Author Topic: Siglent SVA1015X and SVA1032X 1.5, 3.2GHz Spectrum & Vector Network Analyzers  (Read 257235 times)
Offline Johnny B Good
 I'm guessing it's more likely that this data, along with other setup data, is stored in sram ready to be copied at an instant's notice into the flash when the soft power button is pressed to initiate the shutdown process controlled by the OS. It may be being saved to sram every 60 seconds but this only gets written to the flash on each soft power-down cycle.
 Of course there's always the alternative strategy of triggering a short  (10 to 30ms?) write to flash cycle when the PSU PG signal is negated by the loss of mains supply utilising the few hundred milliseconds worth of reserve power remaining in the HT smoothing caps to complete such a short write cycle to guard against even this most extreme of shutdown scenarios.
John
Offline pagrei
Does any one have a vna factory cal file from a genuine SVA1000X they can share?
I’d like to have a go at understanding the internal file format…
Offline pagrei
Specifically, I am after the following files:
/usr/bin/siglent/usr/config/usr_vna_o_calib_log.bin
/usr/bin/siglent/usr/config/usr_vna_s_calib_log.bin
/usr/bin/siglent/usr/config/usr_vna_calib_log.bin
/usr/bin/siglent/usr/config/usr_vna_ref_log.bin
/usr/bin/siglent/usr/config/enh_rsp_calib_log.bin
/usr/bin/siglent/usr/config/usr_vna_e_calib_log.bin
/usr/bin/siglent/usr/config/usr_vna_e_ref_log.bin
/usr/bin/siglent/usr/config/usr_vna_o_calib.bin
/usr/bin/siglent/usr/config/usr_vna_s_calib.bin
/usr/bin/siglent/usr/config/usr_vna_calib.bin
/usr/bin/siglent/usr/config/usr_vna_ref.bin
/usr/bin/siglent/usr/config/enh_rsp_calib.bin
/usr/bin/siglent/usr/config/usr_vna_e_calib.bin
/usr/bin/siglent/usr/config/usr_vna_e_ref.bin
Offline CoolNamesAllTaken
    • Personal Website
After upgrading my SVA1032X to firmware version 3.2.2.6.2R5.r19, I seem to no longer be able to save .CAL files, to the local file system nor to an external USB drive. Has anyone else experienced this issue? Any attempts to save .CAL or .CSA result in a "MSG: Save file failed!" warning. It seems that I can still save CSVs and other file types.
For what it's worth, the calibration does seem to stick between reboots after it's done, but it's weird to not be able to save it to a separate file.
Offline NY2KW
If you can give me some basic instruction how to download those files, I can try.
Jerry
The following users thanked this post: pagrei
Offline pagrei
Hi Jerry,
Thanks for the offer.  I’m waiting to see if another option “pans out”.  If not, I’ll post some instructions to extract the calibration data to a USB stick.
Pa
Offline pagrei
Hi Tautech,
Did you get any feedback from Siglent regarding the write to NAND every 60 seconds in the latest firmware?
In particular, does it only occur if you don’t select boot to default?
« Last Edit: August 25, 2024, 09:58:14 pm by pagrei »
Offline IM3
Yes, I share the same concerns.
This is preventing me from proceeding with the update. I know that the hardware does have flash memory with a write limit of 100,000 cycles.
It would be great if Siglent acknowledged the concerns of technical users and provided an explanation that inspires confidence.
I have an SSA3075X-R, and this 60-second save feature has been implemented there as well.
« Last Edit: August 26, 2024, 01:21:43 pm by IM3 »
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
Wow, that's theoretically only 28 hours of runtime needed to start having issues of worn memory.....
Offline IM3
The calculation is a bit different: 100,000 flashes / (24 x 60 minutes) = 69 days.  :)
It would be quite strange for Siglent to flash data every minute, so I hope it was just poorly phrased in the firmware notes.
However, the only reason to save data every minute would be for power-down purposes, which must be done in non-volatile memory, such as flash.
I recently photographed a flash memory chip in an SDS5000X. This flash was located near the processor. You can assume that this type of flash is used in all Siglent devices.
« Last Edit: August 27, 2024, 11:12:19 am by IM3 »
Offline spacehen
Saving a calibration file works fine on my unit with the latest firmware.
Offline antenna
Re: Siglent SVA1015X and SVA1032X 1.5, 3.2GHz Spectrum & Vector Network Analyzers
« Reply #1011 on: September 07, 2024, 05:18:23 pm »
Is there any more information about the excessive writes with the latest firmware?  I had updated my 1032x and came across this thread before using it again, and now I am afraid to use it until I hear more about this issue.  Thanks!
Offline wma
« Reply #1012 on: September 22, 2024, 05:26:58 am »
The SSA3032X-R is the cheapest of the SSA X-R series and costs €4830, but you can expand it to 7.5 GHz for free, including all options with the key generator that you can download here.
http://tpcg.io/_SV2SRE  (Many thanks to the guys who made this script)
In my opinion, the SSA3032X-R is the device that gives you the most for the least money.
And real time is nice to have, really.
Hi I just want to double check for scripts http://tpcg.io/_SV2SRE  , Do I have to modify 3075 to 7075 and 3050 to 7050 ?
as mentioned in https://www.eevblog.com/forum/testgear/siglent-ssa3000x-spectrum-analyzers/msg5572021/?topicseen#msg5572021
The other thing, how about model SSA3032X-R,
Scripts only have following
#Model = 'SVA1000X'
#Model = 'SSA3000X'
#Model = 'SSA3000X_Plus'
#Model = 'SSA3000R'
Seems scripts does not have particular section for SSA3000X_R
Which Model  that I should use if I want to upgrade it from SSA3032X-R to SSA3075X-R
Many Thanks
Offline IM3
« Reply #1013 on: September 22, 2024, 03:45:35 pm »
Yes, you have to change 3075 to 7075. Skip the 7050 because upgrade in one step wil do the job.
The SSA3000R is the one you need for the SSA3032X-R upgrade.
It’s as easy as it sounds. You will be happy with this upgrade for sure.
Offline wma
« Reply #1014 on: September 23, 2024, 01:45:25 am »
Thank you
