvd_warning: cannot reserve enough PEBs for bad PEB handling, reserved 9, need 40
[    1.996668] UBI-3: ubi_attach_mtd_dev:attached mtd9 (name "log", size 10 MiB)
[    2.003765] UBI-3: ubi_attach_mtd_dev:PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[    2.012346] UBI-3: ubi_attach_mtd_dev:min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[    2.020887] UBI-3: ubi_attach_mtd_dev:VID header offset: 2048 (aligned 2048), data offset: 4096
[    2.029583] UBI-3: ubi_attach_mtd_dev:good PEBs: 80, bad PEBs: 0, corrupted PEBs: 0
[    2.037262] UBI-3: ubi_attach_mtd_dev:user volume: 1, internal volumes: 1, max. volumes count: 128
[    2.046250] UBI-3: ubi_attach_mtd_dev:max/mean erase counter: 8/4, WL threshold: 4096, image sequence number: 1866265482
« Last Edit: January 24, 2021, 07:04:14 pm by Elasia »
Offline tubularnut
Definitely not working with the telnet script from 31st May 2020.
In fact, even weirder, trying to run the script, it times out after 60 seconds. I've never had that before, used to be able to run it for as long you wished.
EDIT: Tried 2 other USB sticks to make sure, and also the SSA version, same result.
« Last Edit: January 24, 2021, 07:14:06 pm by tubularnut »
Offline Elasia
Upgrade log part 2
[    2.057098] UBI-3: ubi_attach_mtd_dev:available PEBs: 0, total reserved PEBs: 80, PEBs reserved for bad PEB handling: 9
[    2.067882] UBI-3: ubi_thread:background thread "ubi_bgt3d" started, PID 590
[    2.070055] UBI-0: ubi_attach_mtd_dev:attaching mtd8 to ubi0
[    2.470806] UBI-0: scan_all:scanning is finished
[    2.483096] UBI-0: ubi_attach_mtd_dev:attached mtd8 (name "datafs", size 100 MiB)
[    2.490537] UBI-0: ubi_attach_mtd_dev:PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[    2.499140] UBI-0: ubi_attach_mtd_dev:min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[    2.507666] UBI-0: ubi_attach_mtd_dev:VID header offset: 2048 (aligned 2048), data offset: 4096
[    2.516372] UBI-0: ubi_attach_mtd_dev:good PEBs: 800, bad PEBs: 0, corrupted PEBs: 0
[    2.524109] UBI-0: ubi_attach_mtd_dev:user volume: 1, internal volumes: 1, max. volumes count: 128
[    2.533060] UBI-0: ubi_attach_mtd_dev:max/mean erase counter: 13/7, WL threshold: 4096, image sequence number: 626955013
[    2.543946] UBI-0: ubi_attach_mtd_dev:available PEBs: 0, total reserved PEBs: 800, PEBs reserved for bad PEB handling: 40
[    2.554922] UBI-0: ubi_thread:background thread "ubi_bgt0d" started, PID 594
[    2.574878] UBIFS: background thread "ubifs_bgt1_0" started, PID 597
[    2.606420] UBIFS: recovery needed
[    2.746423] UBIFS: recovery completed
[    2.750095] UBIFS: mounted UBI device 1, volume 0, name "siglent"
[    2.756147] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[    2.765267] UBIFS: FS size: 34410496 bytes (32 MiB, 271 LEBs), journal size 4952064 bytes (4 MiB, 39 LEBs)
[    2.774927] UBIFS: reserved for root: 0 bytes (0 KiB)
[    2.779960] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 0327D069-3DA9-4070-95A1-3E1D117AABDE, small LPT model
[    2.824779] UBIFS: recovery needed
[    2.868505] UBIFS: recovery deferred
[    2.872087] UBIFS: mounted UBI device 2, volume 0, name "firm0", R/O mode
[    2.878830] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[    2.887957] UBIFS: FS size: 7237632 bytes (6 MiB, 57 LEBs), journal size 1650688 bytes (1 MiB, 13 LEBs)
[    2.897346] UBIFS: reserved for root: 0 bytes (0 KiB)
[    2.902385] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 68D1D634-0B41-44C3-8EE7-5B148BE8F0D7, small LPT model
[    2.916088] UBIFS: background thread "ubifs_bgt3_0" started, PID 600
[    2.947719] UBIFS: recovery needed
[    2.970471] UBIFS: recovery completed
[    2.974165] UBIFS: mounted UBI device 3, volume 0, name "log"
[    2.979839] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[    2.988991] UBIFS: FS size: 7237632 bytes (6 MiB, 57 LEBs), journal size 1650688 bytes (1 MiB, 13 LEBs)
[    2.998380] UBIFS: reserved for root: 0 bytes (0 KiB)
[    3.003430] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 35E3C92F-68EC-461E-A46E-9F549FBFB3F1, small LPT model
[    3.016864] UBIFS: background thread "ubifs_bgt0_0" started, PID 602
[    3.048336] UBIFS: recovery needed
[    3.125471] UBIFS: recovery completed
[    3.129147] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[    3.135109] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[    3.144233] UBIFS: FS size: 94597120 bytes (90 MiB, 745 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
[    3.153883] UBIFS: reserved for root: 0 bytes (0 KiB)
[    3.158923] UBIFS: media format: w4/r0 (latest is w4/r0), UUID AB78C81C-0D18-4506-91AE-D6D46AF0DBD0, small LPT model
[    5.601129] Unhandled fault: external abort on non-linefetch (0x818) at 0x36f1c380
Bus error
[    5.628773] irq = 170
[    5.640179] <<-GTP-INFO->> GTP driver installing...
[    5.645226] <<-GTP-INFO->> GTP Driver Version: V2.4<2014/11/28>
[    5.651076] <<-GTP-INFO->> GTP Driver Built@22:06:06, Apr 27 2018
[    5.657201] <<-GTP-INFO->> GTP I2C Address: 0x14
[    5.661800] 0-0014 supply vdd_ana not found, using dummy regulator
[    5.668136] 0-0014 supply vcc_i2c not found, using dummy regulator
[    5.674307] <<-GTP-INFO->> Guitar reset
[    5.803831] <<-GTP-INFO->> IC Version: 928_1060
[    5.814504] <<-GTP-INFO->> X_MAX: 1024, Y_MAX: 600, TRIGGER: 0x00
[    5.833351] <<-GTP-INFO->> create proc entry gt9xx_config success
[    5.839632] input: goodix-ts as /devices/virtual/input/input0
[    5.845620] <<-GTP-INFO->> GTP works in interrupt mode.
[    5.861240] gpib_usb_init
[    5.864015] usbcore: registered new interface driver usb-gpib
startup_app.sh   start++++++++++
rm -f /usr/bin/siglent/usr/*.ADS
upgrade_app1:           starting
-rpf /usr/bin/siglent/usr/usr/upgrade/app/* /usr/bin/siglent/
upgrade_app1:           ending
/usr/bin/siglent/usr/backup/upgrade_app1.sh
rm /usr/bin/siglent/usr/backup/upgrade_app1.sh -rf
rm /usr/bin/siglent/usr/usr/upgrade/* -[   10.470122] UBIFS: background thread "ubifs_bgt1_0" stops
rf
startup_app.sh   end++++++++++
[   11.580464] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   11.592180] ehci-pci: EHCI PCI platform driver
[   11.634512] e0002000.usb supply vbus not found, using dummy regulator
[   11.641398] ci_hdrc ci_hdrc.0: EHCI Host Controller
[   11.646505] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[   11.673372] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[   11.678901] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   11.685713] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   11.692896] usb usb1: Product: EHCI Host Controller
[   11.697778] usb usb1: Manufacturer: Linux 3.19.2-omg-xilinx-svn35686 ehci_hcd
[   11.704917] usb usb1: SerialNumber: ci_hdrc.0
[   11.710067] hub 1-0:1.0: USB hub found
[   11.713832] hub 1-0:1.0: 1 port detected
[   11.719484] e0003000.usb supply vbus not found, using dummy regulator
[   11.782258] usbcore: registered new interface driver usb-storage
[   11.813185] usbcore: registered new interface driver usbhid
[   11.818839] usbhid: USB HID core driver
[   11.828922] mousedev: PS/2 mouse device common for all mice
[   12.033456] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[   12.040055] macb e000b000.ethernet eth0: link up (100/Full)
[   12.209127] usb 1-1: New USB device found, idVendor=154b, idProduct=00ee
[   12.215816] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   12.222927] usb 1-1: Product: USB 2.0 FD
[   12.226843] usb 1-1: Manufacturer: PNY
[   12.230558] usb 1-1: SerialNumber: No!
[   12.236388] usb-storage 1-1:1.0: USB Mass Storage device detected
[   12.245830] scsi host0: usb-storage 1-1:1.0
[   13.247158] random: Aladdin urandom read with 21 bits of entropy available
log init finished
[   13.407710] spidev spi1.1: setup: unsupported mode bits 50
set_output_level ===============10.000000
[   13.509200] UBIFS: completing deferred recovery
[   13.538289] UBIFS: deferred recovery completed
[   13.543169] UBIFS: background thread "ubifs_bgt2_0" started, PID 773
route: SIOCDELRT: No such process
system cmd error!WEXITSTATUS(result) = 1
route del default: Success
[   13.600205] UBIFS: background thread "ubifs_bgt2_0" stops
[   13.624381] UBIFS: background thread "ubifs_bgt2_0" started, PID 785
[   13.667743] UBIFS: background thread "ubifs_bgt2_0" stops
[   13.682381] UBIFS: background thread "ubifs_bgt2_0" started, PID 795
[   13.700014] UBIFS: background thread "ubifs_bgt2_0" stops
[   13.715190] UBIFS: background thread "ubifs_bgt2_0" started, PID 800
[   14.143379] UBIFS: background thread "ubifs_bgt2_0" stops
[   14.159201] UBIFS: background thread "ubifs_bgt2_0" started, PID 812
[   14.178515] UBIFS: background thread "ubifs_bgt2_0" stops
[   14.194933] UBIFS: background thread "ubifs_bgt2_0" started, PID 817
[   14.219471] UBIFS: background thread "ubifs_bgt2_0" stops
[   14.241242] UBIFS: background thread "ubifs_bgt2_0" started, PID 822
[   14.261210] UBIFS: background thread "ubifs_bgt2_0" stops
[   14.648871] <<-GTP-INFO->> System resume.
[   14.648882] gpio-963 (GTP INT IRQ): _gpiod_direction_output_raw: tried to set a GPIO tied to an IRQ as output
[   14.663516] <<-GTP-INFO->> GTP wakeup sleep.
[   14.663525] gpio-963 (GTP INT IRQ): _gpiod_direction_output_raw: tried to set a GPIO tied to an IRQ as output
[   14.852156] UBIFS: background thread "ubifs_bgt2_0" started, PID 827
[   14.886746] UBIFS: background thread "ubifs_bgt2_0" stops
[   14.921098] UBIFS: background thread "ubifs_bgt2_0" started, PID 832
[   14.936315] UBIFS: background thread "ubifs_bgt2_0" stops
rotationAngle:  0 invertx:  false inverty:  false
[   15.455346] scsi 0:0:0:0: Direct-Access     PNY      USB 2.0 FD       PMAP PQ: 0 ANSI: 6
[   15.464911] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   15.470572] sd 0:0:0:0: [sda] 30294016 512-byte logical blocks: (15.5 GB/14.4 GiB)
[   15.480642] sd 0:0:0:0: [sda] Write Protect is off
[   15.487130] sd 0:0:0:0: [sda] No Caching mode page found
[   15.492371] sd 0:0:0:0: [sda] Assuming drive cache: write through
[   15.510395]  sda: sda1
insert~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
[   15.521404] sd 0:0:0:0: [sda] Attached SCSI removable disk
devName ==sda
devName ==sda1
sda1
sleep time == 0
[   15.548167] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
/usr/bin/siglent/usr/tmp/sda1_U-disk0
device:IVISoftwareModuleName:: node error!device:ManufacturerDescription:: node error!found the dir = /usr/bin/siglent/usr/mass_storage/U-disk0
[   17.045293] UBIFS: background thread "ubifs_bgt2_0" started, PID 857
[   17.070323] UBIFS: background thread "ubifs_bgt2_0" stops
0x00000000
0x00000000
Initializing framebuffer device /dev/fb0...
xres=1024, yres=600, xre[   21.994683] input: PolyVision Touch Screen as /devices/virtual/input/input1
sv=1024, yresv=600, xoffs=0, yoffs=0, bpp=16
Initializing touch device /dev/input/event0 ...
Reading From :(goodix-ts)
buttonMask: xmin:0
xmax: 1024
ymin:0
ymax: 600
Initializing VNC server:
        width:  1024
        height: 600
        bpp:    16
        port:   5900
Initializing server...
25/01/2021 02:29:06 Listening for VNC connections on TCP port 5900
rcS Complete
(none) login:
usbtmc_para = insmod /usr/bin/siglent/drivers/g_usbtmc.ko idVendor=0xf4ec idProduct=0x1301 iManufacturer=Siglent iProduct=SVA1032X iSerialNum=No!
insmod: can't insert '/usr/bin/siglent/drivers/libcomposite.ko': File exists
insmod: can't read '/usr/bin/siglent/drivers/udc-xilinx.ko': No such file or directory
insmod /usr/bin/siglent/drivers/libcomposite.ko;insmod /usr/bin/siglent/drivers/udc-xilinx.ko;: No such file or directory
[   30.526827] ######################### usb_gadget_probe_driver 3f09d738 ##################
[   30.535106] usbtmc_bind+++
[   30.539994] SIGLENT_DEV: SIGLENT_DEV, version: 2007 OCT 06
[   30.546478] usbtmc_open()++
[   30.549212] dev->usbtmc_cdev_open ret = 0
[   30.553232] ret = 0
[   30.555355] usbtmc_open--
[   30.558067] show_send_buffer_size = 61440
Offline Elasia
I wonder if they added some kind of new validation perhaps to the file load process? Im hardwired into the debug port at all times so thats how mine works
Offline tubularnut
I might bite the bullet and go in via the debug port, just out of interest to see what is going on.
I don't explicitly need telnet, but it was a comfort blanket knowing it was there.
Online tv84
  • Country: pt
Upgrade log
Have you noticed this?
It checks the USB disk for a env file when booting...   ::)
Online tv84
  • Country: pt
Some other Siglent equipments also do that. One needs to make the script stay awake a bit longer...  :) (I didn't do that in these cases, but I could if now it's needed)
Offline tubularnut
Not sure a longer timeout will help if telnet isn't starting?
I'll open it up later in the week and see what is going on, will also later try creating that file on the usb drive, but it may be expecting something in the file itself.
Offline Elasia
Upgrade log
Yeah there are a few interesting nuggets
I liked this one more
Machine model: Zynq Zed Development Board  :popcorn:
Offline Noy
Where can i find the latest working NAND Backup script for the SVA1032?
Will do a backup before i update it...
The following users thanked this post: dc8wan
Offline tomud
Reply #406
https://www.eevblog.com/forum/testgear/siglent-sva1015x-1-5ghz-spectrum-vector-network-analyzer-(coming)/msg3171982/#msg3171982
For every complex problem, there is a solution that is simple neat and wrong...
The following users thanked this post: Kibabalu, dc8wan
Offline Noy
Unfortunally this script isn't working on my SVA1032.
It's doing something but relatively short (30s or so) then its rebooting but nothing is on the USB thumbdrive
Offline Elasia
More than likely broken in the same way the telnet script was... tv84 will have to put out new ones to test
Works fine if you use the console to run it
Offline Noy
Have not upgradet so far.
Still v3.2.2.3.2 and Telnet is permanent opened up (currently without update)
Offline tomud
hmmm
I made a copy of the NAND memory without any problems (SVA1032X firmware V3.2.2.3.3R1). Maybe some problem with flash drive etc.
Offline tubularnut
Connection refused for telnet.
Times out after approx 1 minute, and reverts to file load screen.
Online Bicurico
  • Country: pt
    • VMA's Satellite Blog
Please try this one.
It kills the Aladdin process, before starting telnet.
Regards,
Vitor
Offline tubularnut
Regards,
Vitor
Behaves the same. No telnet, times out after 1 minute.
Offline tubularnut
Or this one.
Port 10101.
Exactly the same, timeout 1 minute, goes back to file screen
$ telnet 192.168.1.203 10101
Trying 192.168.1.203...
telnet: connect to address 192.168.1.203: Connection refused
telnet: Unable to connect to remote host
$ ping 192.168.1.203
PING 192.168.1.203 (192.168.1.203): 56 data bytes
64 bytes from 192.168.1.203: icmp_seq=0 ttl=64 time=4.857 ms
64 bytes from 192.168.1.203: icmp_seq=1 ttl=64 time=5.743 ms
Online Bicurico
  • Country: pt
The problem is: how do you dump the list without telnet and without being able to run upgrade.sh...
The following users thanked this post: Tek14
